What is PMAed, STDed, etc.?
Old November 19th 03, 09:48 PM
G.R. Patterson III
Andrew Gideon wrote:
Ah, so a PMA is aircraft-specific?
Not exactly. If the item is (for example) a Cessna wing flap, then the answer
is yes. If it's a replacement for something more generic, it can be used to
replace that item on any aircraft that uses it. A good example would be one of
these lightweight starter motors. Since the part is legally a direct replacement
part, no STC is required.
The 337 is required for any change that the local FSDO believes is a "major"
modification.
An STC is legally a change to the original type certificate that allows you do
do something the original manufacturer didn't do.
George Patterson
A man who carries a cat by the tail learns something that can
be learned no other way.
