Steven Barnes wrote:
: Heh, on the way back from the avionics shop to get the IFR cert done and a : new VOR head installed, the LEDs went out on our #1 comm (KX-155). The first : 2 digits ( 121.9, the 12 is gone). Just went out in flight. What is : involved in replacing the LEDs? Is it the whole cover? Along those lines, I was wondering if anyone had any suggestions for my KN-53 Nav. It's got similar plasma display as the KX-155, but blanks out when it's really humid in the plane... like after a rain and it's cold and damp in there. I took the lid off and snooped around for cold solder joints, but couldn't find any. Upon poking around, I grounded the high-voltage (using my fingertips... slightly unexpeted... yeoch!). That blanked the digits too... SO, I'm thinking that it's a high-impedance "short" when it's humid that kills the HV drive for the display. Any thoughts on a coating, spacer, insulator? Sound plausible? Thanks, -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
I have the same problem with one of my KX155's and my ADF. Funny thing is
that about five minutes after takeoff. The problem clears up. It seems like low voltage, but it isn't. -- John Purner Editor - The $100 Hamburger http://www.100dollarhamburger.com wrote in message ... Steven Barnes wrote: : Heh, on the way back from the avionics shop to get the IFR cert done and a : new VOR head installed, the LEDs went out on our #1 comm (KX-155). The first : 2 digits ( 121.9, the 12 is gone). Just went out in flight. What is : involved in replacing the LEDs? Is it the whole cover? Along those lines, I was wondering if anyone had any suggestions for my KN-53 Nav. It's got similar plasma display as the KX-155, but blanks out when it's really humid in the plane... like after a rain and it's cold and damp in there. I took the lid off and snooped around for cold solder joints, but couldn't find any. Upon poking around, I grounded the high-voltage (using my fingertips... slightly unexpeted... yeoch!). That blanked the digits too... SO, I'm thinking that it's a high-impedance "short" when it's humid that kills the HV drive for the display. Any thoughts on a coating, spacer, insulator? Sound plausible? Thanks, -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
John Purner wrote:
: I have the same problem with one of my KX155's and my ADF. Funny thing is : that about five minutes after takeoff. The problem clears up. It seems like : low voltage, but it isn't. As I said it my post, I'm pretty sure that it's a pseudo-grounding of the high-voltage that runs the displays. They're not LED's, and they require a fairly high voltage, which is easier to bleed off due to humidity. It's definately high enough to make you notice if you accidentally brush up against it! -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Aaron,
I hate to press to much but I really need the help. How exactly do you remove the displays? Thanks very, very much -- John Purner Editor - The $100 Hamburger http://www.100dollarhamburger.com "Aaron Coolidge" wrote in message ... wrote: : John Purner wrote: : : I have the same problem with one of my KX155's and my ADF. Funny thing is : : that about five minutes after takeoff. The problem clears up. It seems like : : low voltage, but it isn't. : As I said it my post, I'm pretty sure that it's a pseudo-grounding : of the high-voltage that runs the displays. They're not LED's, and they : require a fairly high voltage, which is easier to bleed off due to : humidity. It's definately high enough to make you notice if you : accidentally brush up against it! : -Cory John, Cory, try this: Take the displays out. Burnish the silver contacts on the displays. I used a pencil eraser. Note that the contacts are not gold, if they were they would not tarnish. Put a bead of dielectric grease on the display's contacts. This will create a gas-tight contact, and keep the condensation from bleeding off the +150V used to light the displays. Put the displays back in. This is what Conrad up at the Radio Shop at KORH did to my KX155's when I was having similar difficulties a few years ago. No further problems. -- Aaron Coolidge (N9376J) |
One of my co-owners flew the plane a couple days after the digits vanished
on me. He said it worked fine. Hmmm. I was very cold on my flight. Enough that I could see my breath. I wonder if that had something to do with it. "John Purner" wrote in message .. . Aaron, I hate to press to much but I really need the help. How exactly do you remove the displays? Thanks very, very much -- John Purner Editor - The $100 Hamburger http://www.100dollarhamburger.com "Aaron Coolidge" wrote in message ... wrote: : John Purner wrote: : : I have the same problem with one of my KX155's and my ADF. Funny thing is : : that about five minutes after takeoff. The problem clears up. It seems like : : low voltage, but it isn't. : As I said it my post, I'm pretty sure that it's a pseudo-grounding : of the high-voltage that runs the displays. They're not LED's, and they : require a fairly high voltage, which is easier to bleed off due to : humidity. It's definately high enough to make you notice if you : accidentally brush up against it! : -Cory John, Cory, try this: Take the displays out. Burnish the silver contacts on the displays. I used a pencil eraser. Note that the contacts are not gold, if they were they would not tarnish. Put a bead of dielectric grease on the display's contacts. This will create a gas-tight contact, and keep the condensation from bleeding off the +150V used to light the displays. Put the displays back in. This is what Conrad up at the Radio Shop at KORH did to my KX155's when I was having similar difficulties a few years ago. No further problems. -- Aaron Coolidge (N9376J) |
: One of my co-owners flew the plane a couple days after the digits vanished : on me. He said it worked fine. Hmmm. : I was very cold on my flight. Enough that I could see my breath. I wonder if : that had something to do with it. I have seen a couple digits on one of my KX155's stop working in extreme cold. I haven't been able to fix this, except by GENTLY pushing in on the translucent lens, which makes them come back on. Usually by 1000' AGL climbing out they're back on and stay OK for the rest of the day. I suspect there are some questionable contacts that the extreme cold makes, uh, more questionable. -- Aaron Coolidge (N9376J) |
One of my co-owners flew the plane a couple days after the digits vanished on me. He said it worked fine. Hmmm. I was very cold on my flight. Enough that I could see my breath. I wonder if that had something to do with it. Probably. I fly right down to -30 degC, and I notice that my KX-155 display gets extremely flakey on cold days until the plane starts to warm up. All the best, David |
John Purner wrote:
: Aaron, : I hate to press to much but I really need the help. How exactly do you : remove the displays? : Thanks very, very much John, this is for the King Crown equipment (KX155, KN62, etc). Take radio out of plane. Remove front bezel, there are small philips screws on the sides or top & botton of the radio. You don't need to remove the knobs and switches (in fact, you can't until you've removed the bezel). Now, you'll be looking at the display. It's the very fragile, very expensive glass thingy. On the bottom, you'll see a row of 20 to 60 bent silver metal fingers - these are the radio side of the contacts. The display contacts are the dull silver squares that these bright metal fingers are touching. To remove the display, carefully slide it away from the fingers. This is hard to explain without graphics, but the display will slide a small distance directly away from the fingers (toward the top, on a KX-155), and then the bottom (again on a KX-155) will pivot slightly inward and the top slightly outward. This pivoting will allow you to take the display out of the radio, moving it up and away from the radio. There is a little stub on the back of the display; this is how Dale fills them with neon. The stub is exceptionally fragile! The rest of the display is pretty solid, though. Now, you'll see those 20-60 silver-plated fingers on the bottom edge of the display. You can "burnish" them to remove the tarnish with a business card, a pencil eraser, or whatever your favorite burnisher is. Be careful, the silver isn't very thick! NEVER use abrasives of any sort (well, a pencil eraser is technically an abrasive, but it's very fine). Try not to touch these silver-plated contacts as your finger oils & acids will tarnish them again. Do a final cleaning with alcohol. Now is the time to put a bead of dielectric grease on top of those silver square contacts. If you don't have dielectric grease, you may be able to get it at Radio Shack, a good auto parts store, or a boating store. Don't use "white lube", it's lithium based and conductive. Don't use "heat sink grease", or anything but silicon-based dielectric grease! To put the display back in, reverse the process. Drop it into the plastic carrier with the bottom angled in and the top angled out. Push the top down while guiding the bottom into contact with those shiny metal fingers. You can push the left a little, then the right a little, back & forth. Soon, the display will pop back into place. You'll have a big glop of dielectric grease on your dining room table, and on the front of the display. Make sure that the display contacts and the radio shiny fingers are properly aligned, and not touching 2 contacts, etc. Clean the display face with alcohol (rubbing, not bourbon). Takes off the fingerprints, too! Put the front bezel back on, and the radio back in the plane. Presto! No more funky digits! (Probably.) What if this doesn't work? Then, the display itself is probably no good. The neon gradually leaks out, and the display gets dimmer and dimmer. When it's cold, the display is dimmer yet. If this describes the problem you're having, you need a new display, which will cost around $200. Good luck! (PS, to email, remove 'spam' and 'off') -- Aaron Coolidge (N9376J) |
Aaron,
Thanks so much for the very detailed explanation. I will be at the 'port tomorrow to try this on one of my KX-155. I really am grateful! Send your snail mail address to me and I'll send along a copy of The $100 Hamburger or a t-shirt you pick! -- John Purner Editor - The $100 Hamburger http://www.100dollarhamburger.com "Aaron Coolidge" wrote in message ... John Purner wrote: : Aaron, : I hate to press to much but I really need the help. How exactly do you : remove the displays? : Thanks very, very much John, this is for the King Crown equipment (KX155, KN62, etc). Take radio out of plane. Remove front bezel, there are small philips screws on the sides or top & botton of the radio. You don't need to remove the knobs and switches (in fact, you can't until you've removed the bezel). Now, you'll be looking at the display. It's the very fragile, very expensive glass thingy. On the bottom, you'll see a row of 20 to 60 bent silver metal fingers - these are the radio side of the contacts. The display contacts are the dull silver squares that these bright metal fingers are touching. To remove the display, carefully slide it away from the fingers. This is hard to explain without graphics, but the display will slide a small distance directly away from the fingers (toward the top, on a KX-155), and then the bottom (again on a KX-155) will pivot slightly inward and the top slightly outward. This pivoting will allow you to take the display out of the radio, moving it up and away from the radio. There is a little stub on the back of the display; this is how Dale fills them with neon. The stub is exceptionally fragile! The rest of the display is pretty solid, though. Now, you'll see those 20-60 silver-plated fingers on the bottom edge of the display. You can "burnish" them to remove the tarnish with a business card, a pencil eraser, or whatever your favorite burnisher is. Be careful, the silver isn't very thick! NEVER use abrasives of any sort (well, a pencil eraser is technically an abrasive, but it's very fine). Try not to touch these silver-plated contacts as your finger oils & acids will tarnish them again. Do a final cleaning with alcohol. Now is the time to put a bead of dielectric grease on top of those silver square contacts. If you don't have dielectric grease, you may be able to get it at Radio Shack, a good auto parts store, or a boating store. Don't use "white lube", it's lithium based and conductive. Don't use "heat sink grease", or anything but silicon-based dielectric grease! To put the display back in, reverse the process. Drop it into the plastic carrier with the bottom angled in and the top angled out. Push the top down while guiding the bottom into contact with those shiny metal fingers. You can push the left a little, then the right a little, back & forth. Soon, the display will pop back into place. You'll have a big glop of dielectric grease on your dining room table, and on the front of the display. Make sure that the display contacts and the radio shiny fingers are properly aligned, and not touching 2 contacts, etc. Clean the display face with alcohol (rubbing, not bourbon). Takes off the fingerprints, too! Put the front bezel back on, and the radio back in the plane. Presto! No more funky digits! (Probably.) What if this doesn't work? Then, the display itself is probably no good. The neon gradually leaks out, and the display gets dimmer and dimmer. When it's cold, the display is dimmer yet. If this describes the problem you're having, you need a new display, which will cost around $200. Good luck! (PS, to email, remove 'spam' and 'off') -- Aaron Coolidge (N9376J) |
More LED's | Veeduber | Home Built | 19 | June 9th 04 10:07 PM |
LED tail strobe | Jeff Peterson | Home Built | 41 | May 15th 04 03:13 PM |
LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 01:53 AM |
LEDs with Strobe lights | pekka1510 | Home Built | 11 | August 31st 03 11:36 PM |
LEDs | Morgans | Home Built | 6 | August 19th 03 03:49 AM |
