Garmin 340 Audio Panel Split Com
Old January 24th 04, 03:54 AM
O. Sami Saydjari
Default Garmin 340 Audio Panel Split Com
Does anyone out there have experience with Garmin's 340 audio panel and
its feature that lets you split the Com 1 and Com 2 so that the pilot
can talk/receive on one while the co-pilot can talk and receive on a
separate frequency on another? It is called the "Com 1/2" button.
On my installation, the co-pilot experienced that Com 2 reception was
blocked with I was talking on Com 1. That is not how it is supposed to
work. I have been told by one avionics shop that it is difficult to not
have Com1/Com2 interference and that I should just write-off this
feature. Another shop said that the Com 1 and Com 2 antenna's had to be
relocated so that they were on opposite sides of the plane (one op top
and one on bottom). I am not sure what to believe at this point. Any
advice or experience that folks have had would be appreciated.
-Sami
N2057M Piper Turbo Arrow III
Old January 24th 04, 06:22 AM
Nathan Young
On Fri, 23 Jan 2004 21:54:40 -0600, "O. Sami Saydjari"
I'm not an avionics expert, but if the COM1 and COM2 antennas are near
each other (which they generally are on a GA plane), the COM2 antenna
is going to be receiving a ton of energy (relatively speaking) when
the COM1 radio transmits. Even if this energy is on a different
frequency (ex. COM1 on 120.55, COM2 on 124.8) the channel selection
fillters will not be able to supress the transmit energy from COM1.
I've always wondered how aviation radios deal with this. I suspect
they have some sort of level detector on the output of the 1st
(receiver) amplifier stage which shuts off the input if it reaches a
threshold.
If so - this would explain why your COM2 receive cuts out when COM1
transmits.
Well, enough speculation. Perhaps someone who actually knows how the
radios work will respond.
-Nathan
Old January 24th 04, 10:01 AM
Thomas Borchert
O.,
and one on bottom).
We have been told the same thing. Our antennas are both on top and we have
similar problems.
Thomas Borchert (EDDH)
Old January 24th 04, 11:52 AM
Mark Manes
I just had a Garmin 340 audio panel installed in my 310. The avionics shop
said that there would be interference between the two if the coms were split
and suggested not enabling that feature. I took their suggestion. I am
very pleased with the audio panel but that would have been a nice feature.
"O. Sami Saydjari" wrote in message
-Sami
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.562 / Virus Database: 354 - Release Date: 1/16/2004
Old January 24th 04, 03:13 PM
jerryk
-Sami
I have a 340 AP and use the COM1/COM2 switch. We have had no problems.
But, the COM1 antenna is in the tail and the COM 2 antenna is on the belly.
jerry
Old January 24th 04, 04:15 PM
Richard Hertz
I assumed mine was working fine as I have used the "split" feature often.
However, I have never transmitted while the other person was on the number
2 - I will be sure to check it out next time I have a second person in the
plane.
-Sami
Old January 24th 04, 05:42 PM
MikeM
Like Nathan said!
To be able to receive on one while transmitting on the other
requires much technical effort, including separating antennas,
and installing filters/cavities/duplexors in the antenna leads
to the two radios. Not practical in an aircraft, unless it is
a C130.
Mikem
threshold.
transmits.
-Nathan
Old January 24th 04, 09:09 PM
Jack McAdams
My 340 does the same thing if the frequencies are close together. I
can't say what the spread needs to be but have noticed that if they
are close the odds of blocking are more pronounced.
Jack
Sundowner - N6363U
"O. Sami Saydjari" wrote in message ...
-Sami
Old January 26th 04, 07:55 AM
threshold.
transmits.
You've pretty much nailed it, Nathan. However, the problem is not in the
"channel selection filters" as you call them. Channel selectivity is
achieved with filters at the "intermediate frequency" or "IF" stages.
Before the received signal gets to that point it must be amplified by the RF
preamplifier and frequency-shifted in the first mixer. Both of these stages
have a limited "dynamic range", which means that they cannot pass a
relatively weak signal (as in one from a ground station) in the presence of
a vastly stronger one (as in one emanating from another nearby com antenna
on the same airframe).
-Elliott Drucker
Old January 27th 04, 08:55 PM
Marco Leon
My installation works as designed. The avionics shop separated the two
antennas--Com1(GNS430) on top of the fuselage and Com2 (KX-170B) on the
bottom. He said that I could have had them on the same antenna but if I
remember correctly, he said I would have had interference between the two
coms.
It IS a very cool feature that I've used often. However, most are with the
copilot just listening to ATIS and very few with the copilot talking
simultaneously with the pilot. These are usually reporting PIREPs or
speaking with other aircraft.
Marco
-Sami
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
RST Audio Panel Legality [email protected] Home Built 13 January 16th 05 10:39 PM
FS KMA20 TSO Audio Panel with Marker Beacon Maik Aviation Marketplace 0 March 18th 04 04:59 PM
FS: KMA20 TSO Audio Panel Maik Aviation Marketplace 0 February 25th 04 07:52 PM
Audio Panel Recommendations Jay Honeck Owning 36 January 28th 04 03:09 PM
Garmin audio panel question Brinks Owning 1 September 10th 03 08:41 PM
