![]() wrote in message ... Dave Stadt wrote: :The : cylinders themselves have choke (they're slightly smaller bore at the : top), with the : thought being they'll expand to be straight when they heat up during : normal operation. : Those two things are the primary reasons.... lack of oil and scuffing of : cylinders. : Doesn't play. The pistons are aluminium and the bores are steel. In cold : weather the aluminium pistons shrink more than the steel cylinders and : clearance actually increases. The rings are steel and follow the cylinders. True... except the piston is warmed by the first few seconds/minutes of combustion much quicker than the steel cylinders. It's not the starting so much as the dissimilar warmup. If the cylinders are pre-warmed, the temperature differential to be transitioned through is lower. Percentage wise the difference is minimal. Granted it's engine preheater propaganda, I believe there's some truth to the research in http://www.tanair.com/article6.html. If you get high-time from your engine without preheat, then good for you. Nobody said that cold-starts are the only cause of engine wear, and I'm sure that for particular engines it's worse than others. As always, YMMV. I do preheat but to be honest I don't know why. Nothing in this discussion has convinced me that anybody knows why or what harm, if any, is caused by not preheating. Only thing I know for sure is preheating makes it much easier to start the engine. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
![]() Dave Stadt wrote: I do preheat but to be honest I don't know why. Continental will tell you that failure to preheat one of their engines when the temperature is below 20 degrees F may result in a snapped valve stem. Good enough? George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
![]() "G.R. Patterson III" wrote in message ... Dave Stadt wrote: I do preheat but to be honest I don't know why. Continental will tell you that failure to preheat one of their engines when the temperature is below 20 degrees F may result in a snapped valve stem. Good enough? I have never sen that written about the O-200. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
![]() "Dave Stadt" wrote in message m... Percentage wise the difference is minimal. Granted it's engine preheater propaganda, I believe there's some truth to the research in http://www.tanair.com/article6.html. or http://www.reiffpreheat.com/index.html I'm leaning towards a Reiff System, probably the Turbo XP system. It just seems a better design especially with a JPI EDM-700 installation. |
On Wed, 18 Feb 2004 17:12:13 -0700, "Tom Sixkiller"
wrote: "Dave Stadt" wrote in message om... Percentage wise the difference is minimal. Granted it's engine preheater propaganda, I believe there's some truth to the research in http://www.tanair.com/article6.html. or http://www.reiffpreheat.com/index.html I'm leaning towards a Reiff System, probably the Turbo XP system. It just seems a better design especially with a JPI EDM-700 installation. I've had a TANIS system for about fifteen years, along with an Insight GEM. The "cylinder" heating is taken care of by heated intake bolts, so no interference with anything else. The oil heating is via a heated oil screen (the upper one). I have no experience with the Reiff system. With a cover, my cylinders are usually around 100°F and the oil around 80°F with OAT's down to -5°F or so. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
I have the Reiff cylinder bands and pan heater for my Arrow - works
just great. I set the timer and the whole engine is warm to the touch when I arrive even when temp is near zero. I also use a Kennon padded cowl and prop cover to retain the heat. |
Exactly!
denny "Dave Stadt" wrote in How come the engine in my car with 190,000 miles is running fine with no signs of undue wear with nary a single preheat. It is often started at temps well below 0 F. Aluminium block, steel crank, steel cylinder liners and aluminium pistons same as the ole Continental. |
Turbine air start -- too cold? | Juan Jimenez | Home Built | 97 | March 14th 05 06:51 PM |
Turbine air start -- too cold? | Juan Jimenez | General Aviation | 54 | February 2nd 05 04:14 AM |
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs | Larry Dighera | Military Aviation | 7 | April 2nd 04 07:05 PM |
Soviet Spy Planes over the West during the Cold War | Rusty B | Military Aviation | 6 | February 19th 04 04:53 PM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
