			#11
..... you can cut seatbelts
	Isn't it easier just to unfasten them? vince norris  |
			 What is the best metal/guage/length of wire to carry for snares?  |
	vincent p. norris wrote: ..... you can cut seatbelts Isn't it easier just to unfasten them? Yes, assuming you can get to the release. After a crash you may have shift enough that you won't be able to release the seatbelt. I know of one case where a floatplane flipped upside down in shallow water. The pilot was still strapped in and couldn't release due to the new upholstery being thicker than the original and the buckle being outboard so that it was jammed against the armrest by the pilots weight. Rescuers were attempting to get him out and handed him a knife, after a moment he handed the knife back. The airplane sank and he died. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html  |
	Isn't it easier just to unfasten them? Yes it is - Unless you are hanging upside down, disoriented, unable to see . . . Also, it isn't just for you - it's for your passengers too - if they are hanging in the belt unconscious cutting the belt may be the only option, particularly if fire/sinking/whatever make it time critical. Tony -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE  |
	EDR wrote: What is the best metal/guage/length of wire to carry for snares? It depends on what you want to snare. For a pocket survival tool I buy a light copper snare wire and it comes in a roll of about 15 ft. It only weighs a few ounces. I like copper as when it is used as a snare it doesn't stand out like steel does. It has many survival uses. I teach a basic survival course and my favourite use for it is tie together the poles to errect a signalfire tower - it continues to hold when the fire takes off - unlike string which lets the whole lot fall apart  . It is also great for fasteningthe materials for your shelter, it is great to hold on your makeshift snowshoes, it can be used to repair things, and to cut with. It can bind a sharp stone to a pole to make a spear, and you can fish with it. And it can be used as snare wire. The one that I use is good for birds, rabbits, squirrels etc, and used in 2 or 3 loops it would be useable on larger game. HTH Tony -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE  |
	Yes it is - Unless you are hanging upside down, disoriented, unable to see . . . Sorry, Tony, I just don't find that persuasive. If you're "hanging upside down, disoriented, unable to see," you're going to have a lot more trouble finding your tool, unhooking it from your belt, etc., than opening a seat belt buckle you've done hundreds of times before. vince norris  |
			 "vincent p. norris" wrote: If you're "hanging upside down, disoriented, unable to see," you're going to have a lot more trouble finding your tool, unhooking it from your belt, etc., than opening a seat belt buckle you've done hundreds of times before. Next time you're in a plane, try this. Fasten the belt. Then raise your body as far off the seat as you can with your legs, putting as much pressure as you can on the belt. Then try to open it. If it's like mine, you won't be able to do it. You'll have more pressure than that on the belt if you're upside down. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip.  |
			 "vincent p. norris" wrote in message ... Isn't it easier just to unfasten them? Yes it is - Unless you are hanging upside down, disoriented, unable to see . . . Sorry, Tony, I just don't find that persuasive. If you're "hanging upside down, disoriented, unable to see," you're going to have a lot more trouble finding your tool, unhooking it from your belt, etc., than opening a seat belt buckle you've done hundreds of times before. Or, perhaps something is jammed against the release, or against the harness so you just can't access the release. Or the harness is tangled with something or the release is mangled somehow. Or your hand/arm that should operate the release is broken, or, your passenger can't get to his release and you can only reach some other part of their harness ...  |
			 Isn't it easier just to unfasten them? Yes it is - Unless you are hanging upside down, disoriented, unable to see . . . Are you saying the seatbelt is no longer around your waist?  |
	as far off the seat as you can with your legs, putting as much pressure as you can on the belt. Then try to open it. If it's like mine, you won't be able to do it. Fair enough; I'll try it. But if that's the case, I think it would be smart to replace the buckle. vince norris  |
| Thread Tools | |
| Display Modes | |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
| Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 01:35 AM |
