#11
![]() Last summer we bought a 1997 160 HP Cessna 172-R. The test flight (with 3 adults) went just fine. Hi Chuck Suggest you pull all of the plugs & examine them - I believe that you will find at least some of them are black from running too rich. I also suggest that you also post your question at: http://www.cessnaowner.org/new/forum/forums.htm There is a ton of Cessna knowledge there. Tony -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE |
Hi, Dan,
Thanks for your suggestions. I leaned the mixture for the static runup and consequently got good results. I did NOT lean before takeoff. Perhaps that is significant. Chuck On 12 Feb 2004 16:57:35 -0800, (Dan Thomas) wrote: "Gary" wrote in message ... Also, there was a "burbling" sound from the exhaust. Maybe loose baffle in muffler restricting the outlet. Could have broken loose between the time you tried it and the time you took it away. Other things to check might be one mag retarded somewhat, perhaps caused by a broken impulse coupling spring. Did you try leaning the mixture a bit to see if there was better RPM in the static runup? Dan Freedom Chuck - The Man of 1,000 Songs see my website at: www.freedom-chuck.com |
Hi, George,
Thanks again for your help. I'm going to ask my AME to check the fuel injection system. Chuck On Fri, 13 Feb 2004 01:30:35 GMT, "G.R. Patterson III" wrote: Chuck wrote: George Patterson, you say it's running way to rich. I was wondering way you say this, but you just may be right. To correct this I The "burbling" sound you report is typical of raw gas going through the engine and igniting in the exhaust system. I'm not familiar with the injector system, so I really can't help with troubleshooting. With a carbureted engine, you could easily check this by leaning on the ground. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. Freedom Chuck - The Man of 1,000 Songs see my website at: www.freedom-chuck.com |
Thanks for your suggestion, Tony,
I'll ask my AME to check the plugs, as well as the fuel injection system. And I'll try the forum you suggested. Chuck On Fri, 13 Feb 2004 02:06:26 GMT, tony roberts wrote: Last summer we bought a 1997 160 HP Cessna 172-R. The test flight (with 3 adults) went just fine. Hi Chuck Suggest you pull all of the plugs & examine them - I believe that you will find at least some of them are black from running too rich. I also suggest that you also post your question at: http://www.cessnaowner.org/new/forum/forums.htm There is a ton of Cessna knowledge there. Tony Freedom Chuck - The Man of 1,000 Songs see my website at: www.freedom-chuck.com |
On Fri, 13 Feb 2004, Chuck wrote:
Victor J. Osborne Jr., your question about fuel flow/pressure is interesting. When starting you are supposed to advance the lean control with the aux. fuel pump on to get about 3-5 gal/hr., then when it starts, you turn off the aux. fuel pump. But once the engine starts, I don't know what the fuel flow/pressure is. Do I read it on the fuel flow gage? You leave the pump on until after starting? My 172R POH says to shut the pump off before starting. I only use the pump for priming and switching tanks. I also make sure to lean back a few turns as soon as the engine settles down. -- Rick/JYO remove 'nospam' to reply |
fuel flow/pressure. I recently learned that some add-on fuel flow
transducers can restrict fuel flow, resulting in reduced flow (actually pressure) to the injectors. i.e. you do not develop full power on take off. Having said (?) that, I have no idea how you would check the fuel pressure on a 172. W/o manifold pressure at sea level, I guess you w/b left w/ installing an aux. gauge for the test. Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
![]() "Chuck" wrote in message ... Hi, all, First, I want to thank everyone who made suggestions. Gary, a compression check was done on all cylinders and the compression is fine. The power for a full-power static runup should be 2065 to 2165 with the mixture leaned for max rpm. The actual rpm is about 2150. I think this is the most significant thing said. There is no way that the engine should give higher revs on the static check, than on the takeoff roll, unless something is making a 'difference' between the configuration. I see latter, that you say you lean for the power check, but not the take-off roll. The obvious question at this point, is what altitude the field is at?. If it is below perhaps 3000 feet, then the difference, together with the noise reported really solidly implies that the injection is running rich at it's default settings. If you are higher than this, then you should really be considering leaning for takeoff. snipped Aaron Coolidge, your comment about the fuel injection is also interesting. I will certainly ask our mechanic to check it (since the plane is in for its annual anyways). I did not, however, notice loss of power, but at minimum rpm (with the throttle full out) it does not idle very well -- it feel like it's going to stop. Rich... George Patterson, you say it's running way to rich. I was wondering way you say this, but you just may be right. To correct this I Once again, thanks to everyone. Chuck I think George has hit the nail on the head. Best Wishes |
Chuck wrote in message . ..
I'll ask my AME to check the plugs, as well as the fuel injection system. And I'll try the forum you suggested. Wow, your AME must be pretty well-rounded. I don't think mine even dabbles in mechanics. ;-) |
On Thu, 12 Feb 2004 19:02:46 GMT, Chuck
wrote: Hi, all, All rpm indications were within spec (for static run-up, etc). When on the takeoff roll, rpm was about 2100, which seemed low, but there is no spec in the POH for rpm for the takeoff roll. The rpm went much higher after we were cruising (2300 or so). Also, there was a "burbling" sound from the exhaust. The prop was removed, inspected and put back on (with pleanty of scratch marks which weren't there before. Are you sure they put the correct prop on the plane? I know some of the new 172 series were produced with 160hp and others with 180hp. Although you have to hope the mechanics did a better job - if you have a 160hp it is possible they swapped props with a 180hp 172. A cruise prop would drag down both the static RPM and climb performance. On the other hand, you should notice a few mph improvement in cruise (unless the prop is grossly wrong). -Nathan |
Chuck wrote:
it. OK it was hot but the book said we should be over a 50' obstacle at about 1800' - we were not even close! Hey Chuck, Maybe those 1000 songs were weighing down the plane grin. Michael Nickolas www.studionineproductions.com |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Cessna 150 lost power with AD 96-12-06? | Ozzy Countin | Owning | 3 | August 17th 03 05:41 AM |
