On Wed, 26 Nov 2003 20:26:21 -0800, A Lieberman
wrote: Ron Wanttaja wrote: I'm currently engaged in a statistical analysis of accidents, and have read about 600 reports in the last several weeks. You still see the main fault being assigned to the pilot when the accident was precipitated by a mechanical fault. The vast majority of those cases involve engine failure (in fact, I don't recall seeing cases that *didn't*). Talking from experience, an engine failure doesn't mean accident. Same as my experience... ended up gliding over downtown, on approach, with the prop stopped. I'm analyzing the accidents included in the NTSB accident database, which does not include incidents. The FAA inspection after an accident is cursory. I respect the FAA guys who do the initial investigation, but they do not perform the same level of investigation that the NTSB does. In one case, the FAA inspector gave me a totally wrong cause for the accident. It took metallurgical testing (which the FAA doesn't do) to establish what had actually happened. I would have to say, it depends WHEN the engine fails as to whether it be pilot fault / error or mechanical. In my opinion, in most cases, engine failure accidents should be attributed to pilot error if THEY FAILED TO FLY THE PLANE during the crisis. All of them flew the plane. Some just didn't land without damage. I'm not going to sit in my comfy office chair and say, "This guy four years ago should have been able to land that plane safely...." Take two brand-new 172s at identical locations. Have both engines suffer connecting rod failures. Have both pilots wearing parachutes. Pilot #1 says, "This sucks," and bails out. The plane crashes and is totally destroyed. Pilot #2 says, "I think I can land in that opening in the trees." Luck isn't with him that day, and he lands a bit long and rolls the plane into the trees. He's uninjured, but dings a wing. Probable NTSB rulings: Case 1: Probable cause was the failure of the connecting rod. Case 2: Pilot error, with failure of the connecting rod as a factor. So, when you study the accident reports, I would be interested at what phase of the flight did the engine fail. Was it on take off, climb out, level flight, descent or landing phases? For take off, and climb out, you really don't get much opportunity to select an alternate emergency landing spot especially at an airport you never have been to. My study is only peripherally touching on pilot error. I'm after data on hardware failures. I have a checkoff box for pilot error, with a few other factors available, but my primary interest is in the accidents involving failure of some component of the aircraft. In my analysis, I would list both Case 1 and Case 2 above as a "Loss of Power (Engine Internal)." Successful landings generally don't even make an incident as in my case. I was expecting "call the tower" routine after landing. I only had to call Flight Services to let them know I was on the ground safely, and have them report back to New Orleans Approach that I was OK. The reportability criteria for aircraft accidents and incidents is contained in NTSB Part 830. I didn't report my engine failure; no damage, no injuries. I did have a thing or two to say to the FBO who sold me contaminated fuel. :-) Successful off field landings are "incidents". I hope you include those in your study. I'm using the NTSB accident reports, which don't include incidents unless they are later upgraded to accidents. So, in a nutshell, with the proper training, an engine failure can be a non event providing you have the ample time to make appropriate decisions. Sorry, I believe that's oversimplified. All forced landings take some element of luck. Two pilots pick different pastures that look the same from 5,000 feet. Both have 8" tall grass, but one field is studded with old railroad ties that you can't see until you get on short final. Time is only one factor. Add a howling crosswind, wires you can't see until you descend, a panicking passenger, and unanticipated better glide ratio because of a stopped prop, and/or a tractor that pulls onto the field as you're on short final. As Ernie Gann said, "Fate is the Hunter". There are a lot of good pilots in graveyards. I think most engine-failure cases are *survivable* (and, actually, most are survived). But I don't fault someone who damages an airplane in a forced landing. The primary goal in an emergency is the saving of the lives involved. and most pilots appear to be pretty good at that. For instance, in the year 2000, about 148 Cessna 172s had accidents, of which 18 resulted in at least one fatality. Of the fatal crashes, none involved a loss of engine power. Eight involved the pilot losing control (typically stall/spin accident), two were VFR to IFR cases, four density altitude, two midair, etc. Allen (who lives in the flatlands of the deep south) Ron Wanttaja (who learned to fly the flatlands of North Dakota, but now flies over the mountains, forests, bays, and sounds of western Washington state.) |
Ron Wanttaja wrote:
Hi Ron, You raise some interesting points. snip All of them flew the plane. Some just didn't land without damage. I'm not going to sit in my comfy office chair and say, "This guy four years ago should have been able to land that plane safely...." I 100 percent agree, Monday morning quarterbacking is much easier then in the thick of things. So for us to make judgement is easier said then done.... Take two brand-new 172s at identical locations. Have both engines suffer connecting rod failures. Have both pilots wearing parachutes. Pilot #1 says, "This sucks," and bails out. The plane crashes and is totally destroyed. Pilot #2 says, "I think I can land in that opening in the trees." Luck isn't with him that day, and he lands a bit long and rolls the plane into the trees. He's uninjured, but dings a wing. Probable NTSB rulings: Case 1: Probable cause was the failure of the connecting rod. Case 2: Pilot error, with failure of the connecting rod as a factor. I actually agree with your probable NTSB rulings. The error you point out is that the pilot dinged the wing, not the engine failure. I don't say it's "right" to fault the pilot, but it was the pilot's decision to bring it back to terra firma and it was his decision that caused the wing to get dinged. The strange part about what you bring up, is that in case two, the pilot will suffer more "legal consequences" then the pilot in case one, which is mucho backwards. In my analysis, I would list both Case 1 and Case 2 above as a "Loss of Power (Engine Internal). Well, the "loss of power" was what caused the pilot to prematurely come down and land, The engine failure was not the direct the cause of the crash in either situation. Your case #2 substantiates this. Go back to my take off example, and yes, I would agree with you that the crash cause would be engine failure. At that phase of flight, the pilot has no alternatives. The reportability criteria for aircraft accidents and incidents is contained in NTSB Part 830. I didn't report my engine failure; no damage, no injuries. I did have a thing or two to say to the FBO who sold me contaminated fuel. :-) And this did not show up on your preflight??? I don't know about others, but I sump everytime I get topped off. Even on layover flights. Sorry, I believe that's oversimplified. All forced landings take some element of luck. Two pilots pick different pastures that look the same from 5,000 feet. Both have 8" tall grass, but one field is studded with old railroad ties that you can't see until you get on short final. Time is only one factor. Add a howling crosswind, wires you can't see until you descend, a panicking passenger, and unanticipated better glide ratio because of a stopped prop, and/or a tractor that pulls onto the field as you're on short final. As Ernie Gann said, "Fate is the Hunter". There are a lot of good pilots in graveyards. I simplify it, but I doubt the NTSB would say pilot error for landing in a field in your example. If you have come across a report that "exaggerated", I would love to see it. I think there is some reasonability in their determinations. Allen |
On Thu, 27 Nov 2003 00:06:41 -0800, A Lieberman
wrote: Ron Wanttaja wrote: The reportability criteria for aircraft accidents and incidents is contained in NTSB Part 830. I didn't report my engine failure; no damage, no injuries. I did have a thing or two to say to the FBO who sold me contaminated fuel. :-) And this did not show up on your preflight??? I don't know about others, but I sump everytime I get topped off. Even on layover flights. There was no water separation in the fuel when I checked the sumps. There were tiny bubbles in the sample, but they looked like air. They did not separate out from the fuel during the time I was sitting on the ground...every sample came up with red fuel, and little tiny bubbles scattered through it, neither rising nor falling. I walked into the FBO with my sample and asked my CFI about it. He'd never seen the phenomena before. Other pilots in the lounge looked at it, and had never seen the effect. We'd had heavy rain the night before. I asked the FBO manager whether that could be water in the fuel, and he insisted that their fuel tanks' water detector would shut off the fuel if water was in the gas In any case, two airplanes had already filled at the same tanks that day with no reported trouble. Everyone gave the fuel sample a clean bill of health, including my CFI. But...the FBO's fuel-tank caps were in shallow pits in the tarmac. The heavy rain had filled the pits...and the caps had leaky gaskets and let the water drain into the tank. The fuel-water separator had only partially worked...I had noticed the fuel had dispensed slowly, but it hadn't shut it off completely. What it *had* done was place the water in suspension in the fuel...that's what the bubbles were. There wasn't any water in the sumps, because it hadn't had a chance to separate yet. I figure the vibration of the engine hastened the precipitation. About five minutes after takeoff, the engine started getting rough. I firewalled it to gain as much altitude as I could and headed towards a nearby airport. the engine finally died completely about 3/4 mile out from the airport...but by that time, I had about 1500 feet. I had a choice between flying directly to the airport and landing downwind, or trying to circle the field to land upwind. I elected to take the downwind landing, but I had a ton of altitude to get rid of and a fairly short distance to do it. BTW, did I mention my airspeed indicator was ALSO inop...due to water in the pitot line? After I landed, I immediately checked the sumps. All I got was scummy pond water. I pelted for the office to call the other airport's FBO and warn them. Then I spent about 45 minutes draining water out of my tanks. After the first five or ten sampler-loads, I started draining it directly into an empty oil can. From the number of times I filled those quart cans, I figure there was about two gallons of water in each of my 13-gallon tanks. While I was doing this, a guy came over and asked what I was doing. I filled a sampler and showed it to him. He said, "Yeah, I use auto fuel, too." The sample mimicked the way 80-octane and auto fuel would mix and turn clear. The two airplanes that had filled before me? The first one to fill that day had flown to another nearby airport. They got hold of him, and he checked his tanks. He had just a cup of water in his fuel. The one that filled up second? He had flown in, filled, and parked. They got about six gallons of water out of his tanks. Did I make a mistake? Yep. Had I crunched it, I would have added an "X" to the "Improper Preflight" column in my accident database. The NTSB probably would have castigated me for my decision to do the deadstick landing downwind, too. As it is, it makes a good hangar story (and for that matter, a good article in FLYING magazine...May 1987). But I had luck on my side, that day. Proximity to an airport, and a bunch of recent practice in the glide-path control techniques described in "Stick and Rudder." Had that 1500 feet to kill in three-quarters of a mile. Full flaps, nose well up with the stall horn nickering. Prop stopped almost immediately. Didn't even have to slip. I was lucky...but it did leave me with plenty of sympathy for those who DON'T have my luck. I simplify it, but I doubt the NTSB would say pilot error for landing in a field in your example. If you have come across a report that "exaggerated", I would love to see it. I think there is some reasonability in their determinations. After the hundreds of reports I read, they all start to blur together. I do remember at least one where the investigator said something like "pilot should have picked the next field over." I tend to remember the REALLY memorable cases, like the Mooney that had its entire tail section fall off on final due to dry rot (the pilot went ahead and landed it...no injuries) or the toxicologic summary of what was in the pilot's blood and organs in one particular accident (alcohol, cannabis, cocaine, prozac, a whole pharmacopeia). In the vast majority of cases, I see nothing in the described situation that makes me argue when the NTSB attributes the accident to pilot error. Of those 172 accidents in 2000, over 60% were due to the pilot incorrectly controlling the aircraft or misjudging his flight path. That 60% doesn't include an additional 5% that ran out of fuel, or the 2% that flew VFR into IFR conditions, or several other causes that are related to bad judgment on behalf of the PIC. However, there's a danger in that. Years ago, I read a report that revealed that 95% of the people surveyed considered themselves above-average drivers. I don't doubt the numbers are similar for pilots. Thus enters an insidious danger in "Pilot Error" accident reporting: People tell themselves, "If the cause was pilot error, I don't have to worry about it because I'm a better pilot than that guy was." We tend to attribute those accidents to bad piloting skills or poor decision making by some "lesser" pilot. "He should have known better." "How can someone make such an idiotic mistake?" Tom Wolfe wrote about this attitude in "The Right Stuff." And I think it's one we're still fighting today. Ron Wanttaja |
Ron Wanttaja wrote:
BTW, did I mention my airspeed indicator was ALSO inop...due to water in the pitot line? Hi Ron, Sounds like you had a run of bad luck with the water. How in the world did water get in your pitot line? Was your drain hole blocked? High winds blowing straight down the pitot tube? I myself have found rain in the static ports, and used a 10wD 40 straw to clear it, but never water in the pitot tube. I will now start checking the drain hole in my preflight. I never thought to before this conversation, I always peer inside the tube to insure no insect nests (I put a cover on anyway, but still check.) I take that word "assume" very seriously. Allen |
On Thu, 27 Nov 2003 07:09:10 -0800, A Lieberman
wrote: Sounds like you had a run of bad luck with the water. How in the world did water get in your pitot line? Was your drain hole blocked? High winds blowing straight down the pitot tube? I live in the Seattle area. 'Nuff said. :-) Seriously, it had to be a combination of rain with strong winds, since I had one of those little "blowback" hinged pitot tube covers on my plane. My tiedown spot faced south, and that's the direction the storm winds come from around here. Still, it's a tiny little hole...hard to believe that water could find and enter it. It happened a couple of times in my ownership of the plane. There was a junction for the pilot line just inboard of the tube, behind an inspection panel in the bottom of the wing. I'd open the panel, disconnect the line, blow on the end of the tube, and be rewarded with a "splut!" sound as water shot from the open end of the line. Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message news ![]() On Thu, 27 Nov 2003 07:09:10 -0800, A Lieberman wrote: Sounds like you had a run of bad luck with the water. How in the world did water get in your pitot line? Was your drain hole blocked? High winds blowing straight down the pitot tube? I live in the Seattle area. 'Nuff said. :-) Seriously, it had to be a combination of rain with strong winds, since I had one of those little "blowback" hinged pitot tube covers on my plane. My tiedown spot faced south, and that's the direction the storm winds come from around here. Still, it's a tiny little hole...hard to believe that water could find and enter it. It happened a couple of times in my ownership of the plane. There was a junction for the pilot line just inboard of the tube, behind an inspection panel in the bottom of the wing. I'd open the panel, disconnect the line, blow on the end of the tube, and be rewarded with a "splut!" sound as water shot from the open end of the line. Ron Wanttaja Interesting, Ron. I had a bug jammed in mine once. He crawled in and hid and then got stuck. I pushed him out with safety wire. BTW, congratulations on the award for your Stits-finished airplane. I do have a lot of respect and faith in the Stits system and in its durability. On the issue of sheepskins saving a life, a cellphone saved the life of an injured Mooney pilot who would probably have frozen to death had he not been able to call and tell his long and lat -- he also had a GPS -- after a cold winter's crash in the dense-forested WNC mountains of Graham County. |
In article , Ron Wanttaja wrote:
There was no water separation in the fuel when I checked the sumps. There were tiny bubbles in the sample, but they looked like air. They did not I remember readin this in the book, "I Learned about Flying From That". The great phrase was, "Looks like champagne", to which the answer was "It costs like champagne" :-) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
[Answering two posting in one]
On 28 Nov 2003 14:08:35 GMT, Mike Spera wrote: ]"the main fault ]being assigned to the pilot when the accident was precipitated by a ]mechanical fault". Guess why? Because if it is not the pilot's fault, ]then it must be the FAA's fault. They set up the processes and ]procedures by which airplanes and their components are tested, approved, ]distributed, tracked, and reinspected. If something goes wrong, either ]this system is not perfect, or it is someone else's fault. Guess which ]option the FAA chooses...? Well...keep in mind that the FAA does not perform the formal accident investigation. They do the initial fact-finding, and all the analysis and determination is performed by the NTSB. While they are both government agencies, they are quite separate. You'll often find the NTSB reports at odds with current FAA regulations/policy (almost always towards trying to make them MORE restrictive, but, hey....) Oddly enough, the NTSB does have *some* regulatory basis for ruling that pilot error was the primary cause in some engine-failure accidents. 14 CFR 91.119, "Minimum Altitudes," says that "...no person may operate below...an altitude allowing, if a power unit fails, a emergency landing without undue hazard to persons or property on the surface." If the field you pick has a fence in it and you end up crashing through it, then you obviously weren't flying at a high enough altitude to select a field where you could land without causing property damage... 1/2 :-) On Fri, 28 Nov 2003 16:37:37 -0000, Dylan Smith wrote: In article , Ron Wanttaja wrote: There was no water separation in the fuel when I checked the sumps. There were tiny bubbles in the sample, but they looked like air. They did not I remember readin this in the book, "I Learned about Flying From That". The great phrase was, "Looks like champagne", to which the answer was "It costs like champagne" :-) Yup...it was published in the third edition of ILAFFT articles. I really *don't* kick about that engine failure. That FLYING article that resulted was the very first writing I got paid for. And the FBO gave me a free fill-up on my next visit. :-) Ron "Brought a microscope that time" Wanttaja |
![]() Well...keep in mind that the FAA does not perform the formal accident investigation. They do the initial fact-finding, and all the analysis and determination is performed by the NTSB. While they are both government agencies, they are quite separate. You'll often find the NTSB reports at odds with current FAA regulations/policy (almost always towards trying to make them MORE restrictive, but, hey....) I know of one case where the FSDO investigated, turned the facts over to the NTSB, and the NTSB conclusion changed the facts to support their conclusion. |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Airliner Seats ... | smjmitchell | General Aviation | 6 | September 26th 04 10:00 PM |
Seat repairs | mikem | Owning | 2 | October 10th 03 09:25 PM |
FS: Sheepskin covers for Cherokee front seats | Jay Honeck | Aviation Marketplace | 0 | September 4th 03 03:38 AM |
