Replace (Fix) ADF?
Old October 25th 03, 05:02 AM
On 24-Oct-2003, "Dan Luke" c172rgATbellsouthDOTnet wrote:
The ADF still may be necessary in some instances, but they are dwindling.
I have an ADF in my airplane that I will keep using as long as it still
works, but I when it breaks, it's gone.
OK, here's a question for those familiar with use of an IFR certified GPS in
non-GPS approaches. The approach plate for the ILS at my home airport (PAE)
plainly states "ADF REQUIRED". The reason is that the missed approach
procedure calls for intercepting and tracking inbound on a specific heading
to the LOM. In looking over a bunch of approaches it is clear to me that
there are a number of ILSs that carry the ADF REQUIRED indication. My
question is, can an approach certified GPS (legally) be used in lieu of an
ADF for navigational guidance in a segment of an ILS procedure that
nominally requires an ADF? If so, how? If not, it seems to me that
ditching the ADF will close off use of many ILS procedures.
-Elliott Drucker
Old October 25th 03, 06:20 AM
John Clonts
dwindling.
in
(PAE)
heading
-Elliott Drucker
Yes. Punch 'direct-to' and put in the NDB id. Hit 'Obs' if you want to
intercept a different radial/bearing than the one that your already on.
Piece of cake!
Cheers,
John Clonts
Temple, Texas
N7NZ
Old October 25th 03, 04:13 PM
Dan Luke
certified GPS in
airport (PAE)
approach
heading
that
My
of an
From the AIM 1-1-20 f.:
6. Restrictions
(a) GPS avionics approved for terminal IFR operations may be used in
lieu of ADF and/or DME....
[snip]
(f) Charted requirements for ADF and/or DME can be met using the GPS
system, except for use as the principal instrument approach navigation
source. [unless, of course, the approach is charted as an "overlay"
approach].
To do this in the case you describe, I would press the the "direct"
button on the KLN-90B and enter the identifier for the LOM as the
waypoint. I would then have to press "enter" twice, set the GPS to OBS
mode, set the CDI scale to one mile and turn the OBS to the missed
approach course setting on the approach plate.
If I were really flying this approach, I would have already done this
stuff before I ever commenced the approach. It's really the same thing
as tuning in a VOR and setting the OBS on a conventional NAV radio.
More accurate than using the ADF and easier to fly. Oh yeah, and I
would *still* have my ADF tuned to the LOM and be watching it, too.
Dan
C172RG at BFM
We should replace planes with tie-fighters !!! Dan Simper Naval Aviation 5 February 6th 05 06:20 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 3rd 03 11:49 PM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 09:41 AM
best source to replace missing cowl fastener Craig Owning 5 August 25th 03 08:07 PM
