I would have also left the plane.
No reason to kill yourself over a minor inconvenience. More than inconvenience. A dead mag means the airplane is not legally airworthy, and flying it that way presents a whole range of threats, from a second mag failure through to insurance invalidation and to the loss of your license. Ok, I'm setting myself to get totally jumped on, but hey this thread is far too one sided to make a legitimate newsgroup thread. So I feel compelled to offer another perspective. First with regard to the "loss of your license" comment above, If you crashed as a result of your second magneto failing, I doubt you would admit to the FAA inspector or your insurance agent that the first mag failed before takeoff. (After all, if the first mag just failed on the previous flight, it would be just about as likely that it failed after takeoff of the flight in question.) Second, I think the "kill yourself" comment above is overly dramatic. You were trained what to do when an engine fails weren't you? And you do practice this I assume when you enter a traffic pattern that is totally devoid of other traffic or other complications prohibiting a power off landing? I've actually had to land without power once thru no fault of my own. It was even in Colorado, not exactly the most hospitable terrain in the country for forced landings, yet my plane and its occupants were just fine. If I was unlucky enough my plane would have been damaged, even totaled perhaps, yet I believe I could walk away from such an incident no matter when the engine decided to give up the ghost. (At night, my confidence is that would be dramatically reduced.) This little bit of flying bravado doesn't mean I seek out the situations demanding such skill. (The old expression about the superior pilot comes to mind ![]() I had the whole family loaded up ready to fly to Tahoe. During the run-up, one mag was completely dead. For one, I was planning on flying over some pretty rugged mountains. And then their would have been the same problem on the return. Also I had a perfectly functional car parked right there at the airport (although it did take us about 5 times longer to drive). However in other circumstances I might do it. For instance if I had to make it only 40 miles back to home base, and the terrain in between was hospitable, and the wx was good vfr, and of course it was daytime. I would take extra precautions - such as circling the field while climbing to give me an early out. I would try to choose a route and fly high enough to remain within gliding distance of an airport for as much of the flight as possible. (Actually after my return from Tahoe, I had no hesitation about flying it to my mechanics airport. It was only 15 miles away with two large airports directly enroute.) One has to be careful about the "no reason to take unnecessary risks" idea espoused by posters in this thread. The rub is in defining unnecessary. Some of my non-flying friends question my sanity for taking unnecessary risks for going out airport hopping on a perfectly fine windless CAVU day just after my most experienced and nitpicky mechanic has gone over everything with a fine tooth comb and pronounced the plane airworthy. Some of my heavy metal flying friends question my sanity for packing my family across the Sierras and the Rockies in an airplane with only one engine. And then when I mention that I also fly at night and in IFR wx, they say "with only one pilot, only one alternator, only one vacuum source, no anti-ice equipment, what are you nuts?" No I'm not nuts. Thousands of other pilots do it also. Its all what you are used to and how you balance the risks and the rewards. I always say that a pilot has to have the right mix of desire and fear. Not enough desire and too much fear and the pilot will not get experience because he will never go anywhere. Not enough fear and too much desire and he will not get experienced either since he will kill himself first. So to all those "certainly leave it on the ground" responders, don't you occasionally go biking even if those brakes are a little bit worn. And surely an errant truck driver could wipe you off the road with barely a 1 second mistake. And what about those pilots of the 1920's. Are you saying if you were born say a century ago, you wouldn't have been among that fun loving pilot crowd. If I remember right, they only had one magneto even when everything was working. Heck I don't think they even had the luxury of a throttle. (Of course their engines failed so often, for so many different reasons, that the extra safety from having two magnetos would have been insignificant ![]() My point is we all take risks. We just have to evaluate each one as objectively as possible taking in all the statistics we know and the relative rewards for taking the risk. And saying "and it's against the FARs" is a cop out too. I feel that the FARs are pretty much irrelevant in the decision making process. Certainly one should ponder why the FAA made this decision, yet as I tried to point out, everyone's risk/reward system is different. There are many things the FARs allow me to do that I will not. (One of many examples is that I'm allowed to take off in zero-zero conditions, which I feel is not worth the risk. Some fellow pilots will do this, but I do not denigrate their decision, since their piloting skills are different as well as their risk perceptions.) There are other things prohibited by the FARs that I feel perfectly comfortable with. I've taken off many times with equipment not working that was required by the type certificate (even the airspeed indicator once). Before I get the flood of irate responses from those of you who claim that you always fly legally, let me point out that FAA inspectors claim they can find something illegal with every aircraft if they look closely enough, and usually they don't have to look very close. I just hope too many FAA inspectors are not reading this newsgroup ![]() ~Paul |
I'm with you Paul, as far as saying the answer is not 100% clear. The
monday morning quarterbacks have all the easy answers. Mechanical troubles away from home can create real dilemmas. If it's only 40 miles, VFR, and there's an interstate highway to follow, I might do it if there was some disastrous consequence to not making it back on time. A 150 can be landed almost anywhere, even in an empty Wal Mart parking lot. But the original poster's own mechanic could also easily drive over with a new mag for not much additional expense, or the local mechanic could easily put one in or troubleshoot the bad one. I've had mag troubles away from my home field a couple times, and it's always been easily and quickly fixed. One time, it was that the points were burned after the capacitor wire had severed, and new points and a capacitor were all that were needed and on hand at the shop. A one hour delay. "Paul Mennen" wrote in message m... I would have also left the plane. No reason to kill yourself over a minor inconvenience. More than inconvenience. A dead mag means the airplane is not legally airworthy, and flying it that way presents a whole range of threats, from a second mag failure through to insurance invalidation and to the loss of your license. Ok, I'm setting myself to get totally jumped on, but hey this thread is far too one sided to make a legitimate newsgroup thread. So I feel compelled to offer another perspective. First with regard to the "loss of your license" comment above, If you crashed as a result of your second magneto failing, I doubt you would admit to the FAA inspector or your insurance agent that the first mag failed before takeoff. (After all, if the first mag just failed on the previous flight, it would be just about as likely that it failed after takeoff of the flight in question.) Second, I think the "kill yourself" comment above is overly dramatic. You were trained what to do when an engine fails weren't you? And you do practice this I assume when you enter a traffic pattern that is totally devoid of other traffic or other complications prohibiting a power off landing? I've actually had to land without power once thru no fault of my own. It was even in Colorado, not exactly the most hospitable terrain in the country for forced landings, yet my plane and its occupants were just fine. If I was unlucky enough my plane would have been damaged, even totaled perhaps, yet I believe I could walk away from such an incident no matter when the engine decided to give up the ghost. (At night, my confidence is that would be dramatically reduced.) This little bit of flying bravado doesn't mean I seek out the situations demanding such skill. (The old expression about the superior pilot comes to mind ![]() I had the whole family loaded up ready to fly to Tahoe. During the run-up, one mag was completely dead. For one, I was planning on flying over some pretty rugged mountains. And then their would have been the same problem on the return. Also I had a perfectly functional car parked right there at the airport (although it did take us about 5 times longer to drive). However in other circumstances I might do it. For instance if I had to make it only 40 miles back to home base, and the terrain in between was hospitable, and the wx was good vfr, and of course it was daytime. I would take extra precautions - such as circling the field while climbing to give me an early out. I would try to choose a route and fly high enough to remain within gliding distance of an airport for as much of the flight as possible. (Actually after my return from Tahoe, I had no hesitation about flying it to my mechanics airport. It was only 15 miles away with two large airports directly enroute.) One has to be careful about the "no reason to take unnecessary risks" idea espoused by posters in this thread. The rub is in defining unnecessary. Some of my non-flying friends question my sanity for taking unnecessary risks for going out airport hopping on a perfectly fine windless CAVU day just after my most experienced and nitpicky mechanic has gone over everything with a fine tooth comb and pronounced the plane airworthy. Some of my heavy metal flying friends question my sanity for packing my family across the Sierras and the Rockies in an airplane with only one engine. And then when I mention that I also fly at night and in IFR wx, they say "with only one pilot, only one alternator, only one vacuum source, no anti-ice equipment, what are you nuts?" No I'm not nuts. Thousands of other pilots do it also. Its all what you are used to and how you balance the risks and the rewards. I always say that a pilot has to have the right mix of desire and fear. Not enough desire and too much fear and the pilot will not get experience because he will never go anywhere. Not enough fear and too much desire and he will not get experienced either since he will kill himself first. So to all those "certainly leave it on the ground" responders, don't you occasionally go biking even if those brakes are a little bit worn. And surely an errant truck driver could wipe you off the road with barely a 1 second mistake. And what about those pilots of the 1920's. Are you saying if you were born say a century ago, you wouldn't have been among that fun loving pilot crowd. If I remember right, they only had one magneto even when everything was working. Heck I don't think they even had the luxury of a throttle. (Of course their engines failed so often, for so many different reasons, that the extra safety from having two magnetos would have been insignificant ![]() My point is we all take risks. We just have to evaluate each one as objectively as possible taking in all the statistics we know and the relative rewards for taking the risk. And saying "and it's against the FARs" is a cop out too. I feel that the FARs are pretty much irrelevant in the decision making process. Certainly one should ponder why the FAA made this decision, yet as I tried to point out, everyone's risk/reward system is different. There are many things the FARs allow me to do that I will not. (One of many examples is that I'm allowed to take off in zero-zero conditions, which I feel is not worth the risk. Some fellow pilots will do this, but I do not denigrate their decision, since their piloting skills are different as well as their risk perceptions.) There are other things prohibited by the FARs that I feel perfectly comfortable with. I've taken off many times with equipment not working that was required by the type certificate (even the airspeed indicator once). Before I get the flood of irate responses from those of you who claim that you always fly legally, let me point out that FAA inspectors claim they can find something illegal with every aircraft if they look closely enough, and usually they don't have to look very close. I just hope too many FAA inspectors are not reading this newsgroup ![]() ~Paul |
"Dan Thompson" wrote in message m...
I've had mag troubles away from my home field a couple times, and it's always been easily and quickly fixed. One time, it was that the points were burned after the capacitor wire had severed, and new points and a capacitor were all that were needed and on hand at the shop. A one hour delay. It failed because the capacitor wire broke, not because the points burned. There's a widespread misconception that the capacitor's only job is to prevent arcing at the points, but the mag will not spark at all if the capacitor is removed from the circuit. The capacitor's job is to intensify the secondary coil's output by speeding up the collapse of the magnetic field, and it does this by absorbing the bit of current that would otherwise arc across the points. Such arcing not only burns those points but also represents continuing current flow in the primary, just when we want an abrupt arresting of that flow to collapse the field. The capacitor absorbs current just long enough that the points can open far enough to prevent arcing after the capacitor is full. Of all the concepts that I teach in aircraft systems, the magneto is the one that students have the most difficulty understanding. Dan |
"Paul Mennen" wrote in message om...
I would have also left the plane. No reason to kill yourself over a minor inconvenience. More than inconvenience. A dead mag means the airplane is not legally airworthy, and flying it that way presents a whole range of threats, from a second mag failure through to insurance invalidation and to the loss of your license. Ok, I'm setting myself to get totally jumped on, but hey this thread is far too one sided to make a legitimate newsgroup thread. So I feel compelled to offer another perspective. I appreciate your alternative perspective, but if I don't have two mags, and I know that to be a fact, I ain't flying. It's just not worth it. I was talking to a friend recently who lost a mag on take off in a C-172. He was amazed at how much power he lost. He barely cleared the trees at the end of the runway and he felt sure that he was going to have to set down in the parking lot of the local community college which was about 3/4 mile straight ahead. He was able to get the plane to about 900 feet, but no more, so he was able to nurse it back to a landing. This guy is a very accomplished pilot (instrument, commercial) and it scared him. Freaked me a bit too because the plane is the plane that I rent most often. When he found out it was a lead wire that fell onto the block, effectively grounding out the mag, he was amazed. He was sure that it was something much more severe because it hampered his climb performance so much. Lots of times, you need 100% power to take off and climb, especially if you have obstacles, it's hot and high, etc. Think about it, would you ever take off with the throttle partially closed? You know, just for kicks? That's similar to what it's like to take off with a failed mag. -Trent PP-ASEL |
