#11
I had an old ADF that didn't work. I also did not have a DME, but a VFR
GPS. When I started my training I found out, like the other post, that DMEs and ADF were required for several approaches. I pulled out the ADF and traided the GPS for a reconditioned King KLN 89/B and associated hardware. Works for me. ross Tom Nery wrote: My '66 Cherokee 180C currently has a T12C ADF. Even though it has analog tuning, the previous owner installed a Davitron digital frequency read out so it's not as bad to tune as you'd think. Anyway, it now longer points to the NDB (actually the needle never moves) but can successfully tune am radio stations. So my choices a 1 Fix it, 2 Replace it, 3 Remove it. My plane is currently certified for instrument operation (and I plan on starting my IFR training shortly). I also have a Garmin 196 (primary) and a Garmin 195 (backup - came with the plane). Given the fact that ADF is (someday) being phased up (maybe), what is the collective wisdom of the group? Which of the three choices should I pursue? Tom |
It's could be the right time to get the IFR GPS since you are getting ready
to train. A VFR unit is nice backup but can't replace it in IFR ops. Then junk it. It would be a waste of money and training time to fix it. AM radio? Is there stuff on there? Get an Ipod and plug it into your intercom. "Tom Nery" wrote in message news:bfElb.540$9E1.5435@attbi_s52... My '66 Cherokee 180C currently has a T12C ADF. Even though it has analog tuning, the previous owner installed a Davitron digital frequency read out so it's not as bad to tune as you'd think. Anyway, it now longer points to the NDB (actually the needle never moves) but can successfully tune am radio stations. So my choices a 1 Fix it, 2 Replace it, 3 Remove it. My plane is currently certified for instrument operation (and I plan on starting my IFR training shortly). I also have a Garmin 196 (primary) and a Garmin 195 (backup - came with the plane). Given the fact that ADF is (someday) being phased up (maybe), what is the collective wisdom of the group? Which of the three choices should I pursue? Tom |
On Wed, 22 Oct 2003 23:18:32 GMT, "Tom Nery"
wrote: So my choices a 1 Fix it, 2 Replace it, 3 Remove it. Actually you have a fourth choice which is to leave it as is g. That is the choice I would use -- but that's for me, here. The reason: My local airport's altimeter setting can ONLY be received on the ADF. Without being able to receive that frequency, I have to use a remote altimeter setting, and the MDA is increased by 160' This is not true in most parts of the country, so you may not want the hassle of keeping it. Now, I don't need it to point -- only to receive the station. If the stock market is good to me, I'm looking to install a CNX80 this winter. But I will keep the ADF. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Thu, 23 Oct 2003 23:30:37 -0700, Tim Bengtson
wrote: Ron Rosenfeld wrote: The reason: My local airport's altimeter setting can ONLY be received on the ADF. Without being able to receive that frequency, I have to use a remote altimeter setting, and the MDA is increased by 160' What approach is that? Any of the approaches to EPM. There are two NDB, one overlay GPS, and one stand-alone GPS Does the plate say "ADF Required"? No. But it's handy to have if you are executing one of the NDB approaches and don't have a GPS :-)). If not, I wonder if it would be legal to get the altimeter with a garden-variety AM radio. Perfectly legal. In addition, if there were someone on the ground, they could relay the information via Unicomm. But I've not seen a garden-variety AM receiver that would tune to 260. If you know of one, please let me know. The one's I've seen don't go much below the AM broadcast band. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
The reason: My local airport's altimeter setting can ONLY be received on the ADF. Without being able to receive that frequency, I have to use a remote altimeter setting, and the MDA is increased by 160' What approach is that? Does the plate say "ADF Required"? If not, I wonder if it would be legal to get the altimeter with a garden-variety AM radio. Tim |
"Tom Nery" wrote:
Anyway, it now longer points to the NDB (actually the needle never moves) but can successfully tune am radio stations. So my choices a 1 Fix it, 2 Replace it, 3 Remove it. My plane is currently certified for instrument operation (and I plan on starting my IFR training shortly). ... Given the fact that ADF is (someday) being phased up (maybe), what is the collective wisdom of the group? Which of the three choices should I pursue? Remove it and get a certified-for-approaches GPS installed. It would be silly to train for the rating without a GPS in today's world. Many small airports now have *only* GPS approaches. If you do much IFR traveling, you will find the GPS useful. I have found mine essential on two recent occasions; without it I simply wouldn't have been able to get where I needed to go when I wanted to go there. The ADF still may be necessary in some instances, but they are dwindling. I have an ADF in my airplane that I will keep using as long as it still works, but I when it breaks, it's gone. -- Dan C172RG at BFM |
![]() "Tom Nery" wrote in message news:bfElb.540$9E1.5435@attbi_s52... My '66 Cherokee 180C currently has a T12C ADF. Even though it has analog tuning, the previous owner installed a Davitron digital frequency read out so it's not as bad to tune as you'd think. Anyway, it now longer points to the NDB (actually the needle never moves) but can successfully tune am radio stations. So my choices a 1 Fix it, 2 Replace it, 3 Remove it. My plane is currently certified for instrument operation (and I plan on starting my IFR training shortly). I also have a Garmin 196 (primary) and a Garmin 195 (backup - came with the plane). Given the fact that ADF is (someday) being phased up (maybe), what is the collective wisdom of the group? Which of the three choices should I pursue? Those GPS receivers won't count for much in your IFR training, but, for the ADF, I'd dump it. ADF approaches and transmitters are being decommissioned around the country wholesale, and replaced by GPS approaches which are more accurate than ADF anyway. I noticed the price of a new Garmin 155XL IFR-certified GPS is now down to just over $2,000. As soon as I can I plan to get rid of both my ADF and my DME now that GPS can substitute legally for DME. They're just taking up useful load. If you need a solution to the loss of capability to listen to AM radio, I just read an interesting article on AvWeb about satellite radio, which eliminates the need to keep tuning new stations on the ADF when you fly out of range of the stations. You have to pay $10/month for the service, but that's pretty cheap for an elegant solution to the problem, and cheaper than most anything else in aviation, that's for sure. |
Ron Rosenfeld wrote in
: But I've not seen a garden-variety AM receiver that would tune to 260. If you know of one, please let me know. The one's I've seen don't go much below the AM broadcast band. An old one can be modified without too much effort. The newer ones (with a single digital IC for both AM/FM operation can't be. Probably time to whip out the old Galena crystal and cat's whisker. [Okay, I'm showing my age again. G] ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
![]() Tim Bengtson wrote: Good point; I forgot about that. If you are seriously interested in going this route you might check out the various shortwave receivers that are available. I saw a Grundig unit advertised recently in a mail-order catalog. Might've been the Sportsman's Guide, but I'm not sure. George Patterson You can dress a hog in a tuxedo, but he still wants to roll in the mud. |
"CriticalMass"
Those GPS receivers won't count for much in your IFR training, but, for the ADF, I'd dump it. ADF approaches and transmitters are being decommissioned around the country wholesale, and replaced by GPS approaches which are more accurate than ADF anyway. That's a little contradictory isn't it? If you are going to fly GPS approaches at small airports why wouldn't it count for much in your IFR training? I think I know where you are coming from but that position may be a bit of a problem. Outside of learning to do ILSs, everything else is button pushing. Rather than practice NDB approaches with an ADF, you do the overlay with a GPS. Same with VOR overlays. The made for GPS approaches themselves are pretty easy but there is still button pushing and it is not self-evident - especialy on misses and units like..... I noticed the price of a new Garmin 155XL IFR-certified GPS is now down to just over $2,000 Or at least the 300XL which I'm familiar with. I agree with totally with your recommendation - but get it before you train. |
We should replace planes with tie-fighters !!! | Dan Simper | Naval Aviation | 5 | February 6th 05 06:20 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
best source to replace missing cowl fastener | Craig | Owning | 5 | August 25th 03 08:07 PM |
