As hokey as it sounds, my first criteria is the condition of the shop floor.
The shop which does my work has two hangars both with pristine white floors. The shops I didn't choose have dirty unpainted floors. I believe there's a correlation between clean/neat facilities and competent work, but maybe I'm just fooling myself. I also reviewed the comments on airnav. It's sometimes hard to tell a shill from a real customer but I found the comments to be fairly accurate. And once you find a shop, post it here, you'll likely find someone who's been there before. You can also ask other owners at your home base. Most are fairly candid about such things. When I made my choice, I was lucky enough to do a trial with some simple maintenance (if something major breaks you may not have this option): I got an oil change and a strut refilled, and also talked to the mechanic about some plug fouling issues. My chat with the mechanic convinced me that this was a competent individual whom I could rely on in the long term. To be honest, though, I don't think you can really know until your first annual, which is a sort of test of how thorough your mechanic is. Finally, I resolved to become more knowledgable about my aircraft. I joined a type club, acquired the parts and maintenance manuals, and did some independent research each time I had a squawk. I suggest you do the same, regardless of where you get your maintenance done. You'll feel much better if you can do some high-level problem determination on your own and compare with what the shop wants to do to the plane. A type club is also great for guessing where your next problem might be, and provides some hints as to what your mechanic should be looking for. best of luck, mark "O. Sami Saydjari" wrote in message ... OK, I have a controversial question. How does one find a good A&P mechanic. I just bought a Piper Turbo Arrow III recently and I want to find a mechanic in my area (Central Wisconsin) that I can trust and is competent. I am interested in hearing about how folks find the good A&Ps out there, other than by pure luck. I have had a couple of disappointing experiences with A&Ps where they missed some pretty significant problems. I found one through word of mouth. The other, well, I found the closest Piper Service Center near me (figuring that they had special knowledge and expertise with Pipers -- turned out to not be so). -Sami |
![]() Mark Astley wrote: As hokey as it sounds, my first criteria is the condition of the shop floor. The shop which does my work has two hangars both with pristine white floors. The shops I didn't choose have dirty unpainted floors. I believe there's a correlation between clean/neat facilities and competent work, but maybe I'm just fooling myself. You are fooling yourself. This sounds more like a personal comfort issue. There is an FBO with a fairly large Maintenance shop with pristine floors and a lousy reputation. They look good but there quality of service is lousy. They are also the most expensive in the area. Guess that must be the time they spend cleaning the floor. An A&P I used to work for could not keep the place clean if they wanted to. THey were too busy fixing airplanes. When the airport had issues after 9/11, the Shop moved outside the ADIZ and many of the based aircraft went with the shop. Now that's loyalty! Michelle -- Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P "Elisabeth" a Maule M-7-235B (no two are alike) Volunteer Pilot, Angel Flight Mid-Atlantic Volunteer Builder, Habitat for Humanity |
![]() I also reviewed the comments on airnav. It's sometimes hard to tell a shill from a real customer but I found the comments to be fairly accurate. And once you find a shop, post it here, you'll likely find someone who's been there before. You can also ask other owners at your home base. Most are fairly candid about such things. I have found the airnav comments to be nearly useless. Almost all of them relate to the FBO ramp service and whether the receptionist greeted them with a smile or not. I have seen precious few on the competence of the A&Ps. Also, I think people are reluctant to make negative postings. It is hard to tell the difference between true incompetence and an honest mistake. Who wants to trash someone's business so publically on the basis of one experience? I know I am reluctant to make negative postings even though I have had three negative experiences. When I made my choice, I was lucky enough to do a trial with some simple maintenance (if something major breaks you may not have this option): I got an oil change and a strut refilled, and also talked to the mechanic about some plug fouling issues. My chat with the mechanic convinced me that this was a competent individual whom I could rely on in the long term. To be honest, though, I don't think you can really know until your first annual, which is a sort of test of how thorough your mechanic is. Well, unfortunately, I am not knowledgable enough yet to really tell the difference between someone who sounds like they know what they are talking about and someone who actually does. I am learning, but it is not a quick road to travel. Finally, I resolved to become more knowledgable about my aircraft. I joined a type club, acquired the parts and maintenance manuals, and did some independent research each time I had a squawk. I suggest you do the same, regardless of where you get your maintenance done. You'll feel much better if you can do some high-level problem determination on your own and compare with what the shop wants to do to the plane. A type club is also great for guessing where your next problem might be, and provides some hints as to what your mechanic should be looking for. Yes, good suggestion. This newsgroup is very helpful in that regard. I have also joined the Piper type club. Everytime I learn more, I become even more disappointed in the service I have had. best of luck, mark "O. Sami Saydjari" wrote in message ... OK, I have a controversial question. How does one find a good A&P mechanic. I just bought a Piper Turbo Arrow III recently and I want to find a mechanic in my area (Central Wisconsin) that I can trust and is competent. I am interested in hearing about how folks find the good A&Ps out there, other than by pure luck. I have had a couple of disappointing experiences with A&Ps where they missed some pretty significant problems. I found one through word of mouth. The other, well, I found the closest Piper Service Center near me (figuring that they had special knowledge and expertise with Pipers -- turned out to not be so). -Sami |
![]() Mark Astley wrote: As hokey as it sounds, my first criteria is the condition of the shop floor. The shop which does my work has two hangars both with pristine white floors. The shops I didn't choose have dirty unpainted floors. It doesn't just sound hokey, it is hokey. I believe there's a correlation between clean/neat facilities and competent work, There ain't. |
![]() Mark Astley wrote: I believe there's a correlation between clean/neat facilities and competent work, but maybe I'm just fooling myself. I have found that to be not the case, but I have found a direct relationship between neatly painted floors and the size of the final bill. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
Me too on the other hand my last annual was at a dirty shop int the country.
A cylinder needed to be repaired. The invoice claimed 9 hours and thirty minutes to remove and replace it! Theft or incompetence is alive and well everywhere. -- John Purner Editor - The $100 Hamburger http://www.100dollarhamburger.com "G.R. Patterson III" wrote in message ... Mark Astley wrote: I believe there's a correlation between clean/neat facilities and competent work, but maybe I'm just fooling myself. I have found that to be not the case, but I have found a direct relationship between neatly painted floors and the size of the final bill. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
In article , G.R. Patterson III wrote:
I have found that to be not the case, but I have found a direct relationship between neatly painted floors and the size of the final bill. The one time in my life I took my plane to a place with spotless floors, I was 800 miles from home when a magneto decided to no longer be attached to the crankcase. I didn't have a gasket or a timing tool with me, so I had to take it to a shop (Southern Jet Center in Raleigh). They replaced the gasket, timed both mags, cleaned the engine, and had me on the road again in an hour. For $100. I've always been wary of clear-floor shops, but there are good ones out there that charge a fair price. Of course, by the time the 6 quarts of oil that were spread all over my belly dripped off, their floor wasn't quite so clean. ![]() Tina Marie -- http://www.tripacerdriver.com "...One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." (Robert Firth) |
floor. The shop which does my work has two hangars both with pristine white floors. The shops I didn't choose have dirty unpainted floors. I believe there's a correlation between clean/neat facilities and competent work, but maybe I'm just fooling myself. I felt the same way, but soon found that the "clean white floors" were also considerably more expensive. They were the corporate shop, that "punched in" on your plane at 8 AM, and "punched out" at 5 PM -- regardless of progress or results. My current mechanic is a long-term EAA and AAA (Antique Aircraft Association) member who works a full-time job (a chief mechanic for Airborne Express) as well as running his own shop, and is building his own plane between jobs. (When? God only knows....) As a result, there is usually some major sub-section being worked on, with all the associated clutter and fuss scattered about. This bothered me, at first, till I found out that Keith did twice the work in half the time of the "white floor" shop. With better results, too. So, it's a good rule -- but not universally applicable to all A&Ps. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Free Volksplane to good home, located in Chino Hills CA | Bryan Zinn | Home Built | 3 | July 18th 04 02:55 AM |
looking for good brake master cyls for homebuilt. | clare @ snyder.on .ca | Aviation Marketplace | 0 | March 28th 04 05:13 AM |
New novel and it's a good one | Lone Eagle | Military Aviation | 7 | October 2nd 03 04:13 AM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
Commander gives Navy airframe plan good review | Otis Willie | Military Aviation | 0 | July 8th 03 09:10 PM |
