"Dan Thomas" wrote in message
om... "Gary Drescher" wrote in message news:bnzLb.6520$8H.20195@attbi_s03... "Dave S" wrote in message . net... Now... a question about realities.. The POH nazi's will say that the Word as written is good, praise be to the POH... if I base flight decisions and speeds on MY calculated numbers rather than the max weight sea level standard day numbers published in the almighty POH.. am I going to be asking for trouble here? It depends on what you mean by 'trouble'. The laws of physics prevail over the POH in determining whether your engine mount will break... Why do folks worry about engine mounts breaking? They are far stronger, in most cases, than the rest of the structure. For production airplanes, the legal standards for certification include a 9G strength for fuselage/cabin structure for crashworthiness, and I have seen other specs calling for the same 9Gs specifically on engine mounts. Are those regulatory specs? In any case, it's just an example. The crucial point is that Va is a speed that limits the _acceleration_ that the control surfaces can impose before the plane stalls, whereas Vno is a speed that limits the _force_ that the wings can develop before the plane stalls. Therefore, staying below Vno is what keeps the wings attached and intact, whereas staying below Va is what keeps _other_ parts of the plane attached and intact (because the plane's acceleration determines the force exterted upon other structures). This distinction is key to understanding why Va is proportionate to the square root of weight, whereas Vno is independent of weight. (Whether or not the engine mounts are the weak link in the rest of the plane presumably varies from one aircraft to another.) --Gary Dan |
"Gary Drescher" wrote in message news:wKGLb.9047$8H.23200@attbi_s03...
"Dan Thomas" wrote in message om... "Gary Drescher" wrote in message news:bnzLb.6520$8H.20195@attbi_s03... "Dave S" wrote in message . net... Now... a question about realities.. The POH nazi's will say that the Word as written is good, praise be to the POH... if I base flight decisions and speeds on MY calculated numbers rather than the max weight sea level standard day numbers published in the almighty POH.. am I going to be asking for trouble here? It depends on what you mean by 'trouble'. The laws of physics prevail over the POH in determining whether your engine mount will break... Why do folks worry about engine mounts breaking? They are far stronger, in most cases, than the rest of the structure. For production airplanes, the legal standards for certification include a 9G strength for fuselage/cabin structure for crashworthiness, and I have seen other specs calling for the same 9Gs specifically on engine mounts. Are those regulatory specs? Yes, they are. being a Canadian, I can quote the CARs but the FARs are a different matter. I'l see what they have to say. In any case, when have you ever heard of an engine departing an airplane in turbulence or during violent maneuvering? Our Citabria has a G-meter in it, and we have seen some pretty big numbers when students get clumsy on landing. Landing forces don't affect wings much, since they're still generating lift and the landing forces on the structure tend to be negative, and if the engine mount was a 5G structure like the rest of the airplane it would have fallen off long ago. A missing 300 pounds or so during a hard landing would be disastrous: CG way back near the trailing edge, an airplane suddenly much lighter, and airspeed still sufficient to flip the whole works over into a crash and burn scenario, all for the lack of another pound or so of tubing. The only times I have heard of engine mounts failing on light airplanes is when a prop throws part of a blade, or maybe the whole blade on a constant-speed prop. The imbalance is more than enough to rip the engine off the airplane. Blades will fail when propeller nicks are left untreated and cracks develop. The prop is the most highly stressed bit of metal on the whole airplane, and THAT'S what pilots should be concerned about, not engine mounts. Dan |
om... The only times I have heard of engine mounts failing on light airplanes is when a prop throws part of a blade, or maybe the whole blade on a constant-speed prop. The imbalance is more than enough to rip the engine off the airplane. Blades will fail when propeller nicks are left untreated and cracks develop. The prop is the most highly stressed bit of metal on the whole airplane, and THAT'S what pilots should be concerned about, not engine mounts. Nah. Properly designed engine mounts would never let that happen. |
"Tony Cox" wrote in message link.net...
"Dan Thomas" wrote in message om... The only times I have heard of engine mounts failing on light airplanes is when a prop throws part of a blade, or maybe the whole blade on a constant-speed prop. The imbalance is more than enough to rip the engine off the airplane. Blades will fail when propeller nicks are left untreated and cracks develop. The prop is the most highly stressed bit of metal on the whole airplane, and THAT'S what pilots should be concerned about, not engine mounts. Nah. Properly designed engine mounts would never let that happen. Cessna 185 operated by JAARS Inc, South America, about ten years ago. Threw a blade and the engine tore off the mount before the pilot could shut it down. It turned sideways in the cowl, and the cowl was the only thing keeping it from departing entirely. The O-520 mount is a bed mount; if it had been the usual rear mounting the engine would have fallen off. Dan |
*****The O-520 mount is a
bed mount; if it had been the usual rear mounting the engine would have fallen off.**** No, it isn't a bed mount in a Cessna 185. The mount attaches to fourpoints on the firewall. A cessna 206, however, has a bed mount. Karl "curator" N185KG |
"karl" wrote in message ...
*****The O-520 mount is a bed mount; if it had been the usual rear mounting the engine would have fallen off.**** No, it isn't a bed mount in a Cessna 185. The mount attaches to fourpoints on the firewall. A cessna 206, however, has a bed mount. Karl "curator" N185KG The mount attaches to the firewall, but extends underneath the engine and attaches to four mounts on the *bottom* of the case. These are the mounts that failed, not the tubing. The engine in question was resting on that structure when the noise was finished. |
om... "Tony Cox" wrote in message link.net... "Dan Thomas" wrote in message om... The only times I have heard of engine mounts failing on light airplanes is when a prop throws part of a blade, or maybe the whole blade on a constant-speed prop. The imbalance is more than enough to rip the engine off the airplane. Blades will fail when propeller nicks are left untreated and cracks develop. The prop is the most highly stressed bit of metal on the whole airplane, and THAT'S what pilots should be concerned about, not engine mounts. Nah. Properly designed engine mounts would never let that happen. Cessna 185 operated by JAARS Inc, South America, about ten years ago. Threw a blade and the engine tore off the mount before the pilot could shut it down. It turned sideways in the cowl, and the cowl was the only thing keeping it from departing entirely. The O-520 mount is a bed mount; if it had been the usual rear mounting the engine would have fallen off. What's a bed mount, Dan? I've always thought (hoped) that my 182 cowling would contain the engine. And there is always the fuel line, throttle cable, and battery cable as a last line of defense ![]() |
"Tony Cox" wrote in message ink.net...
"Dan Thomas" wrote in message om... "Tony Cox" wrote in message link.net... "Dan Thomas" wrote in message om... The only times I have heard of engine mounts failing on light airplanes is when a prop throws part of a blade, or maybe the whole blade on a constant-speed prop. The imbalance is more than enough to rip the engine off the airplane. Blades will fail when propeller nicks are left untreated and cracks develop. The prop is the most highly stressed bit of metal on the whole airplane, and THAT'S what pilots should be concerned about, not engine mounts. Nah. Properly designed engine mounts would never let that happen. Cessna 185 operated by JAARS Inc, South America, about ten years ago. Threw a blade and the engine tore off the mount before the pilot could shut it down. It turned sideways in the cowl, and the cowl was the only thing keeping it from departing entirely. The O-520 mount is a bed mount; if it had been the usual rear mounting the engine would have fallen off. What's a bed mount, Dan? I've always thought (hoped) that my 182 cowling would contain the engine. And there is always the fuel line, throttle cable, and battery cable as a last line of defense ![]() I couldn't trust a few wires and cables to keep the weight of the engine attached to the firewall. I spoke with a former 747 pilot who was into Formula 1 racing. He had a single-seat (Cassutt?) racer that used an O-200 turning a tiny prop at 4400 RPM to get the flat-out speed he wanted. I asked him about the prop failure/engine departure scenario, and he told me that he (and his buddies, in their airplanes) had a stout cable wrapped around the engine and bolted to the firewall to cover this eventuality. Apparently it had happened more than once before to other unfortunate racers. Dan |
Druine Turbulent | Stealth Pilot | Home Built | 0 | August 30th 04 05:05 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
