Tiny vacuum pump
Old January 22nd 04, 12:24 AM
GeorgeB
On Wed, 21 Jan 2004 03:08:30 GMT, "Greg Milligan"
Check Fisher Scientific under "aspirator".
yes, https://www1.fishersci.com/Coupon?gid=109471&cid=1328 looks
exactly like what I remember. The $63.24 looks about 10x what I think
it would be worth to Jim ... is there a yellow tag?
"GeorgeB" wrote in message
On Fri, 16 Jan 2004 08:41:07 -0800, Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on the
order
of an aquarium pump or so that will draw just a few inches of water?
Preferably
110, but I can rig up a 12 volt supply if necessary.
Thoughts?
When I was in college, the chem labs used a venturi on water faucets
to create a vacuum for filtration. I've tried Google to show where to
get them, and failed.
Just a little attachment with a side barbed fitting ... good vacuum
levels, CHEAP, and appropriate for one who utilizes Bernoulli in other
ways ...
now where do I get it?
Old January 24th 04, 05:42 AM
Wright1902Glider
If you've got shop air, try looking for either a Vac Cubes or Piab venturi-type
vac injector. Both companies make some that are under 1" sq. and are used to
pick up post cards, tec. on factory machines. Should be in the $20 range.
You'll probably find them in your area at an industrial pneumatics supplier.
Harry
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
