Avoiding Shock Cooling in Quick Descent
Old January 7th 04, 08:30 AM
Jeff
I read an article that said that if you dont go below 20' MP pressure you
should be ok.
Personally, I reduce power enough where I can do a 500 fpm decent and stay
under the yellow, usually this puts me at about 140 kts IAS, but only if its
smooth air, if I need to stay below Va or if they are trying to slam dunk me
then I drop the landing gear, that and about 25' MP and 2300 rom will give
you around a 800 fpm decent, sometimes faster if you let it. But I try my
best to only do 500 fpm decents.
I was taught to pull power off at about 1' MP per minute.
BTW how is that new T-arrow of yours doing.
"O. Sami Saydjari" wrote:
My engine operating manual (for my Piper Turbo Arrow III) strongly
discourages pulling the power back and doing a quick descent -- it warns
of engine-killing shock cooling. Sounds reasonable to me...but it (and
my airplane manual) does not really seem to say how best to do a fast
descent when you have to.
I inferred that the right thing to do might be to lower the prop speed
to a minimum and ease back power as slowly as you can. Does that sound
about right? How quickly can one expect to pull the throttle back and
not risk shock cooling? If one must get down (say, for air traffic
control reasons, or perhaps because one is trying to take advantage of
favorable winds as long as possible), what is the best procedure. What
about slipping it down? Does that risk the engine or the airframe at
all? I've never done slips at cruise speeds (just on approach), so
please forgive me if this is a naive question.
-Sami
N2057M
Old January 8th 04, 12:51 AM
O. Sami Saydjari
Still undergoing an avionics upgrade (Garmin 430, GDL 49 weather uplink,
and GTX 330 transponder with TIS....pretty cool). Will be ready Friday
(I can't wait!!!). Flying it home 12 January (Reno to Central
Wisconsin)...Wish for good weather! If I end up taking a southerly
route, I will wave as I pass overhead
-Sami
N2057M
Old January 8th 04, 02:10 AM
Jeff
one other thing, dont lean the engine on take off or during climb.
Wait untill your at your cruise altitude to do any leaning.
and make sure you get the new power settings, the book settings no longer
apply since that intercooler was installed. If you fly it at book settings,
you will be running at a higher power setting and will burn up cylinders.
-Sami
N2057M
Old January 8th 04, 04:47 AM
Mike Rapoport
Is it at Aviation Classics?
Mike
MU-2
"O. Sami Saydjari" wrote in message
-Sami
N2057M
Old January 8th 04, 06:28 AM
O. Sami Saydjari
Yes, as a matter of fact it is. Do you want to stop by and check on it
for me? Just don't bug them...its a big job and they are trying to
get it done by Thursday night so they can do a certifying flight on
Friday
-Sami
Mike
MU-2
-Sami
N2057M
