Thanks Mike. From your experience and other comments on this thread it
seems; this is a common problem that doesn't get worse, does not create irreparable damage and it can be fixed. At least it can be fixed so that the engine doesn't stumble start in mid-summer. The previous owner was convinced the solution was a geared starter, and he was probably right. Now, I'm starting to get the impression the problem could also be fixed with an overhaul of my existing starter. As I mentioned on a previous post I'll research and post. Cheers! Jose Vivanco C-GPYH "Mike Spera" wrote in message ... My 140 has required the initial "bump" you describe for the last ten years I owned it. Our positive braided battery strap has always been in marginal shape. I will probably replace it this fall. It is split at the battery post and does not offer the best connection. What is that hardened putty-like stuff that insulates it from the battery box? That looks like a really crude solution. Do they make some sort of (legal) rubber isolator as a replacement, or do I have to replace it with the same goop? By the way, I have had ours out in -13 and the oil temp is pretty low, even with the plate on. No battery boost was needed, even with the aging cable. With thermal underwear it was still too cool for my tastes. The heater does not keep the plane at any comfort level below 0F. Here in Illinois, +10-+15F is about the reasonable limit on a tiedown. Fortunately, daytime temps don't go lower than that very often. I see what the other respondent was saying about the hangar woes. Here, they plow in front of the hangars and leave a nice 10-15 inch bump of snow that turns to solid ice when the sun bounces off the hangars and partially melts it during the day and it solidifies at night. Mike Jose Vivanco wrote: I live in Ottawa, Canada and this is my first winter as a PA-28-140 owner. My airplane does have copper battery cables (cable ?) and an engine heater but the previous owner warned me; in really cold weather, below (-10C/-23 F) it won't start without a battery boost. The battery boost is in addition to plug-in the aircraft for about an hour before departure. The aircraft doesn't have an engine cover AND it does not have a geared starter. Are there any other PA-28-140s with a similar problem? I will be getting an engine cover, but I don't think this alone will eliminate the battery boost requirements. The battery is two years old. Normal summer start always looks like the battery is dead, i.e. one blade goes by and the prop stops turning, ignition back to off, then crank again and it fires up immediately. My plan this winter is to get a trickle charger for the battery, blanket battery warmer plus regular plug-in of the engine heater. Any other ideas would be greatly appreciated. Thanks in advance. Jose Vivanco C-GPYH. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
I have an E3D also. I noticed another fellow suggested field wiring open
circuits that cause this problem. Well, the problem has persisted through 2 different starters (the second one a fresh overhaul when we swapped out the engine). So, I tend to rule out the starter being the problem. Check your cable connections at the battery. They may be starting to deteriorate. Good Luck, Mike Jose Vivanco wrote: Thanks Mike. From your experience and other comments on this thread it seems; this is a common problem that doesn't get worse, does not create irreparable damage and it can be fixed. At least it can be fixed so that the engine doesn't stumble start in mid-summer. The previous owner was convinced the solution was a geared starter, and he was probably right. Now, I'm starting to get the impression the problem could also be fixed with an overhaul of my existing starter. As I mentioned on a previous post I'll research and post. Cheers! Jose Vivanco C-GPYH "Mike Spera" wrote in message ... My 140 has required the initial "bump" you describe for the last ten years I owned it. Our positive braided battery strap has always been in marginal shape. I will probably replace it this fall. It is split at the battery post and does not offer the best connection. What is that hardened putty-like stuff that insulates it from the battery box? That looks like a really crude solution. Do they make some sort of (legal) rubber isolator as a replacement, or do I have to replace it with the same goop? By the way, I have had ours out in -13 and the oil temp is pretty low, even with the plate on. No battery boost was needed, even with the aging cable. With thermal underwear it was still too cool for my tastes. The heater does not keep the plane at any comfort level below 0F. Here in Illinois, +10-+15F is about the reasonable limit on a tiedown. Fortunately, daytime temps don't go lower than that very often. I see what the other respondent was saying about the hangar woes. Here, they plow in front of the hangars and leave a nice 10-15 inch bump of snow that turns to solid ice when the sun bounces off the hangars and partially melts it during the day and it solidifies at night. Mike Jose Vivanco wrote: I live in Ottawa, Canada and this is my first winter as a PA-28-140 owner. My airplane does have copper battery cables (cable ?) and an engine heater but the previous owner warned me; in really cold weather, below (-10C/-23 F) it won't start without a battery boost. The battery boost is in addition to plug-in the aircraft for about an hour before departure. The aircraft doesn't have an engine cover AND it does not have a geared starter. Are there any other PA-28-140s with a similar problem? I will be getting an engine cover, but I don't think this alone will eliminate the battery boost requirements. The battery is two years old. Normal summer start always looks like the battery is dead, i.e. one blade goes by and the prop stops turning, ignition back to off, then crank again and it fires up immediately. My plan this winter is to get a trickle charger for the battery, blanket battery warmer plus regular plug-in of the engine heater. Any other ideas would be greatly appreciated. Thanks in advance. Jose Vivanco C-GPYH. __________________________________________________ __________________________ ___ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
Eurofighter - useless in cold weather and fog? | Peter Kemp | Military Aviation | 9 | September 13th 03 04:37 AM |
