Tiny vacuum pump
Old January 16th 04, 04:46 PM
Ron Natalie
"Jim Weir" wrote in message ...
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
110, but I can rig up a 12 volt supply if necessary.
Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
as long as it's narrower than the roll of "bag stock." I've got one in the kitchen.
If that's too pricey for you, then there's always this one $14.94, not sold in stores....
http://www.pump-n-seal.com/
Old January 16th 04, 05:26 PM
Jim Weir
Because Foodsaver requires you to use their special bags. Besides being WAY
overpriced, the bags ain't cheap either. Yeah I knew about pump'n'seal, but
that seems to be a kluge way of doing it. I was looking for elegant.
"Ron Natalie"
-Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
-vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
-as long as it's narrower than the roll of "bag stock." I've got one in the
kitchen.
-If that's too pricey for you, then there's always this one $14.94, not sold in
stores....
-http://www.pump-n-seal.com/
http://www.rst-engr.com
Old January 16th 04, 10:52 PM
Blueskies
The foodsaver thing we have has a fitting for a small hose that you can hook up to whatever you want - would be just
right for what you are doing...
Dan D.
"Ron Natalie"
kitchen.
stores....
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 05:42 AM
Battery and Vacuum pump PaulaJay1 Owning 3 January 16th 04 04:22 PM
