Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Owner's right to maintenance records?
Old January 20th 05, 12:57 PM
jls
Default Owner's right to maintenance records?
"Peter" wrote in message
Hi All,
Does the owner of an N registered aircraft have the right to keep all
the maintenance records?
Presently, records are kept by maintenance organisations and these are
not normally given to the aircraft owner. So, over the years, bits end
up in different places and as maintenance firms go out of business,
these get lost.
I am currently putting everything together in one place.
I know that under G-reg (which is where the aircraft presently is) I
do have that right because the maintenance records form a part of the
aircraft logbooks. It's the FAA rules I am not sure about.
Moreover, can the maintenance organisation say that they must keep a
copy, and charge me (whatever they like) for making a copy?
Thank you for any feedback.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Hmmmm. British spellings. British address. British rules. If I were a
Brit I'd want all my records together.
Old January 20th 05, 01:21 PM
Denny
N registered aircraft are required to have all work recorded in the
airframe and powerplant logs, what you apparently call maintenance
records... I have no idea why you would think otherwise... My 1957
Apache came with an armload of logbooks going back to day one... In
this country a plane that does not have a complete set of logbooks
suffers a significant drop in the value of the aircraft...
Denny
Old January 20th 05, 02:52 PM
Dude
As far as I am aware, an FAA certified A&P has to put records of work in the
aircraft logs. He may charge you for the entry, but he has to make it or,
depending on the work, he could risk his certificate. Many A&P's charge
hourly rates for the time they spend on your paper work.
Old January 20th 05, 05:48 PM
G.R. Patterson III
In the U.S., the owner frequently (probably usually) keeps the records. The
records are presented to the maintenance organization so that they can inspect
the records during the annual inspection process and make their own entries when
this or any maintenance work is performed.
I've never heard of this being done in the States, but dealing with a shop here
is contractural. If a shop were to make this claim, the owner could choose to go
elsewhere.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old January 20th 05, 05:56 PM
Mark Hansen
On 1/20/2005 01:43, Peter wrote:
Hi All,
The Pilot in Command needs to be able to inspect the Aircraft and
Powerplant maintenance logs to be sure the aircraft is airworthy.
This couldn't be done if the log books were not available to him.
This is in the U.S, anyway.
these get lost.
Peter.
Mark Hansen
PP-ASEL, C-172M/G
Old January 20th 05, 06:50 PM
This request might have a deeper meaning than first apparent. I have
all of the logs from day one for my aircraft but they are not what I
would consider 'complete'. Some of the earlier entries show in broad
terms the work that was performed and then refer to work order #XXX for
details.
If you ask for (demand) copies of all work orders you should be able to
obtain them readily when the work is performed. Trying to go back 20
years or so to retrieve them is a totally different exercise. Yes - you
have the right to all of the documentation, but an attempt to get
copies afetr a number of years would likely be a problem.
Jack
Old January 20th 05, 09:34 PM
The FBO/Repair Station that I used to work for had an excellent policy
on records. We placed a copy of the work order with a detailed listing
of parts and work performed with the aircraft logs. In addition, we
kept a file on each aircraft that included copies of the most current
log book pages dating back to the last annual. Along with those copies,
we included all the maintenance worksheets we used and any paper notes
anyone made during the time the aircraft was in our possesion. It made
it very easy for someone to call us and either verify anything we did
or recover data when the log books were damaged.
Craig C.
Old January 20th 05, 11:46 PM
Michael
Logbooks yes. I have the logbooks. But logbooks don't contain the
*details* of work done. They should contain references to other
documents. For example a logbook might say that a 100hr check was
done. What it won't say (unless the engineer felt like writing it in
there) is that the landing gear gas seals had to be replaced and two
instrument panel light had to be replaced, etc; that will be in a
separate file which is referenced in the logbook.
This is not correct. 14CFR43 requires that a record be made of the
work done. A 100 hr inspection is just that - an inspection. It is
acceptable to state that a 100 hr inspection was performed and no
discrepancies were found. Any discrepancies found and corrected would
be maintenance in addition to the inspection, and would have to be
recorded. It is acceptable to reference a work order, but a copy of
that work order would have to be attached to the maintenance records.
In practice, this often means the mechanic returns the logbook AND a
copy of the work order to the owner. The owner then promptly loses the
copy of the work order, since to him it's just another receipt. The
careful owner will tape/staple/otherwise make the work order a part of
the permanent maintenance record, and this will not happen. Some
owners are so 'careful' that they never throw ANYTHING away, and the
maintenance records are all in one big bag with every receipt for
everything that was ever done in there. Others throw everything away.
Very few (excepting those who do their own maintenance) are anywhere in
between.
If a reference was made to a work order but the work order was not
given to the owner, regulations have been broken. Good luck proving
it, though. If the work is recent the work order will be on file. I
have yet to encounter a repair station that would not make a copy for
the current owner. Yes, they have a right to charge for this but most
won't. But if it's old, forget it. The record is lost.
Michael
Old January 21st 05, 12:46 AM
Doug
I no longer give my maintenance logs to any mechanic or FBO for any
period of time longer than necesarry to attach the log of the work. I
actually prefer to put the log of the work in the maintenance log. Most
mechanics have no problem just giving me a paper with a tearoff sticky
back and I attach it. I have my own way of keeping logs, which is a bit
unconventional. But after having mechanics log their work out of
sequence and in ways that made for sloppy logs, I have taken on the
responsibility myself. Also, I have discovered mistakes in logging made
by previous mechanics. I personally know of an aircraft owner that was
given a violation for having an incorrectly worded log his logbooks.
Since the FAA is saying it is up to the owner/operator, then I do it
myself. Each log goes on it's own seperate sheet of paper. These sheets
of paper are each put in a glassene envelope in a 3 ring binder. I now
have the worlds neatest logs. In the past, I have given my logs to a
mechanic, purportedly worth 1/3 the value of the airplane, and NEVER
did I get a receipt. If they were lost or stolen, he could simply
maintain he never had them. Would you check $25,000 worth of jewelry
into the hotel safe without a receipt or put $25,000 of money into a
bank without a receipt? Yet mechanics take our logs and "throw them
into a non-locked drawer". as if they are the Sunday newspaper. If the
mechanic asks for my logbooks I bring him all of the aircraft paperwork
(POH, manual etc), except the airframe and engine logs (and in my case
propellor and float logs), in a pouch and that seems to make him happy.
Some mechanics seem to want to possess logs as a control issue. I only
give the mechanic the logbooks if they have a need for them. And they
only get to examine them for the time it takes, and I get them back
immediately thereafter. I have no issue with them looking at the logs,
but they cannot take possession of them. If this ever became an issue,
I could easily remove each page and xerox it and give them a copy,
something I should probably do anyway.
Old January 21st 05, 03:05 AM
Aaron Coolidge
In rec.aviation.owning Doug wrote:
: immediately thereafter. I have no issue with them looking at the logs,
: but they cannot take possession of them. If this ever became an issue,
: I could easily remove each page and xerox it and give them a copy,
: something I should probably do anyway.
A far better idea: take a picture of each page with your digital camera.
Put those pictures on a CD. Much easier to store than xerox copies, and
if you ever decide to sell you can just send the CD with the airplane
when it goes for inspections.
Aaron C.
Records Show Bush Guard Commitment Unmet WalterM140 Military Aviation 53 September 13th 04 05:49 PM
Bush's Military Records again the Subject of Cort Action WalterM140 Military Aviation 5 July 21st 04 10:24 PM
USS Liberty Challenge/Reward Issac Goldberg Naval Aviation 75 July 16th 04 09:28 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
