On 7 Nov 2003 12:37:59 -0400, Gregg Germain
wrote: In rec.aviation.military Charles Talleyrand wrote: : There are lots of P51s out there, so they are not rare enough. : Further, they are said to be even harder to fly than normal for : vintage and type. Where does it say P-51's are hard to fly? Or harder to fly than "normal"? Every thing is relative. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) --- Gregg "Improvise, adapt, overcome." Smithsonian Center for Astrophysics Phone: (617) 496-1558 |
In rec.aviation.military Roger Halstead wrote:
: On 7 Nov 2003 12:37:59 -0400, Gregg Germain : wrote: :In rec.aviation.military Charles Talleyrand wrote: : :: There are lots of P51s out there, so they are not rare enough. :: Further, they are said to be even harder to fly than normal for :: vintage and type. : : Where does it say P-51's are hard to fly? Or harder to fly than : "normal"? : Every thing is relative. That's why I added "Or harder to fly than 'normal'" and why I put normal in quotes. I'm curious as to how the conclusion was reached - it's certainly harder to fly than a Cessna 152, but not nearly as hard to fly as the space shuttle. I'm assuming he compared them to aircraft contemporary with the P-51 since he used the word "vintage". Was it harder to fly than the P-39? the 39 has some tough spin characteristics. Other than the 51 being somewhat less stable when the aft gas tank was full, I don't know of any other difficult characteristics. Just curious what he meant by "harder". --- Gregg "Improvise, adapt, overcome." Smithsonian Center for Astrophysics Phone: (617) 496-1558 |
![]() "Gregg Germain" wrote in message ... :: There are lots of P51s out there, so they are not rare enough. :: Further, they are said to be even harder to fly than normal for :: vintage and type. : : Where does it say P-51's are hard to fly? Or harder to fly than : "normal"? I'm curious as to how the conclusion was reached - it's certainly harder to fly than a Cessna 152, but not nearly as hard to fly as the space shuttle. I'm assuming he compared them to aircraft contemporary with the P-51 since he used the word "vintage". Was it harder to fly than the P-39? the 39 has some tough spin characteristics. Other than the 51 being somewhat less stable when the aft gas tank was full, I don't know of any other difficult characteristics. Just curious what he meant by "harder". I've read three things. The p51 is unstable in pitch with full tanks and the resulting aft CG, and that a p51 has a high speed stall that's tougher than most other WWII fighters. And finally the p51 has a higher stall speed than other contemporary fighters. I myself have no idea, and will defer to people with actual knowledge. But this is the scuttle-butt around this household. |
"Charles Talleyrand" wrote in message
... "Gregg Germain" wrote in message ... :: There are lots of P51s out there, so they are not rare enough. :: Further, they are said to be even harder to fly than normal for :: vintage and type. : : Where does it say P-51's are hard to fly? Or harder to fly than : "normal"? I'm curious as to how the conclusion was reached - it's certainly harder to fly than a Cessna 152, but not nearly as hard to fly as the space shuttle. I'm assuming he compared them to aircraft contemporary with the P-51 since he used the word "vintage". Was it harder to fly than the P-39? the 39 has some tough spin characteristics. Other than the 51 being somewhat less stable when the aft gas tank was full, I don't know of any other difficult characteristics. Just curious what he meant by "harder". I've read three things. The p51 is unstable in pitch with full tanks and the resulting aft CG, and that a p51 has a high speed stall that's tougher than most other WWII fighters. And finally the p51 has a higher stall speed than other contemporary fighters. I myself have no idea, and will defer to people with actual knowledge. But this is the scuttle-butt around this household. The P-51 is a little more unforgiving than some other WWII fighters because of it's high speed laminar-flow wing - this gives it speed and range, at the cost of a more 'sudden' wing stall and a higher stall speed. The Spitfire is more forgiving to fly because, due to a design quirk, it's airframe actually gives a little shudder to warn you you're near a wing stall state. Matt |
"killfile" wrote: The P-51 is a little more unforgiving than some other WWII fighters because of it's high speed laminar-flow wing - this gives it speed and range, at the cost of a more 'sudden' wing stall and a higher stall speed. The Spitfire is more forgiving to fly because, due to a design quirk, it's airframe actually gives a little shudder to warn you you're near a wing stall state. I've never flown a Spitfire, but if you miss the buffet on a Mustang you must be brain-dead. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
![]() Charles Talleyrand wrote: I've read three things. The p51 is unstable in pitch with full tanks and the resulting aft CG, and that a p51 has a high speed stall that's tougher than most other WWII fighters. And finally the p51 has a higher stall speed than other contemporary fighters. The balance problem is caused by the aft fuselage tank. Many Mustangs have had this removed. In any case, you won't need to fill it unless you're planning a 1600 mile trip. Stall speed in military configuration was about 95, which isn't out of line with other fighters of the era and is actually a bit lower than the Bf-109. I've read, however, that the plane doesn't give warning before the stall and drops the left wing dramatically when it does. Len Deighton claims that few military pilots three-pointed the Mustang because that gets you too close to the stall speed. Some years back, I got to watch 52 of these planes land at Sun'n Fun. Every landing was a wheel landing with the tail slightly low. George Patterson If you're not part of the solution, you can make a lot of money prolonging the problem. |
"G.R. Patterson III" wrote: orary fighters. The balance problem is caused by the aft fuselage tank. Many Mustangs have had this removed. In any case, you won't need to fill it unless you're planning a 1600 mile trip. Stall speed in military configuration was about 95, which isn't out of line with other fighters of the era and is actually a bit lower than the Bf-109. I've read, however, that the plane doesn't give warning before the stall and drops the left wing dramatically when it does. Len Deighton claims that few military pilots three-pointed the Mustang because that gets you too close to the stall speed. Some years back, I got to watch 52 of these planes land at Sun'n Fun. Every landing was a wheel landing with the tail slightly low. I only have 1 hour in a Mustang, but when doing stalls it gave plenty of warning with the stall occuring at about 81KIAS. We did not however do any accelerated stalls. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Dale wrote:
In article , "G.R. Patterson III" wrote: orary fighters. The balance problem is caused by the aft fuselage tank. Many Mustangs have had this removed. In any case, you won't need to fill it unless you're planning a 1600 mile trip. Stall speed in military configuration was about 95, which isn't out of line with other fighters of the era and is actually a bit lower than the Bf-109. I've read, however, that the plane doesn't give warning before the stall and drops the left wing dramatically when it does. Len Deighton claims that few military pilots three-pointed the Mustang because that gets you too close to the stall speed. Some years back, I got to watch 52 of these planes land at Sun'n Fun. Every landing was a wheel landing with the tail slightly low. I only have 1 hour in a Mustang, but when doing stalls it gave plenty of warning with the stall occuring at about 81KIAS. We did not however do any accelerated stalls. That's interesting about 'little warning' and dropping the 'left' wing. I'm only familiar with some heavies and they all gave lots of warning, very 'fine' buffeting progressing to coarser and higher amplitudes before the 'real thing'. Also they all six dropped the 'right' wing. Would that be a function of the prop rotation direction? I notice that all six had right hand rotation, does the Mustang have left hand rotation?, or is it some other factor that causes this?. -- -Gord. |
"Gord Beaman" ) wrote in message . ..
That's interesting about 'little warning' and dropping the 'left' wing. I'm only familiar with some heavies and they all gave lots of warning, very 'fine' buffeting progressing to coarser and higher amplitudes before the 'real thing'. Also they all six dropped the 'right' wing. Would that be a function of the prop rotation direction? I notice that all six had right hand rotation, does the Mustang have left hand rotation?, or is it some other factor that causes this?. From the cockpit the prop turned clockwise. As for stall warning there was more than enough, and landing stall was closer to 75mph than 95 Having flown several thousand hours in the Mustang, other than in extreme crosswinds, all my landings were three point . Flying a Mustang to it's limit is one of the greatest challenges, and one of the greatest pleasures, one can ever experience. Howard Austin |
Military & vintage warbird slides for sale | Wings Of Fury | Aviation Marketplace | 0 | July 10th 04 01:17 AM |
Florida Mil Comms; Tico Warbird Acft | AllanStern | Military Aviation | 4 | March 16th 04 01:49 PM |
Keeping Me Out of Your Warbird? | Stephen Harding | Military Aviation | 47 | February 12th 04 04:34 PM |
Vintage & Warbird mailing list. | Darryl Gibbs | General Aviation | 0 | September 13th 03 09:53 AM |
Vintage & Warbird mailing list. | Darryl Gibbs | Owning | 0 | September 13th 03 09:53 AM |
