Tiny vacuum pump
Old January 24th 04, 05:42 AM
Wright1902Glider
If you've got shop air, try looking for either a Vac Cubes or Piab venturi-type
vac injector. Both companies make some that are under 1" sq. and are used to
pick up post cards, tec. on factory machines. Should be in the $20 range.
You'll probably find them in your area at an industrial pneumatics supplier.
Harry
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
