Lars,
Fit wedges on the leading edges at the wing roots to force a root stall. Some WW2 era military trainers tip stalled to enhance training experience and the root wedge fix is used to remove the characteristic (and surprise) for civilian warbird use. Albert (drake) wrote in message om... Any help/advice/recollection of previous such problems and what you did to fix it will be greatly appreciated. Lars |
Ditto Chuck's response. On one of my experimental gliders, I designed a
delta-wing using a reflex airfoil (M-178 I think.) However, I did not wash out the tips, and I used wingtips that terminated in a sharp points. Big mistake. When tested at high AOA's, massive tip stalls caused the wing to roll 45 degrees and yaw 180 degrees about every 3 seconds. Curiously enough, the Wright boys (yep, them again) used washed out wingtips on the 1902 glider. Harry "flies under polyethylene too" Frey PS: Funny what you can learn from watching the (stress) hawks fly. Isn't it? |
Dave Hyde wrote:
Wright1902Glider wrote: When tested at high AOA's, massive tip stalls caused the wing to roll 45 degrees and yaw 180 degrees about every 3 seconds. Was this a model or was it piloted? Dave 'bowling balls' Hyde Yea, that'd be heck in a dog fight. You could fly a tight landing pattern, though. Nafod "nafod" 40 |
Hi all,
Thanks for your replies. The a/c in question is: http://www.bharat-rakshak.com/IAF/Im...nt/Deepak.html The wingdrop problem has been solved (some years back). Just learnt that all the engineers did was to replace the counter-sunk flat top rivets on the wing-top (holding the skin to the ribs) were replaced by protruding pan-head rivets, which apparently energised the flow (made it more turbulent?). There were rivets all over the wing, but more towards the wing-root side. This solved the wing drop problem i.e. the wing drop while stalling was then gentle enough to be handled by novice pilots. I still am not completely satisfied with the turbulence explaination... why should a more "energised" flow make the wing drop less violent? One character who worked on this kite several years ago said that the stall actually started mid-wing, and progressed very quickly, so that one wing (entire wing, not just the tip or root) stalled and dropped. Dunno if he was farting or not. Has anybody used the protruding rivet approach before to solve wing aerodynamic problems before? Quite a minimalist solution! Drake Lars |
drake wrote:
Hi all, Thanks for your replies. The a/c in question is: http://www.bharat-rakshak.com/IAF/Im...nt/Deepak.html The wingdrop problem has been solved (some years back). Just learnt that all the engineers did was to replace the counter-sunk flat top rivets on the wing-top (holding the skin to the ribs) were replaced by protruding pan-head rivets, which apparently energised the flow (made it more turbulent?). There were rivets all over the wing, but more towards the wing-root side. This solved the wing drop problem i.e. the wing drop while stalling was then gentle enough to be handled by novice pilots. I still am not completely satisfied with the turbulence explaination... why should a more "energised" flow make the wing drop less violent? Sounds like the round head rivets are acting like turbulators. If the boundry layer is not attached to the surface, none of the "energy" in the flow is transfered to the surface. Basically, tickling the boundry layer like that causes it to reattach to the surface. That's what they mean by "energizing" the flow. Make more sense? Richard (the new improved)Lamb Hi ya'll! |
Separation bubbles?
OT: BTW, my experimental glider was a full-sized HG, and I tested it both clipped-in and unclipped. The second method was preferable, as the first allowed the glider to drag me all over the beach at Kitty Hawk. I should note that when I designed this machine, I had very little understanding of the fine points of non-rigid delta-wing aerodynamics. There's a photo of it on my website. Its the "Stormy Petrel 3" photo. The "Stormy Petrel 2A" was a modified "Batso" glider and flew fairly well. Harry http://hometown.aol.com/wright1902/page3.html |
On Thu, 15 Jan 2004 17:01:06 GMT, Richard Lamb
wrote: drake wrote: Hi all, Thanks for your replies. The a/c in question is: http://www.bharat-rakshak.com/IAF/Im...nt/Deepak.html The wingdrop problem has been solved (some years back). Just learnt that all the engineers did was to replace the counter-sunk flat top rivets on the wing-top (holding the skin to the ribs) were replaced by protruding pan-head rivets, which apparently energised the flow (made it more turbulent?). There were rivets all over the wing, but more towards the wing-root side. This solved the wing drop problem i.e. the wing drop while stalling was then gentle enough to be handled by novice pilots. I still am not completely satisfied with the turbulence explaination... why should a more "energised" flow make the wing drop less violent? Sounds like the round head rivets are acting like turbulators. They have done this in Bonanzas for years. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com If the boundry layer is not attached to the surface, none of the "energy" in the flow is transfered to the surface. Basically, tickling the boundry layer like that causes it to reattach to the surface. That's what they mean by "energizing" the flow. Make more sense? Richard (the new improved)Lamb Hi ya'll! |
It must be poor wing design if you have to modify the airfoil with a flow
disrupting rivet head. My Bellanca doesn't have a wing drop problem and doesn't have any rivet heads either. Wonder what the Glass plane builders are doing? Designing the wing correctly? -- Cy Galley - Bellanca Champion Club Newsletter Editor-in-Chief & EAA TC www.bellanca-championclub.com Actively supporting Aeroncas every day Quarterly newsletters on time Reasonable document reprints "Roger Halstead" wrote in message ... On Thu, 15 Jan 2004 17:01:06 GMT, Richard Lamb wrote: drake wrote: Hi all, Thanks for your replies. The a/c in question is: http://www.bharat-rakshak.com/IAF/Im...nt/Deepak.html The wingdrop problem has been solved (some years back). Just learnt that all the engineers did was to replace the counter-sunk flat top rivets on the wing-top (holding the skin to the ribs) were replaced by protruding pan-head rivets, which apparently energised the flow (made it more turbulent?). There were rivets all over the wing, but more towards the wing-root side. This solved the wing drop problem i.e. the wing drop while stalling was then gentle enough to be handled by novice pilots. I still am not completely satisfied with the turbulence explaination... why should a more "energised" flow make the wing drop less violent? Sounds like the round head rivets are acting like turbulators. They have done this in Bonanzas for years. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com If the boundry layer is not attached to the surface, none of the "energy" in the flow is transfered to the surface. Basically, tickling the boundry layer like that causes it to reattach to the surface. That's what they mean by "energizing" the flow. Make more sense? Richard (the new improved)Lamb Hi ya'll! |
