Buying a used COMM
Old January 24th 04, 01:53 AM
Jim Weir
Which is the theoretical length of an infinitely small diameter wire antenna.
For antennas made out of REAL materials (like brass welding rod) you wind up
with a Finagle Factor that approximates somewhere between 90 and 95% for rod
between 1/8" and 1/4". In general, I recommend somewhere around 22.5 inches for
the bottom end of the band (around 120 MHz.) or so, and an inch shorter for the
dead center of the band at 127.5 MHz.
-Therefore Lamda = 3 / 1.2 = 2.5 meters. Therefore
-1/4 wavelength would be 0.625 meters or around 24.4 inches.
-Keep in mind, though, I'm just a dumb airshow pilot -
-check with Jim about this. He builds these in his sleep
-from welding rod.
http://www.rst-engr.com
Tips on buying a cessna 182 Matteucci Aviation Marketplace 4 September 15th 04 08:42 AM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill General Aviation 0 December 11th 03 09:42 PM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Instrument Flight Rules 0 September 4th 03 04:41 AM
