#11
![]() "Otis McNatt" wrote: I was just curious about just how much trouble an MD-88 pilot, say, would have with a 737, if he were just thrust into the cockpit in an emergency situation, without ever having been there before. Could he pass a checkride for the type rating? Probably not. Could he land it? Yes. -- Dan C172RG at BFM |
"Otis McNatt" wrote in message
om... Suppose *both* pilots in, say, a B-737, were to die in flight due to some incredible, but unfortunate coincidence. For instance, one could die of a heart attack, and the other, say, of an aneurysm. Now, I'll admit the chances of this happening are remote, but it could happen; stranger things have. So, suppose it did happen. If there happened to be an airline pilot on board who was certified in any of the other Boeing models, from the 717 up the 747 and 777, but having no experience flying the 737, would he have much of a problem landing the plane? The most modern airliners are automated. The pilot takes off and climbs until at a safe point enganges the autopilot and the plane flies itself from that point on. Most modern airliners have a Flight Management Computer which pretty much does everything, including serving coffee (joke). Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) , requires the pilot to only dial the right nav data; it will intercept the localizer, descend, flare, touchdown, brake, and steer itself down the runway to a stop. When everything works, it's quite amazing to watch ... the first 3-4 times. Then I am ready to bet, it gets boring. So if the plane was not damaged in the accident that killed the two pilots, a person with zero knowledge of piloting, under the guidance of experts on the ground, can land the plane ... for the very simple reason that the plane will land itself. All he/she will have to do is dial the right data in. pilots are there in case something goes wrong and they make sure that the plane is flying great when nothing is going wrong. 1 - the difference between the professional pilot and the rookie is that the rookie is always surprised when an emergency happens, the pro is surprised when no emergency happens. 2 - (this comes from my instructor) thousands and thousands of engeneering hours went into your plane. It knows more about flying than you'll ever do. Just my personal, non-qualified, attempt at an answer. -- Marco Rispoli - NJ, USA / PP-ASEL My on-line aviation community - http://www.thepilotlounge.com |
Marco Rispoli wrote:
Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) Unless things have changed in recent years, there are very few runways that are equipped with a Cat IIIb ILS. -- Chris W Not getting the gifts you want? The Wish Zone can help. http://thewishzone.com |
Otis McNatt wrote: If there happened to be an airline pilot on board who was certified in any of the other Boeing models, from the 717 up the 747 and 777, but having no experience flying the 737, would he have much of a problem landing the plane? Hell, I could probably land it. But I can't tell you what systems are powered by electrical bus B, or whether loss of hydraulic system A renders the auto brakes inop. That's the difference between being a pilot and having a type rating. -- Ben Jackson http://www.ben.com/ |
Chris W wrote
Marco Rispoli wrote: Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) Unless things have changed in recent years, there are very few runways that are equipped with a Cat IIIb ILS. NOT required! At least in the Boeing jetliners that I flew at PanAm. You are confusing "Approach Categories" with "Autoland". In the B-727, the autoland system functioned quite well from a CAT II ILS. Our B-727 minimums were CAT II and if we saw any of the Part 91 "things" at or above minimums, we could just leave the autoland engaged to touchdown. Autoland IS required for CAT IIIb approaches but in my experience, was optional for CAT II operations. Bob Moore ATP B-707 B-727 PanAm (retired) |
"Bob Moore" wrote in message
. 122... Chris W wrote Marco Rispoli wrote: Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) Unless things have changed in recent years, there are very few runways that are equipped with a Cat IIIb ILS. NOT required! At least in the Boeing jetliners that I flew at PanAm. You are confusing "Approach Categories" with "Autoland". In the B-727, the autoland system functioned quite well from a CAT II ILS. Our B-727 minimums were CAT II and if we saw any of the Part 91 "things" at or above minimums, we could just leave the autoland engaged to touchdown. Autoland IS required for CAT IIIb approaches but in my experience, was optional for CAT II operations. Bob Moore ATP B-707 B-727 PanAm (retired) Thanks for the clarification Bob. As I said, I am unqualified and just going by what I am learning in IFR basics ... and MS Flight Sim. ![]() -- Marco Rispoli - NJ, USA / PP-ASEL My on-line aviation community - http://www.thepilotlounge.com |
due to some incredible, but unfortunate coincidence. Unfortunate? You mean Al-Kaida? Then a bearded guy will fly the plane into some tall building... |
due to some incredible, but unfortunate coincidence. For instance, one could die of a heart attack, and the other, say, of an aneurysm. Now, I'll admit the chances of this happening are remote, but it could happen; stranger things have. So, suppose it did happen. If there happened to be an airline pilot on board who was certified in any of the other Boeing models, from the 717 up the 747 and 777, but having no experience flying the 737, would he have much of a problem landing the plane? Airliners are all very similar. A DC-9 pilot would have no difficulty in landing a B-777 under reasonable VFR conditions, given 2 miles of a runway. In the USA it is easy to find big dry salt lakes 5 miles across. Guess, even a Twin Otter pilot could land a B-777 there if talked to on radio. A quad-jet may be another matter, but you could always turn off the outboard engines and land in twin-jet mode just a little bit harder. Damn it, some planes like the A-320 can fly completely automatically, take-off, fly, land and roll to the terminal. I guess the pilots are bored and keep busy by ****ing the stewardesses in-flight. Which increases the risk of cardiac arrest. Especially if the stewardess is blone, britney and TOXIC... |
"Bob Moore" wrote in message In the B-727,
the autoland system functioned quite well from a CAT II ILS. During Cat II trials, my colleagues logged a successful Cat II with autoland at an airport without a Cat II ILS. D. |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 03:48 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
