High Performance Single Engine Choices
Old December 19th 03, 06:19 AM
Ray Andraka
Cherokee Six-260 = 260 HP, becomes 14.4 GPH, actual is about 14.0
Six-300 = 300 HP, becomes 16.6 GPH, actual is about 17.0
A Six-260 will get you close on everything except the speed. My 260 gets
125-130 kts, price is in the ball park. I have about a 1550 lb useful load,
which with full tanks (84 gal), leaves me a few pounds over 1000 lbs for my
wife, 4 (soon to be 5) kids, bags and the dog with full tanks. Range is about
600 nm at 75% with reserves. If you go by the 84 gal capacity, that is 6 hrs,
which at 125 kts is 750nm. Fact is, most linemen won't get the full 84 gals in
there, and climb eats gas at about 23 GPH. The later models have I think a 102
gallon capacity, but they are also a couple hundred pounds heavier with no
increase in max gross.
A lance will get you close on speed, but may be expensive to insure and you
have quite a bit more weight in the folding gear. The 17 GPH burn n the 300 HP
shortens the range considerably for a relatively small speed increase.
Aaron Coolidge wrote:
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
  #82
Old December 19th 03, 03:16 PM
Mike Rapoport
I find the stated performance completely believable particularly since the
stock airplane can reach 177kts. Don't get hung up on the 180kts though it
does not represent cruise speed. It was achieved at a power setting that is
unlikely to result in a long life for the engine. My first airplane was a
Turbo Lance with the Turboplus intercooler and all availible speed mods.
Top speed was in the low 190s. Cruise was about 170kts at 75% in the mid
teens.
Mike
MU-2
"O. Sami Saydjari" wrote in message
The Turbo Arrow III (PA-28R-201T) has a Turboplus intercooler. the
following quote has been passed along to me as being in the TurboPlus
owners manual:
"The results of the FAA Certification
flight, flown by FAA pilots on September 12, 1983 are as follows:
Take off wt. Max. gross weight
Climb speed 97 kts. IAS (best rate)
OAT 25 degrees above standard
Power during climb
to 16,000 feet 200 H.P
Rate of climb 900 FPM (avg.)
Fuel flow Full rich
Highest oil temp 201 F (240 F max)
Highest CHT 417 F (460 F max)
TAS 180 kts. (30" @ 2500 RPM)"
(a) This seems pretty extraordinary. Does anyone here have a Turbo
Arrow III configured with a Turboplus intercooler? Do they actually
experience these sorts of numbers?
(b) Are the results of "FAA Certification flights" publically accessible
somewhere so I can independently confirm this?
-Sami
Roger Halstead wrote:
On Mon, 15 Dec 2003 04:44:21 GMT, "Mike Rapoport"
Try: http://www.risingup.com/planespecs/
I don't know what "range" figure they are using (range with IFR
reserves,
VFR reserves or dry tanks) but it is a place to start.
I think Mike did a great job of listing the qualifications.
They have, at least for the Beech Deb and F33 only "basic" fuel and
much of that is incorrect. OTOH there were so many combinations
listed, but not used it does get confusing. They listed 50 gallons
as the capacity, but very few ever left the factory configured that
way. The early ones had two 25 mains and two 10 aux tanks. Early on
they went to 80 gallons. (You only know when you check out the
individual airplane)
Mine, from the factory has the 4 tank arrangement for 70 gallons @ 14
per hour or 5.0 hours with no reserve of 800 miles.
I carry an extra 15 in each tip for a bit over two more hours which
is roughly 1130 miles. Whack an hour off for reserve plus change and
it's basically an 800 mile plane with a useful load of 580# with full
gas. Either some one stays home or you leave some gas behind.
4 FAA standard 170# adults = 680#
With Joyce and I, it works out just fine and we can take along almost
everything except the kitchen sink. We even get two full size
bicycles in back.
No matter how you look at it the only way a Bo would go the distance
is with tip tanks and the budget doesn't go that high. And don't
forget to go with "useable fuel" and not how much the plane will
carry.
I think he needs to add about 30 to 40 thousand (if not 60,000) to the
price and figure about $20,000 a year.
But ... I can't think of a single plane that would fit the bill.
Going to 6 seats would, except the insurance companies might get fussy
plus the price would be even higher.
What about an older 210? Course the price for maintaining an older
retract can get kinda steep too.
(N833R, S# CD-2 Worlds oldest Debonair?)
www.rogerhalstead.com
Return address modified due to dumb virus checkers
Mike
MU-2
Mike,
Actually, my typical flight will be about 660nm...so I need that
distance (plus 45 mins of reserve).
Still, it would be good to have a sorted list of complex planes based
on
range. You are right...that is the key factor to consider first.
What I would like to know is that once I factor this in, which aircraft
make the short list. My used aircraft book does not list range in the
spec sheet. it lists fuel capacity, but it does not list cruise burn
rates, so it is hard to figure these out. I am just trying to tap into
the expereince of this forum to either make some suggestions, or point
me at sources that has the information I seek.
-sami
Mike Rapoport wrote:
If you are going to really make 800nm flights then there will only be
a
handful of candidates (if any) that meet your other requirements and
none of
them will be close to your budget. In fact, I'm pretty sure that
there
isn't a single airplane that can meet your stated requirements at any
price.
If you are really going to make 800nm flights then range is the only
thing
that matters. It doesn't matter if one airplane is 30kts faster, if
it
has
to refuel it well get there second. Keep in mind that to fly 800nm
legs
you
will need over a 1000nm still air range. You might want to reconsider
payload with full fuel requirement. It doesn't really matter what the
full
fuel payload is. It matters what the payload is with enough fuel to
make
the flight. It is unlikely that you will ever fly four people 800nm
in
a
single since it would be difficult to find three others who are
willing
to
spend 5hrs in a little airplane. Engine TBO is a just one part of
operating
cost, it is silly to insist on some arbitrary number like 2000hrs.
The
real
issue is how much per hour the engine will cost over its lifetime.
I would look at what airplanes are within your budget.. Not just the
aquisition budget but the flying budget too. Can you spend $20k/yr on
flying? $30K? The worst airplane to own is one that is too expensive
for
you to fly regardless of its other virtues. Budget issues will narrow
down
the choices considerably. Then consider insurance if you feel you
need
insurance. Then how many people will realistically be in the airplane
and
how large are they. THEN you can consder the perfornace tradeoffs.
Mike
MU-2
Mike, I am going through a used aircraft guide and, unfortunately,
they
do not ordr their lists in a convenient way. While I agree that I
have
to consider they trade-offs carefully and make some hard choices, it
seems to me that those choices begin with information about each
factor
(like speed) considered seperately. So...that is why it matters.
-Sami
What does it matter? You need to decide what is important to you,
speed,
range, payload or price. You are not going to get all of them.
Your
price
range is so wide that I assume that you haven't really figured out
how
much
you can spend and your performance requirements are so high that you
will
never find anything approaching your budget and your performance.
If I were you, I would buy a the Used Aircraft Guide and start
reading
and
think about what you are really looking for.
Mike
MU-2
Does anyone have, or know where I can find, an ordered list of high
performance single-engine (HPSE) aircraft according to their
crusing
speed?
It would even be cooler to have (average) retail prices in the
list.
If not, I will work on a project to put such a list together if
others
are interested. What I would really like to see is which aircraft
has
the best purchase-price-to-speed ratio. Someone has to have
created
such a list somewhere?!
-Sami
O. Sami Saydjari wrote:
Folks, I am a first-time aircraft buyer. I have a general idea
of
type of aircraft I want, but am having trouble narrowing the list
down.
Here is my general list of wants/needs:
1. Fast: 160 kts
2. Price range: $75K-$120K
3. Four Seater
4. Range: 800nm
5. Useful Payload (with full fuel); 650lbs
6. Retains its value well over time
7. Reliable: Engine TBO of 2000 hrs, good saftey record
8. Insurable for a pilot with only 350 hrs PIC experience (no
HP/complex
time)
I have been thinking about a Piper Comanche 260 and a Piper Turbo
Arrow
III/IV. I was considering a Mooney M20J, but they feel a little
cramped
in the cabin to me. What I am looking for is the best dollars/kts
airplane (what we call price/performance in the computer biz) that
meets
the above requirements. I would really appreciate suggestions and
advice.
-Sami
  #83
Old January 6th 04, 07:32 PM
Paul Sengupta
Well, best purchase price to speed...my guess would be a Hawker Hunter.
You can pick up a single seat variant for about £45k, and it goes mach 0.92.
Not sure what prices Gnats go for these days, but they do mach 0.98.
Both are trans-sonic in a dive.
Paul
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
be?st choices for new engine for P210? Phil Kellman Owning 3 November 7th 03 02:21 PM
Is taking off on single mag bad for engine flyer Home Built 10 September 21st 03 09:43 PM
