Maule Turbine
Old August 2nd 03, 01:42 AM
kevin
Newps wrote:
kevin wrote:
I was not talking about a conversion, you can buy a new Maule from the
factory with the Allison engine. I was looking at the difference of
cruise speed 164 with the Lycoming as opposed to 190 with the Allsion.
The 2800 fpm climb is also tempting.
The slower Maule will go a lot further between fill ups.
This is true. 15gph as opposed to 25 for the turbine.
Old August 2nd 03, 03:18 PM
Kyler Laird
kevin writes:
15 vs. 25gph for different speeds, right? What are the fuel consumptions
for the same speed at cruise altitudes (10-20K)?
To be fair you should also add in the extra 5 gallons the turbine can
carry (in situations where you're at gross).
--kyler
turbine in microturbine generator for aircraft? Shin Gou Home Built 19 December 26th 04 02:19 PM
turbine propeller sebastian Home Built 19 March 21st 04 12:47 AM
earliest turbine powered helicopter? Charles Gray Military Aviation 7 January 2nd 04 11:35 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
WTB: Turbine ignition exciter unit, single plug Juan E Jimenez Aviation Marketplace 0 August 25th 03 12:48 AM
