Piper headliner (was: simple and cheap tricks for your plane)
Old February 7th 04, 06:53 AM
Prime
Default Piper headliner (was: simple and cheap tricks for your plane)
We have a Cherokee 140. I want to know if anybody knows the simple
and cheap trick to clean our headliner. It is actually in fine
condition, but it has a LOT of brownish spotting on it, apparently
caused by moisture (you know, condensation, leakage, etc. - not
that OUR plane leaks!). It looks like crap. The headliner appears
to be a heavy fabric, almost seems like it is vinyl coated.
I tried washing it, spraying it with a variety of liquids (ammonia,
bleach and water, Formula 409). They helped to reduce the intensity
of the spots by about 30%, which is not nearly enough.
Ideas?
Tim Long
CMA, CA
Old February 7th 04, 02:34 PM
Jay Honeck
Ideas?
Try Castrol's "Super Clean."
That stuff seems to remove just about anything. We use it on literally
every tough stain at the hotel.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 7th 04, 04:16 PM
hlongworth
Prime wrote in message ...
We used vinyl spray paints to rejuvenate the interior of our 1970
Cardinal. The headiner, plastics and vinyl panels now look pristine.
We used two types of paints (Krylon fusion and SEM vinyl paint)
http://www.krylon.com/product/gp_pro....asp?sgID=GP07
http://www.levineautoparts.com/semvinandpla.html
Our initial test showed that it took fewer coats to cover
stains/old color with Krylon so we chose it for the headliner and
upper plastic/panels. and used the more durable SEM paint for lower
plastic/panels. The Krylon fusion worked great on the headliner and
plastics but remained sticky on the vinyl panels (after weeks!). We
ended up repainting the vinyl panels with SEM paints. Krylon fusion
paints can be found at many hardware stores including walmart. We had
to order the SEM paint through an autopart. This was part of the
reason going with Krylon. It we were to do it all over again, we would
just use SEM vinyl paint for everything.
Do remember to take pictures during the headliner removal process.
We did not any pictures or notes!. The entire interior was stripped
bare last summer and we had just recently put everything back together
(had to wait for the annual then was 'grounded' 3 months for an engine
rebuilt). Everything felt into places in the end but it would have
been easier with better planning.
Old February 7th 04, 06:12 PM
atis118
I bought a pack of those Armour All wipes and was amazed with how well
they cleaned up the interior plastic and headliner. The headliner did
not get as clean as the rest of the plastic because the headliner in
my Dakota 236 has a weave pattern. But these wipes did remove enough
to make a drastic difference. I bought the orange kind, and I found
that they also worked really well on the exterior of the plane for oil
marks and bird poop!
Greg King
KVNY
Ideas?
Tim Long
CMA, CA
Old February 8th 04, 05:32 PM
Mike Spera
There is a quick and easy way to make a Piper headliner look good. Use
shoe polish. The kind that is in liquid form with the sponge applicator.
I think the brand that many of us remember is "Kiwi". It takes a while
to do it, but it covers most discolored spots and usually leaves a
uniform color. It is a LOT less messy than vinyl sprays and dyes. You
might want to get the plane up to about 65+ degrees F to use the stuff
(heated hangar or warm Southern climate). You have to tip the bottle
upside down and, if I remember right, touch the sponge enough to get it
to soak up some polish. You may have to depress the sponge enough to
scrunch the rubber collar that holds it. Put a rubber glove on one hand.
The stuff may drip so cover up the interior. Last guy I saw who did it
transformed a discolored, spotted headliner into like-new condition.
Try it on a small spot to see if you like the result.
Good Luck,
Mike
Ideas?
Tim Long
CMA, CA
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old February 10th 04, 11:51 AM
John
I second the use of Kiwi white shoe polish.
You may have to do a few "coats" but it works great!
John
Old February 10th 04, 01:04 PM
Nathan Young
On Sat, 07 Feb 2004 06:53:46 -0000, Prime
The brown spotting is probably the glue that was used to help hold the
headliner up. I cleaned mine with several cleaners, and couldn't get
the brown spots clean. I ended up pulling the seats, masking off the
interior of the plane, and painted it with Krylon. Looks brand new.
Use several light coats, and get a respirator.
-Nathan
Old February 10th 04, 03:15 PM
Dan Thomas
(hlongworth) wrote in message . com...
I can second the use of SEM paints. They work well, and make the
part look like new. Stained plastic is almost impossible to clean,
since the stain is often IN the plastic, not on it.
That said, the plastic interior parts in many older airplanes are
brittle and falling apart from heat and UV damage. Not worth fixing.
Google "Plane Plastics" for affordable replacements.
Dan
Old February 10th 04, 04:47 PM
Don Tuite
On Tue, 10 Feb 2004 11:51:21 GMT, "John"
WHITE!!? What am I gonna do now with this cordovan headlliner?
Don
Simple & Cheap Tricks for your plane Jay Honeck Owning 79 April 21st 04 02:46 PM
