Hi, Dan,
Thanks for your suggestions. I leaned the mixture for the static runup and consequently got good results. I did NOT lean before takeoff. Perhaps that is significant. Chuck On 12 Feb 2004 16:57:35 -0800, (Dan Thomas) wrote: "Gary" wrote in message ... Also, there was a "burbling" sound from the exhaust. Maybe loose baffle in muffler restricting the outlet. Could have broken loose between the time you tried it and the time you took it away. Other things to check might be one mag retarded somewhat, perhaps caused by a broken impulse coupling spring. Did you try leaning the mixture a bit to see if there was better RPM in the static runup? Dan Freedom Chuck - The Man of 1,000 Songs see my website at: www.freedom-chuck.com |
results. I did NOT lean before takeoff. Perhaps that is significant. That can be very significant on a hot day. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Cessna 150 lost power with AD 96-12-06? | Ozzy Countin | Owning | 3 | August 17th 03 05:41 AM |
