Check in ...East Coast BLACKOUT
Old August 20th 03, 08:29 PM
David Lesher
Newps writes:
Montblack wrote:
Now I'm confused. Is my DSL running at higher frequencies, over the same
(single) wire strand that my voice is running on? Or is it running on the
second wire strand, in my standard household wire - which contains 2 wire
strands? Or is it using both strands?
It takes two wires to have a voice line. There are typically 4 wires in
a residential phone line; red, green, yellow and black.
There are 4 wires in older INSIDE WIRING IN YOUR HOUSE. That's
different from the outside plant from the CO to your house.
Normally the
first phone number uses the red and green wires. The other two will be
for your second phone number, should you get one. The DSL uses the same
two wires as your first phone number, with a filter to keep the two
things separate.
And if your IW is newer, it's likely 3-4 pair; blue/white & white/blue;
orange/white [etc], greeen/white, & brown/white...
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
No US soldier should have 2 die for Israel 4 oil Ewe n0 who Military Aviation 1 April 9th 04 11:25 PM
No US soldier should have 2 die for Israel 4 oil Ewe n0 who Naval Aviation 0 April 7th 04 07:31 PM
For Any East Coast Aero Students / Graduates Robert11 General Aviation 0 February 3rd 04 12:10 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
