![]() Carl Orton wrote: One thing I noticed was that the "normal" engraved metal manufacturer's data plate that's usually located under the horizontal stabilizer is missing. In its place is an engraved plastic plate with the serial number, model number, etc - the kind of engraved plastic you think of for office nameplates. This is normal for many aircraft more than about ten years old. Back in the early 90s, the FAA decided that every modern aircraft had to have certain data visible outside the plane, and the empennage became the accepted location for this data. Most aircraft had something like what you are seeing added to meet the regulation. The Cessna 150 I owned simply had the pertinent information painted back there. George Patterson You can dress a hog in a tuxedo, but he still wants to roll in the mud. |
Not quite. This was the subject of discussion at the IA renewal clinic last
year. The FAA could care less if it is there or not. The DEA is the one with the regulation and the FAA can not and will not enforce DEA regulation. Just like FAA can not and will not enforce FCC (old radios) regulations. The required manufacturer's data plate is in the forward port side of the aircraft, generally on the sill between the door jamb and the floorboard. The rule is that plate is the ONLY original part of the aircraft that must be on board the aircraft. You could buy the nameplate and build an entire aircraft around it with used/owner-manufactured/new parts and it would be a certificated aircraft. I shared hangar space with an airline pilot that acquired (don't ask how) the data plate from a Jenny. Nothing more, just the plate. He spent ten years of spare time building a perfectly legal Jenny which was absolutely pristine. Unfortunately, just about the time he completed it, he was coming home space-available on PSA 182 ... Jim -This is normal for many aircraft more than about ten years old. Back in the -early 90s, the FAA decided that every modern aircraft had to have certain data -visible outside the plane, and the empennage became the accepted location for -this data. Most aircraft had something like what you are seeing added to meet -the regulation. The Cessna 150 I owned simply had the pertinent information -painted back there. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote in
: Just like FAA can not and will not enforce FCC (old radios) regulations. Speaking of old radios, I tried to track down the old Cyberhangar web site you used to maintain... the one that had pinouts for a lot of the old radios. All the links I found (including the one from RST) were dead. Is the information still around? tnx, jmk ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
year. The FAA could care less if it is there or not. The DEA is the one with the regulation and the FAA can not and will not enforce DEA regulation. Just ike FAA can not and will not enforce FCC (old radios) regulations. Then why is the regulation requiring an external data plate a part of the FAR 45 rule? Maybe your FSDO doesn't want to enforce it but mine will. The impetus for the rule came from the DEA and Customs but the rule is the FAAs and in the New England region they made real sure that we were all complying with it back in the '80s when it came out. The required manufacturer's data plate is in the forward port side of the aircraft, generally on the sill between the door jamb and the floorboard. Not on any Beechcraft or Piper or Mooney or Commander and not on many Cessna's either though on those it is not far from the floor and is on the left side. John Dupre' |
A pre 1988 aircraft does need to have the aircraft type and serial number
visible on the exterior of the aircraft. It does not have to be in the form of a plate but the data has to be there. FAR 45-13 (d) On aircraft manufactured before March 7, 1988, the identification plate required by paragraph (a) of this section may be secured at an accessible exterior or interior location near an entrance, if the model designation and builder's serial number are also displayed on the aircraft fuselage exterior. The model designation and builder's serial number must be legible to a person on the ground and must be located either adjacent to and aft of the rear-most entrance door or on the fuselage near the tail surfaces. The model designation and builder's serial number must be displayed in such a manner that they are not likely to be defaced or removed during normal service. John Dupre Having said that, any aircraft with a legal manufacturer's data plate on the aircraft does NOT NEED a second data plate back by the tailfeathers. I just reread part 45, and nowhere does it demand a second data plate. Your FSDO may be exerting their fifedom above and beyond the law, but there is no FAA requirement for the second data plate. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor |
On Sun, 02 Nov 2003 10:14:44 -0800, Jim Weir wrote:
The required manufacturer's data plate is in the forward port side of the aircraft, generally on the sill between the door jamb and the floorboard. Not on my airplane. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Legal question | PMA | Home Built | 9 | January 14th 05 03:52 AM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
FS: 1984 "The Nonsuch" (Sailing Vessel) Lim Ed Collector Plate in Ontario | J.R. Sinclair | Aviation Marketplace | 0 | February 15th 04 05:57 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Hinges under stress - mechanical engineering type question | Corrie | Home Built | 21 | August 6th 03 08:49 AM |
