![]() Dan Thomas wrote: Remember that GPS give you track, not heading, and if there's any appreciable wind you won't get anywhere near accurate heading indications for compass calibration purposes. Use the heading indicator instead. Yep, forget the GPS. Use this method instead: Line up on a taxiway or runway with a known, published heading and carefully set the HI. Go fly on gyro headings 360, 030, 060, etc. and carefully record the magnetic compass reading. You might want to try it with and without lights, pitot heat, any other major power consumers. Return to your known taxiway or runway and verify the HI hasn't drifted. Dave Remove SHIRT to reply directly |
Reading the whiskey compass | Ben Jackson | Instrument Flight Rules | 20 | February 28th 04 08:09 AM |
"Whiskey" for compass? | dale | Home Built | 10 | December 17th 03 11:16 PM |
RAHian behavior | Morgans | Home Built | 6 | August 12th 03 04:38 AM |
I'm lost. Which compass? | Greg Burkhart | Owning | 1 | August 12th 03 03:49 AM |
Vertical Card Compass compatible with "V" brace? | Jeff P | Owning | 1 | July 11th 03 03:46 AM |
