On Fri, 09 Jan 2004 02:03:13 GMT, Robert Moore
wrote: ArtP wrote By my calculations, if I am flying in cruise it would take a tail wind gust of 56 knots to stall me. That's not the type of gust being discussed, try "vertical" gust. Since the maximum vertical gust that the plane is designed to handle is 30 knots (3000 feet per second) based upon a 30 kt vector and a 120 kt vector by my calculations the maximum change in the AOA before reaching the design limit of the plane should be 14 degrees. An upward gust would increase the AOA but that would also cause a rapid increase in altitude which would be naturally corrected by a decrease in AOA (even if on auto pilot). A downward gust would similarly be corrected by trying to regain altitude. At cruise altitude in a small plane neither of these should be particularly exciting as long as you don't bounce off the ceiling too hard, something that is less likely at Va than at a higher speed. |
Druine Turbulent | Stealth Pilot | Home Built | 0 | August 30th 04 05:05 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
