"Grandpa B." never.mind wrote in message
... Greetings, all. I'm restoring a Champ, and have a question about driving screws into a drilled 4130 tube. If I drill the proper sized hole, the screws refuse to 'take'; they simply give up their threads to the harder metal of the tube. If I over-size the hole, then the screw won't hold diddley (that's a technical term). Are you tapping the holes? As in, with a tap and die set (preferably that is made for working on 4130). |
![]() "Jim Carriere" wrote in message ... "Grandpa B." never.mind wrote in message ... Greetings, all. I'm restoring a Champ, and have a question about driving screws into a drilled 4130 tube. If I drill the proper sized hole, the screws refuse to 'take'; they simply give up their threads to the harder metal of the tube. If I over-size the hole, then the screw won't hold diddley (that's a technical term). Are you tapping the holes? As in, with a tap and die set (preferably that is made for working on 4130). Where did he get the screws and what kind are they? |
On Fri, 23 Jan 2004 12:05:08 -0500, "Jim Carriere"
wrote: "Grandpa B." never.mind wrote in message ... Greetings, all. I'm restoring a Champ, and have a question about driving screws into a drilled 4130 tube. If I drill the proper sized hole, the screws refuse to 'take'; they simply give up their threads to the harder metal of the tube. If I over-size the hole, then the screw won't hold diddley (that's a technical term). Are you tapping the holes? As in, with a tap and die set (preferably that is made for working on 4130). He did say "sheet metal screws". You would use machine screws in a tapped hole of course. The problem is that the tubes he refers to are pretty thin walled and would not accept much of a real thread. Might it easier to run PK screws in though. O-ring |
"O-ring Seals" wrote in message
... On Fri, 23 Jan 2004 12:05:08 -0500, "Jim Carriere" wrote: "Grandpa B." never.mind wrote in message ... Greetings, all. I'm restoring a Champ, and have a question about driving screws into a drilled 4130 tube. If I drill the proper sized hole, the screws refuse to 'take'; they simply give up their threads to the harder metal of the tube. If I over-size the hole, then the screw won't hold diddley (that's a technical term). Are you tapping the holes? As in, with a tap and die set (preferably that is made for working on 4130). He did say "sheet metal screws". You would use machine screws in a tapped hole of course. The problem is that the tubes he refers to are pretty thin walled and would not accept much of a real thread. Might it easier to run PK screws in though. Bob........... The tube frame for the Emeraude canopy uses rivnuts (metric thread of course ![]() might work for occasional use. Rich S. O-ring |
On Sun, 1 Feb 2004 14:07:40 -0800, "Rich S."
wrote: He did say "sheet metal screws". You would use machine screws in a tapped hole of course. The problem is that the tubes he refers to are pretty thin walled and would not accept much of a real thread. Might it easier to run PK screws in though. Bob........... The tube frame for the Emeraude canopy uses rivnuts (metric thread of course ![]() might work for occasional use. Rich S. O-ring Rich, The area where he is placing the screws is in structural fuselage tubing. I feel that the hole size required for rivnuts might compromise the integrity of the tubing. He is adding a new set of holes as it is. Best to get some number sized drill bits ( 1/64" one way or the other may not work ) and practice on some scrap tubing to find the one that works. O-ring |
Just a caution on the Harbor Freight rivnut tool. I found the #6 mandrel
included with mine was undersized, and would not engage the threads of the #6 rivnuts well enough to crimp them. The #8 worked fine*; I haven't tried the other sizes. Just something to look out for if you're planning on using #6s. *By working fine, I mean it pulled some righteous brand-name RivNuts. The #6 didn't work with either the HF or brand-name ones. A dial caliper vs a screw checker revealed the undersizing issue. It just pulled the thread out of the rivnut. Actually, just pulled the crest of the thread, since the mandrel didn't reach all the way to full thread depth. Henry Bibb Rich S. wrote: The tube frame for the Emeraude canopy uses rivnuts (metric thread of course ![]() might work for occasional use. Rich S. |
"Henry Bibb" wrote in message
ink.net... Just a caution on the Harbor Freight rivnut tool. I found the #6 mandrel included with mine was undersized, and would not engage the threads of the #6 rivnuts well enough to crimp them. The #8 worked fine*; I haven't tried the other sizes. Just something to look out for if you're planning on using #6s. *By working fine, I mean it pulled some righteous brand-name RivNuts. The #6 didn't work with either the HF or brand-name ones. A dial caliper vs a screw checker revealed the undersizing issue. It just pulled the thread out of the rivnut. Actually, just pulled the crest of the thread, since the mandrel didn't reach all the way to full thread depth. I'll watch for that, Henry. I bought one a couple years ago when they were on sale, but it's still in the package. Rich S. |
... The area where he is placing the screws is in structural fuselage tubing. I feel that the hole size required for rivnuts might compromise the integrity of the tubing. He is adding a new set of holes as it is. Best to get some number sized drill bits ( 1/64" one way or the other may not work ) and practice on some scrap tubing to find the one that works. Gotcha, Bob. Mebbe he just needs one those rare "sheet metal screw" taps??? Rich S. |
On Mon, 2 Feb 2004 17:14:34 -0800, "Rich S."
wrote: "O-ring Seals" wrote in message ... The area where he is placing the screws is in structural fuselage tubing. I feel that the hole size required for rivnuts might compromise the integrity of the tubing. He is adding a new set of holes as it is. Best to get some number sized drill bits ( 1/64" one way or the other may not work ) and practice on some scrap tubing to find the one that works. Gotcha, Bob. Mebbe he just needs one those rare "sheet metal screw" taps??? Rich S. Rich, Now that you mention it, a self-tapping sheet metal screw of some type might work. Bob |
![]() "O-ring Seals" wrote in message ... On Mon, 2 Feb 2004 17:14:34 -0800, "Rich S." wrote: "O-ring Seals" wrote in message ... The area where he is placing the screws is in structural fuselage tubing. I feel that the hole size required for rivnuts might compromise the integrity of the tubing. He is adding a new set of holes as it is. Best to get some number sized drill bits ( 1/64" one way or the other may not work ) and practice on some scrap tubing to find the one that works. Gotcha, Bob. Mebbe he just needs one those rare "sheet metal screw" taps??? Now that you mention it, a self-tapping sheet metal screw of some type might work. Be sure the self tapping screw is driven straight. |
Sheet metal "Nibbler" | Nolaminar | Home Built | 3 | January 24th 04 06:05 AM |
Sheet metal shear/press brake | VideoFlyer | Home Built | 7 | October 7th 03 07:08 PM |
