![]() "Mike Beede" wrote in message ... In article et, Bill Daniels wrote: Every figured what you would do if the wet compass goes TA while you are in the soup and all you have is a manually set DG? Been there. Declare an emergency and request a no-gyro approach. If I'm out of radar coverage, then I guess I'd just start compensating for drift as though there were wind, even though it's really precession error. That would get kind of difficult eventually, so I might be tempted to reset it based on what I thought the winds really were when I appeared to be tracking a course accurately. It probably wouldn't be any worse afterwards.... Did you have some suggestions in mind when you asked the question? If so, I for one would like to hear them. Regards, Mike I declared an emergency and requested a no-gyro approach as you suggested - even though I had gyros. Then, because I had quite a ways to go to the first IFR runway, I figured out that the GPS ground track was almost as good as a wet compass. I just set the DG to the GPS ground track and ignored wind - which worked as long as I didn't change heading often. That got me into approach's radar coverage and the no-gyro approach worked from there. My CFII had told me that there was no backup for a wet compass because "they never fail" - baloney, the glass cracked and all the fluid ran down the instrument panel. After that, it wouldn't move. Made me think. Bill Daniels |
50% of NAZI oil was supplied from US | Grantland | Military Aviation | 106 | January 18th 14 07:58 PM |
FS: 1930's Space Exploration Un-Cut Tatoo Sheet | J.R. Sinclair | Aviation Marketplace | 0 | June 7th 04 06:28 AM |
1930s Navy side numbers. | JDupre5762 | Naval Aviation | 3 | September 24th 03 07:51 PM |
IFR in the 1930's | Rich S. | Home Built | 43 | September 21st 03 01:03 AM |
IFR in the 1930's | Rich S. | Owning | 0 | August 29th 03 11:59 PM |
