![]() Chad Lemmen wrote: I'm wiring some avionics that use shielded wire that needs to have the shield terminated into a connector. Is it best to solder a wire to the shield or crimp a wire to the shield so that I can put a connector pin on it? According to the "Acceptable Methods" manual (I can never remember the AC number), the disadvatage of a wire solder joint is that it might break due to vibration fatigue, but it is never acceptable to add connectors to extend wire. I would solder the wire to the shield. George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens |
Soldering is a very bad way to go in high vibration environments. I lost my
alternator due to an improper repair (solder rather than crimped connector). Vibrations eventually broke the strands. Soldered connections are very brittle. "G.R. Patterson III" wrote in message ... Chad Lemmen wrote: I'm wiring some avionics that use shielded wire that needs to have the shield terminated into a connector. Is it best to solder a wire to the shield or crimp a wire to the shield so that I can put a connector pin on it? According to the "Acceptable Methods" manual (I can never remember the AC number), the disadvatage of a wire solder joint is that it might break due to vibration fatigue, but it is never acceptable to add connectors to extend wire. I would solder the wire to the shield. George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens |
I would use crimp as much as possible. As has already been stated,
solder cracks under vibration and will eventually fail. *** Sent via http://www.automationtools.com *** Add a newsgroup interface to your website today. |
