I think you either made a math error or mis-typed. 88 gallons of fuel is 520 lbs, so if the useful
load is 1400 lbs, then that leaves 880 lbs payload, not 1065. Maybe you meant adding the flint tanks gives you an additional 200 lbs useful load, and if you leave them empty it gets you close to that 1065 lbs. 1065 is only 15 lbs more than I get with my more or less stock Six, although I can only dream of 150+ kts. What kind of fuel burn do you get at that speed? Mike Long wrote: Marval wrote in message ... Can anyone help me out? trying to find a 6 place airplane that can truly carry it's load, single engine. looking for a payload of at least 1000 pounds with full of fuel. *** Sent via http://www.automationtools.com *** Add a newsgroup interface to your website today. A 206H has just under 1400 lbs useful. If you add Flint Tip Tanks, it will be 200 lbs additional if you don't put fuel in them. So, roughly, that leaves 1065 lbs payload with 88 gallons. With small gear, 156-158 kts. Mike -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Ray Andraka wrote in message ...
I think you either made a math error or mis-typed. 88 gallons of fuel is 520 lbs, so if the useful load is 1400 lbs, then that leaves 880 lbs payload, not 1065. Maybe you meant adding the flint tanks gives you an additional 200 lbs useful load, and if you leave them empty it gets you close to that 1065 lbs. 1065 is only 15 lbs more than I get with my more or less stock Six, although I can only dream of 150+ kts. What kind of fuel burn do you get at that speed? Mike Long wrote: Yes, I meant to imply the 1065 came with the addition of Flint Tanks but with no fuel in them - only the 88 gallons standard. The Flint's add 200 lbs to the gross weight. 15-16 gallons is the norm and the small gear seems to make the airplane faster by more than I would have thought. Mike |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
