On Fri, 09 Jan 2004 01:29:05 GMT, Robert Moore
wrote: And I thought that every private pilot was taught that an airplane can be stalled at any airspeed and any attitude. I assure you that I, or a gust of sufficient value can stall your SR20 at 120 kts. By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. I suspect that would fall in the category of sever turbulence and I don't think there is any airspeed that would be safe under those conditions in a single engine normal category aircraft. In any case a stall at cruise altitude should not be a problem but parts (like the engine or the wings) falling off the aircraft would be. |
ArtP wrote
By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. That's not the type of gust being discussed, try "vertical" gust. Bob Moore |
On Fri, 09 Jan 2004 02:03:13 GMT, Robert Moore
wrote: ArtP wrote By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. That's not the type of gust being discussed, try "vertical" gust. Since the maximum vertical gust that the plane is designed to handle is 30 knots (3000 feet per second) based upon a 30 kt vector and a 120 kt vector by my calculations the maximum change in the AOA before reaching the design limit of the plane should be 14 degrees. An upward gust would increase the AOA but that would also cause a rapid increase in altitude which would be naturally corrected by a decrease in AOA (even if on auto pilot). A downward gust would similarly be corrected by trying to regain altitude. At cruise altitude in a small plane neither of these should be particularly exciting as long as you don't bounce off the ceiling too hard, something that is less likely at Va than at a higher speed. |
ArtP wrote:
By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. Arrrgghhhh! No, that's not what's going on at all. You stall when you exceed the critial angle of attack. One way to do that is to slowly reduce airspeed under 1g conditions (i.e. straight and level flight in non-turbulent air) until you reach Vs. At Vs and 1g, the wing has to be operating at the critical AOA to generate lift equal to the plane's weight, so you stall. This is your standard private pilot power-off stall demo. But, there are many other ways to reach critical AOA. One way is to instantaneously change the direction the relative wind is coming from. Let's say you're in straight and level flight at 120 KTAS. That's just about 200 ft/s (feet per second). I'm going to pull two plausable numbers out of my butt for the sake of argument: 1) At 120 KTAS, 1g, and whatever you weigh at the moment, the wing is operating at an AOA of 5 degrees. 2) The critial AOA for your wing is 18 degrees. The relative wind is coming from straight ahead and the wing is tilted up at an angle of 5 degrees from the horizontal. This gives you your 5 degree AOA. NOTE: this doesn't mean your nose is pitched up 5 degrees, because the wing has a built-in angle of incidence, i.e. the chord line of the wing is not parallel with the longitudinal axis of the plane. Now, let's say you hit a vertical gust of 50 ft/s. That means the relative wind is now 200 ft/sec straight back plus 50 ft/sec up. If I did my vector sums right, that means it's now 206 ft/sec coming from an angle of 14 degrees below the horizontal. Since your wing is tilted up at 5 degrees, the AOA is suddenly 5 + 14 = 19 degrees, which is greater than the critical AOA. Presto, you are suddenly stalled! If the gust were just a little bit weaker, you would only reach an AOA of, say, 17 degrees. This is below the critcial AOA so you're not stalled. But, the AOA has suddenly gone up by a factor of 3.4. Since you're still going at the same airspeed (actually, a little bit more, 206 instead of 200 ft/s), you're suddenly generating 3.4 times as much lift, and you will find yourself being accelerated upward at 3.4 g's, which is enough to make your socks droop down around your ankles. Well endowed men or women will be wishing they had worn more supportive underwear about now. But, since your wings were probably designed to withstand 3.8 g's (plus 150% safety factor), they should stay on and not even get bent or wrinkled. Here's the mantra; repeat after me: "Stall is when you exceed the critial AOA. You can do this in any flight attitude, at any airspeed" |
ArtP wrote:
By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. Wings don't stall because of a lack of airspeed. Hilton |
Druine Turbulent | Stealth Pilot | Home Built | 0 | August 30th 04 05:05 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
