Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Diesel aircraft engines and are the light jets pushing out the twins?
Old September 18th 04, 12:28 AM
In rec.aviation.owning Mike Rapoport wrote:
snip
The question remains, at what HP level, based on the physics of the
engines,
does the crossover from piston to turbine occur?
As additional criteria, assume specific fuel consumption is the most
important parameter and that the A/C spends the majority of its time in
flight not doing touch and goes.
I think that you can look at the market to see where the crossover occurs.
THere are currently no production piston aircraft engines over 450hp and
there are no aircraft turbines under 400hp.
There's lots of ground turbines under 400hp so we know there's a market
there; i.e. they must be practical and competive with pistons or they
wouldn't sell.
I thought the Chinese were still making a big radial, but I could be
wrong on that one and it is a bit of a nit.
If gasoline hadn't risen to twice the price of Jet-A (at least in parts
of Europe), no one would be seriously discussing diesel engines for
aircraft or actively developing them as several manufacturers are now.
So put it this way, if it were the turbine makers instead of the diesel
makers that jumped on this bandwagon, what would be their smallest
engine?
Jim Pennino
Remove -spam-sux to reply.
Old September 18th 04, 12:40 AM
The Caravan has a 940hp engine flat rated to 675hp. Turbines are typically
flat rated so that the engine can make rated power to reasonable altitudes
and temperatures without having to design the gearbox for the full
thermodynamic horsepower. To keep the comparison with piston engines apples
to apples you need to use thermodynamic ratings.
http://www.pwc.ca/en/3_0/3_0http://w.../3_0_2_1_2.asp
OK, that explains that.
To put some numbers on things, the engines in my MU-2 have a specific fuel
consumption of .55lb/hp/hr and a piston engine is about .45 and diesels can
be under .40. Huge (ship) diesels can be under .30. Compare your model
aircraft engines with the TFE731-60 used on the Falcon 900EX which uses
.405lb/lb thrust/hr
Aha, numbers!
So if one assumes the motivation to switch from a piston to a turbine is
the price of gas is roughly twice Jet-A, the crossover point would be a
turbine that did about .8 (to allow for the weight difference in the fuels).
Any idea how small (in appropriate terms of hp) current technology can make
a turbine with that consumption?
Jim Pennino
Old September 18th 04, 12:50 AM
Mike Rapoport
snip
engines,
occurs.
wouldn't sell.
A lot of them are used to power natural gas compressors way out in the
middle of nowhere and reliability is much more important than fuel
efficiency and you have a large suitable fuel supply availible.
engine?
Given the high initial cost of turbines and the hgiher fuel comsumption, I
doubt that turbines would be competitive with gasoline engines given current
price differentials between the two fuels. The beauty of a diesel aircraft
engine is that it should cost the same as a gas engine, has fewer parts,
uses less fuel and lasts longer. The turbine engine is more reliable but
costs more and uses more fuel. The lower the hp the less competitive the
turbine gets against the diesel.
Mike
MU-2
Old September 18th 04, 12:55 AM
Mike Rapoport
typically
altitudes
apples
fuel
can
.405lb/lb thrust/hr
Aha, numbers!
fuels).
make
Jim Pennino
That would be the economic crossover point if the engines cost the same. Of
course a plane that needed twice the fuel (in lbs) to achieve the same
performance wouldn't have much useful load or range.
Mike
MU-2
Old September 18th 04, 01:04 AM
typically
altitudes
apples
fuel
can
.405lb/lb thrust/hr
Aha, numbers!
fuels).
make
Jim Pennino
Dropping a diesel in an airplane costs a bunch. The justification is the
cost is recovered in lowered fuel costs.
Your second point is certainly valid though and a minor problem with the
diesels according to the AVweb article on them.
Jim Pennino
  #28
Old September 18th 04, 01:20 AM
snip
wouldn't sell.
True.
engine?
Your first sentence overlooks the fact that turbines are currently
competitive at the Caravan level, but I pretty much agree with the
rest.
OK, let's say I buy into about 400hp as the "up to now" crossover point.
Given the current fuel cost differential, where would you expect that point
to move to assuming the engines were available?
Jim Pennino
  #30
Old September 18th 04, 03:44 PM
Mike Rapoport
A diesel doesn't cost any more that a piston engine. A STC'd conversion
costs more but, in a new airplane the cost should be the same.
Mike
MU-2
typically
altitudes
apples
fuel
diesels
can
model
uses
.405lb/lb thrust/hr
Aha, numbers!
is
fuels).
make
Jim Pennino
Of
Jim Pennino
