Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Turbine air start -- too cold?
Old January 14th 05, 03:13 AM
Capt.Doug
"Juan Jimenez" wrote in message
so I bought myself a pressure multiplier (I was worried about hot
starts). It's a simple SMC unit that mechanically multiplies air pressure
by
4x, up to 280-300 psi or so. I have a converted 100# propane tank to hold
the air, which I pressurize to 280 and regulate to 145 psi. It works GREAT
though it takes a while to do its job.
With the air multiplier, you have the pressure, but do you still have the
volume (cubic feet per minute)?
I'm concerned that when I dump the air into
the engine, the drop in pressure is cooling the air so much that it
interferes with the start process and the fuel mist doesn't light up like
it
did in the past.
APUs are designed to start at altitude where the temperature may be minus
40C.
D.
Old January 14th 05, 02:29 PM
Juan Jimenez
"Capt.Doug" wrote in message
news
by
GREAT
it
did in the past.
40C.
The Microturbo Couguar is not an APU. It's a turbojet engine designed to
power small aircraft or drones.
Juan
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 06:51 PM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
Start receiving MONEY with this simple system. Guaranteed. Mr Anderson Aviation Marketplace 0 February 2nd 04 11:55 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
