One thing that bothers me about the 180 we're getting is that it seems to
take almost full left rudder trim to keep the plane tracking straight with 2 people up front & both tanks full. Is that something that's easily fixed? Keep trim where it is but reset the trim knob to center to allow for more travel? We hope to close on Friday. Now I just gotta get CFI endorsement for the insurance so I can get the damn thing home! "Russell Kent" wrote in message ... Jay Honeck wrote: And, BTW: did you know there is a rudder trim indicator on your 180? ;-) Actually, didn't we determine that it is in fact a rudder trim control indicator (i.e. indicates where the control currently is within its full throw)? By way of contrast, I believe that the Cessna electric flap position indicator is actually attached to a cable on the flap, so that the position indicated reflects the actual flap position, regardless of where one positions the flap actuator ("she sells sea shells..."). Of course those that know how the Cessna mechanism works will understand why it has to be that way. Russell Kent |
In article m, Steven Barnes wrote:
One thing that bothers me about the 180 we're getting is that it seems to take almost full left rudder trim to keep the plane tracking straight with 2 people up front & both tanks full. Is that something that's easily fixed? Keep trim where it is but reset the trim knob to center to allow for more travel? I can't answer that, but in best USENET tradition I have a question to follow up: what is the position of the actual trimming surface (I don't know if there's a separate tab or if, like on a Cessna, the rudder is just pulled over a little)? Regards, Mike |
The cherokee trim works by putting spring pressure on the rudder, not with a separate tab. Your rudder may be
out of rig, making it necessary to apply some pressure to put it straight. As far as I know, the indicator is not adjustable. I think it is the edge of a washer on the threaded spring tensioner. It should center when the rudder is properly rigged. You might start by looking to make sure the tension on the cables is correct, that it properly goes over the pulleys and no pulleys are broken. Also check to make sure the rudder bar the pedals are connected to is not slipping at the joint near the middle (as I recall there is a joint in the middle with a bolt through it). Basically, what I am saying is that I don't think the indicator is the problem, rather it is a symptom of a rigging problem. Mike Beede wrote: In article m, Steven Barnes wrote: One thing that bothers me about the 180 we're getting is that it seems to take almost full left rudder trim to keep the plane tracking straight with 2 people up front & both tanks full. Is that something that's easily fixed? Keep trim where it is but reset the trim knob to center to allow for more travel? I can't answer that, but in best USENET tradition I have a question to follow up: what is the position of the actual trimming surface (I don't know if there's a separate tab or if, like on a Cessna, the rudder is just pulled over a little)? Regards, Mike -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
: We hope to close on Friday. Now I just gotta get CFI endorsement for the : insurance so I can get the damn thing home! I understand that completely. When we got our Cherokee 180, I was almost done with my PPL in a 172. Ended up taking a "safety pilot" when I went to fly it home. You can bet that was incentive to finally finish my ticket when I had my "new" airplane sitting on the ramp that I couldn't fly. I didn't want to throw money at an endorsement, familiarity flying, etc, etc when I could do that my own self once I got my ticket. Within a week, I had passed my checkride and gotten comfortable enough in it with a pilot friend that flies cherokees for me to practice on my own... same PPL-SEL as the 172. Now comfortable, I'd like to fly the Cessna again to see what I truly like better. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
![]() On 6-Oct-2003, "Steven Barnes" wrote: One thing that bothers me about the 180 we're getting is that it seems to take almost full left rudder trim to keep the plane tracking straight with 2 people up front & both tanks full. Is that something that's easily fixed? The first thing I would do is to make sure that the "ball" (of the turn coordinator or turn indicator) is centered when the airplane is sitting level on the ground. We had the same issue (full left rudder trim required to center the ball in cruise) with our Arrow, and discovered that the turn coordinator instrument was slightly rotated in the panel, apparently because the mounting screws had somehow loosened. Easy to fix, and probably added a knot or three to cruise speed, since centering the ball prior to the fix actually resulted in a slight slip. -- -Elliott Drucker |
Not only centered, but level. If you have one, take a level with you
to properly set the T&C in the panel. |
CHEROKEE NATIONAL FLY-IN & CONVENTION - A BIG SUCCESS | Don | General Aviation | 0 | June 28th 04 07:08 AM |
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION | Don | General Aviation | 0 | June 16th 04 05:13 AM |
Cherokee National Fly-In & Convention - THIS MONTH | Don | General Aviation | 0 | June 3rd 04 05:01 AM |
Cherokee National Fly-In & Convention | Don | General Aviation | 0 | May 5th 04 08:12 PM |
Cherokee National Fly-In & Convention | Don | General Aviation | 0 | March 20th 04 02:15 AM |
