2 seaters
Old August 30th 03, 11:03 PM
Mark Astley
Marco,
I've posted this befo if you're on a budget check out this article at
AvWeb:
http://www.avweb.com/news/usedacft/181782-1.html
Check out the section on "entry-level trainer", that's the category you're
buying into. They cover the skipper and the high-wings you don't like.
They also say "why buy a two-seater when you can get a four-seater for the
same price"? I took that advice when I picked up by PA28-140, which is also
in your price range. Anyway...
The skipper gets fair reviews and you can pick up decent ones that aren't
too old. The tomahawk, which is a near clone, is another story. It has a
few black eyes due to its stall/spin behavior (at least until several ADs
were applied). You'll want to be careful shopping for tomahawks and some
people simply don't trust them (Rich Stowell, famous for spin training, is
one such person, at least that's what he's said in the past). Don't know
anything about the M10, sorry. I DO know that the first M20s had wooden
wings, if that's true for the M10 then steer well clear.
good luck,
mark
"Marco Rispoli" wrote in message
t...
In my quest to purchase an aircraft I came to the conclusion that a 2
seater
could fit my mission parameters AND my budget.
I can afford:
Beech Skipper (goes between 25-35 grands age around 20+)
Mooney M10 (same as the skipper ... but it's older age around 30+)
Piper Tomahawk (same as the skipper).
Are there any other low wing 2 seaters out there that I am missing?
(probably, yes ...)
By the way it's not by chance that there's no high-wings in my list. I
know
I can probably buy a cub for the same price ... I am just not too crazy
about high wings ... I will look into those later, if I have no other
choice.
Thanks
Marco Rispoli - NJ, USA
You can read my flight training diary at
http://www.tranceweb.net
Old August 31st 03, 12:13 AM
Mitch Hines
"Mark Astley" wrote in message
Marco,
clip
Don't know anything about the M10, sorry. I DO know that the first M20s
had wooden
good luck,
mark
/clip
Just for the record, the Mooney M10 Cadet is all-metal. It is really just
an Aircoupe with its tail feathers clipped. Mooney bought the
Ercoupe/Aircoupe type certificate and started producing the plane after
Alon. But they clipped off the most distictive part of the 'Coupe, the twin
vertical fins and replace it with their well know Mooney tail. With the twin
Tails the plane was placarded as incapable of spinning, under normal CG
limits it just could not be made to spin. For better or worse, this was
not true once Mooney put their tail on it. In my opinion, Mooney did Fred
Weick's design a great disservice. The M10 may be a great little plane, but
it just ain't the same bird.
Mitch Hines
Alon A-2 Aircoupe
N6369V
Flight by machines heavier than air is unpractical
and insignificant, if not utterly impossible.
- Simon Newcomb, 1902
Old September 1st 03, 10:56 PM
Steve Dold
I think they probably did it because they wanted a conventional trainer.
Although I hated the M10, I have to admit it generated a LOT of attention
when I would taxi into an airport. Not to many people have seen one.
Say NO to useless over-quoting! Just quote a few lines to get the
point across, not the whole goddamn thing, OK? Thanks! :-)
Old August 31st 03, 12:38 AM
Marco Rispoli
Very good reading!
thank you!
Marco,
AvWeb:
also
good luck,
mark
t...
seater
I can afford:
(probably, yes ...)
know
choice.
Thanks
