Wingdrop while stalling
Old January 15th 04, 05:01 PM
Richard Lamb
drake wrote:
Hi all,
Thanks for your replies.
The a/c in question is:
http://www.bharat-rakshak.com/IAF/Im...nt/Deepak.html
The wingdrop problem has been solved (some years back). Just learnt
that all the engineers did was to replace the counter-sunk flat top
rivets on the wing-top (holding the skin to the ribs) were replaced by
protruding pan-head rivets, which apparently energised the flow (made
it more turbulent?). There were rivets all over the wing, but more
towards the wing-root side. This solved the wing drop problem i.e. the
wing drop while stalling was then gentle enough to be handled by
novice pilots. I still am not completely satisfied with the turbulence
explaination... why should a more "energised" flow make the wing drop
less violent?
Sounds like the round head rivets are acting like turbulators.
If the boundry layer is not attached to the surface, none of the
"energy" in the flow is transfered to the surface.
Basically, tickling the boundry layer like that causes it to reattach
to the surface. That's what they mean by "energizing" the flow.
Make more sense?
Richard (the new improved)Lamb
Hi ya'll!
Old January 15th 04, 07:27 PM
Wright1902Glider
Separation bubbles?
OT: BTW, my experimental glider was a full-sized HG, and I tested it both
clipped-in and unclipped. The second method was preferable, as the first
allowed the glider to drag me all over the beach at Kitty Hawk. I should note
that when I designed this machine, I had very little understanding of the fine
points of non-rigid delta-wing aerodynamics. There's a photo of it on my
website. Its the "Stormy Petrel 3" photo. The "Stormy Petrel 2A" was a
modified "Batso" glider and flew fairly well.
Harry
http://hometown.aol.com/wright1902/page3.html
Old January 15th 04, 11:26 PM
Dave Hyde
You are a brave, brave man. :-)
Dave 'pirouette' Hyde
Old January 16th 04, 09:36 AM
Roger Halstead
On Thu, 15 Jan 2004 17:01:06 GMT, Richard Lamb
drake wrote:
Hi all,
less violent?
They have done this in Bonanzas for years.
www.rogerhalstead.com
Make more sense?
Hi ya'll!
Old January 16th 04, 02:01 PM
Cy Galley
It must be poor wing design if you have to modify the airfoil with a flow
disrupting rivet head.
My Bellanca doesn't have a wing drop problem and doesn't have any rivet
heads either.
Wonder what the Glass plane builders are doing?
Designing the wing correctly?
Cy Galley - Bellanca Champion Club
Newsletter Editor-in-Chief & EAA TC
www.bellanca-championclub.com
Actively supporting Aeroncas every day
Quarterly newsletters on time
Reasonable document reprints
"Roger Halstead" wrote in message
drake wrote:
Hi all,
less violent?
Make more sense?
Hi ya'll!
Old January 16th 04, 06:25 PM
C.D.Damron
"Cy Galley" wrote in message
news:69SNb.79462$I06.340710@attbi_s01...
Are you kidding?
Airfoil selection and wing design is about making priorities and
compromises.
The majority of planes have some external flow control and I wouldn't
consider every one a case of poor wing design.
Old January 16th 04, 10:32 PM
Corrie
Deja vu all over again - wasn't there a 90-post thread on this topic
(need for thingies sticking up != bad wing design) a couple months
back? Save your fingers and check the archives....
The Deepak is a nifty-looking little trainer, though. Side-by-side
seating, right?
"C.D.Damron" wrote in message news:s0WNb.81800$na.43654@attbi_s04...
Are you kidding?
compromises.
Old January 17th 04, 12:43 PM
drake
(Corrie) wrote in message . com...
seating, right?
Yes side-by-side seating. The canopy looks cool! (More on the Deepak
below, but is skippable)
Never flew in it though (Infact, flew for the 1st time (ever) in a
Saratoga(sedate plane, though several people did get airsick) and then
in a Supercub (what a sexy old bird!) about 20 days back.(Hey, is
there a '1st time in the air' thread?? )
Is there any refernce to Bonanzas using pan-head rivets at turbulators
anywhere?
And why would a more turbulent airflow prevent tip stalling?(leading
to wing drop) Wont it mean that the tip will stall at a higher AoA? Or
the fact that there were more such rivets towards the root side have a
stablizing effect while stalling?
Boring stuff on the HAL HPT-32 DeepakU may skip)
Specs:
http://www.bharat-rakshak.com/IAF/Ai...cs/Deepak.html
Pics:http://www.bharat-rakshak.com/IAF/Im...nt/Deepak.html
http://www.airshowreport.com/india/008.htm
The Indian fedral audit doomsayers report on the plane and the
problems it had:
(Says the Textron Lycoming engine is causing too much pain)
http://www.cagindia.org/reports/defe...1/chapter3.htm
Goto "7.6.2 Unreliability of trainer aircraft 7.6.2.1 HPT-32 aircraft"
The Indian Parliamentary committee invetigates above report:
(The problem is not the engine but...)
http://164.100.24.208/ls/committeeR/...th/report.html
Goto "5.2.1 HPT-32 aircraft"
Apparently, all problems solved now, the Indian Air Force has ordered
even more Deepaks.
Blue skies y'all,
Lars
ObAeroJoke(from http://iron-eagles.tripod.com/jokes.html):
ATC: "HPT-32, what are your intentions?"
HPT 32: "To get my wings and become a fighter pilot sir."
ATC: "I meant in the next 5 minutes, not ten years!"
Old January 16th 04, 11:36 PM
Dave Hyde
Do you consider any airplane with vortex generators,
washout, or stall strips a poor design? Round-head rivets
sound like a pretty slick and cheap way of adding
vortex generators to me. The list of 'poor designs'
(your words, not mine) that have flow-disrupting
devices to address stall characteristics is long and
distinguished.
doesn't have any rivet heads either.
Give any decent aero guy ten minutes with your Bellanca
and he/she could come up with some ugly external mod that
could improve performance in some part of the envelope.
Doesn't mean it's a poor design - nor does adding an
aerodynamic 'band-aid' rather than redesigning an
entire wing when flight test doesn't match predictions.
Or maybe just accepting the compromises that were designed
in from the start? Should a designer faced with a 'wing drop
problem' scrap the entire wing design altogether and start from
scratch when a simple fix will suffice?
Dave 'trade study' Hyde
Old January 17th 04, 08:57 AM
Roger Halstead
On Fri, 16 Jan 2004 14:01:38 GMT, "Cy Galley"
heads either.
I don't think the early Debs had any washout either.
Sure it drops a wing if you aren't on it, or aren't too sharp
yourself, but with a bit of practice using rudder only you can hold
it in a stall with the nose way up there while wobbling around. Just
don't try to center the ball while doing that. It'll roll over every
time.
I'm so used to it I never figured dropping a wing a bit was anything
to worry about. A little rudder stops it right away. OTOH a lot of
rudder can make for an exciting day:-))
