#51
![]() Dale wrote: I made some cheap light wheel-chocks from PVC pipe. I'm old-fashioned. I ripped mine on the tablesaw from 2x4 scrap. Screweyes in the ends and a bit of clothesline, and done. They take up next to no space in the plane, too. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
#52
In article 8RYUb.234255$I06.2627994@attbi_s01, Jay Honeck
wrote: - Silicone spraying your yokes will make your landings better. Is that so when you pull all the way back it slips out of your fingers just at the moment of touchdown? ;-) |
#53
I'm looking for a cargo net also. The baggage area in my cherokee
has two long straps (diagonal the entire width, made of seatbelt webbing) but that doesn't hold down the small stuff that can get loose. |
#54
just at the moment of touchdown? ;-) Hmm. Okay, maybe that should read "Silicone spraying your yoke *shafts* will help your landings"? :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#55
On Fri, 6 Feb 2004 15:44:44 -0500, "Bob Chilcoat"
wrote: I've been looking for a cargo net that will hold down the stuff that's stored in the baggage area (two quarts of oil, small tool box, tiedown kit, etc. I have this image of having to remove the tool box from someone's head after landing out somewhere. Anyone seen one that will work well in an Archer? -- Bob (Chief Pilot, White Knuckle Airways) My cargo net is from the trunk of a mid-size chevy sedan. I think they were standard equipment in the 90's. I got mine at the wreckers for $5. |
#56
On Sat, 07 Feb 2004 03:49:40 GMT, "G.R. Patterson III"
wrote: Dale wrote: I made some cheap light wheel-chocks from PVC pipe. I'm old-fashioned. I ripped mine on the tablesaw from 2x4 scrap. Screweyes in the ends and a bit of clothesline, and done. They take up next to no space in the plane, too. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. mines from a 4x4 cut on the diagonal complete with lightening holes. I used to just block one wheel with the canada flight supplement. |
#57
has two long straps (diagonal the entire width, made of seatbelt webbing) but that doesn't hold down the small stuff that can get loose. This is why we went with the "fits-under-the-bed-on-wheels-plastic-box" instead of a cargo net. It fits in the compartment perfectly, has a flip-up lid, and keeps all the stupid little stuff contained. Unless you get a really tight-mesh net, all the little stuff will just come through it. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#58
![]() Blanche wrote: I'm looking for a cargo net also. These are sold for SUVs. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
#59
I'm 30 miles away from airplane and manual...anyone remember the
width & length of the cherokee 180D baggage area? Floor dimensions, I mean. Or, Jay, what are the dimensions of your under-bed-on-wheels-plastic-box? thanks |
#60
![]() - A Tuffy (mesh diswashing scrubber) in the air vent tubes to keep the air flowing and the bees out. - A low-milliamps voltage regulated 13.4 volts trickle charger wired in to the "keep alive" breaker (clocks and such) to keep the battery going between long periods of aircraft disuse. It makes it much easier to use if you remove the cigarette lighter and replace it with a little 2.1mm power connector tied in to the keep alive circuit. - A trouble light on the top of the cylinders and an oil dipstick warmer for winter easy starts (remove before flight {;-) ) - A long (repeat LONG) wooden dowel marked off in PENCIL in 5-gallon increments to dip each tank. The LONG part keeps it from falling into the tank. Pencil will not dissolve in fuel; ink will. Do NOT varnish or finish as you will not be able to read the dip level. - Small USA and state flags with knotted rubber bungees (or VERY heavy rubber bands) to tie to the prop. (Comes in very handy for campaigning, too!!!) The lateral curvature of the prop keeps them from blowing off. - For emergency high-wing ferry use, a small aluminum bracket drilled out to the size of the tie-down bolt, with a BNC connector and a rubber duck antenna mounted to the plate and strung in to the cockpit along the strut with STRING (not abrasive ribbed nylon) ties will serve as a decent temporary com antenna. .... Jim "Jay Honeck" shared these priceless pearls of wisdom: -A few more tricks that come to mind: Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 04 06:28 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 9th 04 03:47 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 04 06:27 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
