Tiny vacuum pump
Old January 16th 04, 05:25 PM
Jim Weir
Because the pump has to fit on a bench that is already overcrowded. If I was
going to use a shopvac, btw, it would be with a pvc waterpipe fitting glued to a
barbed fitting with plastic tubing. I thought of that and then the hassle for
each part of reaching down to turn the vacuum on for each part you want to seal.
-If it is just the suck that has to be tiny and not the pump, how about
-a toilet paper roll and some duct tape to make an adapter to your shop
-vac?
http://www.rst-engr.com
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Tiny vacuum pump Jim Weir Home Built 41 January 24th 04 05:42 AM
Battery and Vacuum pump PaulaJay1 Owning 3 January 16th 04 04:22 PM
