Roy Smith wrote:
My club wants to equip all our planes with jacks so people can plug their handhelds into an external antenna in case the panel radios fail. In the past, what we've done is had a length of coax run into the cockpit with a BNC connector crimped onto it. The problem there is it tends to get kicked around, the connector gets smashed, etc. When you need it, it's not usable. One alternative I've thought of is to have the antenna cable run to a BNC jack on the panel. The problem with that idea is then you need a length of cable to go from the jack to your radio, which will in turn get lost, smashed up, etc. Has anybody come up with a good solution to this problem? Have each member carry and be responsible for their own cable, and maybe they'll take better care of them 8-) FWIW, I have used a lot of "crimp on" BNC connectors on Ethernet cables, and if moved or handled a lot, the shield braid usually breaks right at the connector. Adding a piece of heat shrink tubing as a strain relief improves their longevity quite a bit. |
Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 06:59 PM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
External GPS Antenna | Jim Weir | Owning | 0 | November 29th 03 04:12 AM |
External GPS Antenna | Jim Weir | Aviation Marketplace | 0 | November 29th 03 04:10 AM |
