taxi in reverse?
Old February 5th 04, 12:14 PM
arcwi
What one should use is to replace the front weel hub wtih a hub-motor
http://www.goldenmotor.com/ .
I am sure that this would not add that much weight and if the hub-motor is
selected corectly, the original tyre used, one could not distinguish it form
original.
Now, I wander if this could be installed on a certified aicraft with some
field approval as a minor modification...
"James M. Knox" wrote in message
(Malcolm Teas) wrote in
om:
I always figured if I was building a homebuilt I would investigate
some relatively small motor/brake assemblies that are used on smaller
electric automobiles.
My first thought when reading this was, "sounds cool!". And I started
to think it through.
All true. Of course, I was thinking primarily in terms of taxiing only a
short distance - into or out of a hangar, for example. I haven't done the
brake calculations, but I *think* (back of the hand calculations) that the
amount of power generated stopping the plane on the runway and taxiing in
is small enough that even a "fully charged" battery can easily absorb it.
Mostly just amusing and idle speculation... But I've seen some cold rainy
days when it would sure be nice to preflight in the hangar, climb in, and
just drive out. G
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old February 6th 04, 03:08 AM
Ernest Christley
original.
The largest one is 500W, a little less than 1Hp. (Is that right?) Just
barely enough power to push a light aircraft out of the hanger? Now how
much does it weigh (along with the 500W voltage converter to go from 12
to 36V)?
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Reverse scoop Paul Lee Home Built 9 April 13th 04 01:58 AM
taxi in reverse? Malcolm Teas Home Built 10 February 21st 04 12:26 AM
Pilot log book and taxi testing Bob Olds Home Built 1 February 11th 04 03:32 PM
Reverse NACA duct Chris W Home Built 22 October 28th 03 10:59 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
