Didja ever wonder...
Old October 23rd 03, 09:13 PM
Jay Honeck
Default Didja ever wonder...
....why our Lycoming engines call for 12 (or 8) quarts of oil, when they blow
out anything over 8 (or 6) quarts?
My old A&P, a real gray head with decades of aviation experience, mentioned
the reason to me in conversation today. Here's the poop:
When Lycoming was certifying these engines, they had to prove that they
could operate them for "x" number of hours at full throttle. (The number
bandied about was in the hundreds of hours, but no one knew for sure.)
Lycoming was not allowed to add oil to the engine during this certification
operation.
Obviously, in order to run at such high power settings for so long, you're
gonna need a lot of oil. Thus, the sump on my O-540 was designed to hold 12
quarts, while the sump on my old O-320 held 8 quarts. This ensured that
they would pass the certification test.
However, since they were certified with these over-sized oil sumps, that
became the only way they could be built and sold. This despite the fact
that anything over 8 and 6 quarts, respectively, ends up painting the belly
of our planes in normal operation...
So now you know...the *rest* of the story.... ;-)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 23rd 03, 09:31 PM
Ron Natalie
"Jay Honeck" wrote in message news:1EWlb.10391$Fm2.7701@attbi_s04...
Bull****. Full throttle isn't a certification requirement. There are various endurance runs,
none of which run even at maximum continuous power for the entire run.
The aircraft certification requirements state the that oil capacity must be such as to
provide the maximum consumption at required temperatures for the endurance of the
AIRCRAFT that the engine is installed in. Any oversizing of the tank is hence to
accomodate the range of uses Lycoming envisioned.
Nope.
Old October 23rd 03, 09:49 PM
Craig Prouse
I've got a 9 qt sump. If I fill it to nine, at the end of a short flight
I'll have eight in the sump and one on the belly. If I see eight, I can
expect that after about ten hours I'll have seven.
My POH used to say something to the effect of: fill to 9 qt (or perhaps
they just said full) for "extended" flight, which they defined as some small
number of hours (2-4). This changed in the last revision to the POH, and no
longer does Cessna apply any undue pressure to fill beyond 8 qt. I was
shocked. Pleased, but shocked.
The POH has always stated, do not operate the engine with less than four
quarts in the sump. Now that's a pretty low standard to meet, since I
generally won't fly it with less than seven quarts at takeoff. So I guess
when I retire and ferry the airplane to Hawaii, I shouldn't really need a
means to add oil while in flight. Just lots of gas.
Old October 23rd 03, 10:20 PM
Roger Long
On our 172 N, it seems to make a difference what kind of flying we're doing.
Natural level is 5, if we fill to 6 and go on a long flight it will be fine.
Fill to 6 and do a lot of touch and gos or short flights with a lot of take
offs and the first quart will blow out.
An extra quart or two on longer flights thus makes good sense.
Roger Long
Old October 23rd 03, 10:29 PM
Michael 182
Two comments:
1) I put a m-20 air/oil separator on my 540 - it does a great job reducing
blowby and keeping the belly clean
2) On my 540 the dip stick has a gasket that fits into the top of the oil
check neck. As the dipstick is inserted it pushes the oil down in the check
tube, making the reading about a qt. low. If I remove the gasket and check,
or check after a few hours I get an accurate reading on the amount of oil in
the engine. So, if I fill to 8 qts, which is what my engine can hold, I'll
actually have closer to 9 qts in the engine.
Michael
blow
mentioned
certification
operation.
12
belly
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 23rd 03, 11:24 PM
Dale
such as to
hence to
I believe there is a requirment that the engine must be able to operate
at rated power within allowable temps with only 50% of the oil sump
capacity. If so that might explain why sumps are seemingly "oversized".
Dale L. Falk
Old October 23rd 03, 11:51 PM
Mike Rapoport
Maybe it obvious to you, but why would you need a lot of oil to run high
power settings?
Mike
MU-2
blow
mentioned
certification
operation.
12
belly
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old October 24th 03, 12:08 AM
Ron Natalie
"Dale" wrote in message ...
Bingo.
33.39 (a) The lubrication system of the engine must be designed and constructed so that it wil
l function properly in all flight attitudes and atmospheric conditions in which the airplane is
expected to operate. In wet sump engines, this requirement must be met when only
one-half of the maximum lubricant supply is in the engine.
Old October 24th 03, 12:47 AM
Mike Spera
..stuff snipped
Jay,
Our 0-320 seems happy with 7 on down.
8 to 7 occurs in about an hour or so. 7 to 6 (or 6 to 5 and so on) takes
about 12 hours for each quart drop.
The surprising thing is that they can run with 2!! Well, the manual says
2 is the minimum. Not sure I want to test it out.
Good Luck,
Mike
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old October 24th 03, 01:36 AM
G.R. Patterson III
Nonsense. At full throttle, they're gonna blow that oil right out in a few
minutes. You could run my Lycoming for at least 250 hours straight if you
started with 7 quarts, and none of it would be blown out.
George Patterson
You can dress a hog in a tuxedo, but he still wants to roll in the mud.
