What is PMAed, STDed, etc.?
Old November 20th 03, 12:59 AM
Bob Noel
In article ne.com,
Andrew Gideon wrote:
If the part is not PMA'd for your aircraft, you'll need a different
"basis" for the approval of the installation in your aircraft. This
does not need to be via an STC.
Ah, so a PMA is aircraft-specific? That's a little suprising - although
reasonable in retrospect - as a number of aftermarket instrument lighting
vendors advertise that their product is "PMA certified", or some such.
No
mention is made of "...for the following aircraft...".
I'm sorry. I was sloppy with my language. I shouldn't have
said "not PMA'd for your aircraft", but something more like
"not a PMA replacement for a part for your aircraft."
As an example, a digital OAT probe I installed in my cherokee
was PMA'd for certain beechcraft aircraft but not my cherokee.
The installation this digital OAT probe was approved via a 337.
I'm confused about the role of a 337. When is one required?
One example is what you've cited: a change for which neither PMA nor STC
exists. But is one required for a replacement with a PMAed "part"?
It is my understanding that replacing an existing part with
a PMA replacement part wouldn't require a 337.
Is one required for an STCed alteration?
Yes.
are we confused yet?
Bob Noel
Old November 20th 03, 03:47 PM
James M. Knox
Bob Noel wrote in
Is one {PMA} required for an STCed alteration?
Yes.
Not quite.
A part may be manufactured by the owner/operator and installed under
STC, or it may be manufactured *and installed* by the holder of the STC
without PMA. Both these minor points are seldom worthy of note, but
they are there.
For example: GAMI designed their new fuel injectors. They went through
testing and the STC was awarded. They were then allowed to make them
and install them on all aircraft/engines for which the STC applied.
The FAA would not allow the PMA application to be even be submitted
until the STC was approved. [It's not clear that this is a rule, so
much as an FSDO made up rule.] Until the PMA was approved GAMI could
not sell the injectors to anyone else for installation elsewhere. You
wanted the injectors, you flew to Oklahoma and had GAMI put them in.
Once the PMA was approved the restriction went away.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old November 20th 03, 05:51 PM
Andrew Gideon
I'm not sure.
- Andrew
