Flying to Arlington, VA
Old February 17th 04, 11:07 PM
Michelle P
Sami,
Rick has a good point. Do a little more than read up on the ADIZ, give
Leesburg AFSS a call directly and ask about the operations into and out
of the ADIZ. Their direct phone number is 703-777-2856 .I also have a
toll free number but I am not sure if it will work from your area.
866-228-7410
If you bust it you WILL loose your license. The marshalist TSA has
mandated that any pilot who violates the ADIZ must loose their license.
I know of two pilots who have had to start over because they
un-intentional wandered into the ADIZ without following the procedures.
Make sure you ask about entry points from the west. There are common
points that the controllers expect.
Michelle
Rick Glasser wrote:
On Mon, 16 Feb 2004 16:47:09 +0000, Michelle P wrote:
Sami,
Your best choices are Manassas or Leesburg. Manassas is closer and has
Rail service to downtown DC. You can then take the Metro back out to
Arlington. http://www.vre.org
Either Jet Services or Dulles Aviation is ok. Their service is pretty much
the same.
Leesburg is easier to get to however you will have to rent a car. Manassas
may be cheaper parking.
Dulles is an option all be it an expensive one. Landing and parking is
over $20 for the day and I work there!
Michelle
O. Sami Saydjari wrote:
I am going to need to travel to Arlington, VA (Ballston area) on
business fairly often. Does anyone have any tips on the best and
nearest general aviation airport to fly into. I am looking for
something that is as close as possible. Reagan would be ideal, but I
expect that they have either prohibitted General Avaiation flights
there, or have landing fees that are not affordable (if i am wrong on
this, please advise). Other likely airports seem to be Manassas,
Gaithersburg, and College Park.
-Sami
N2057M, Piper Turbo Arrow III
I'll agree with Michelle. I fly out of Leesburg and it is a straight-shot
down the Dulles Toll Road ($2.75) to Ballston. Manassas is towered,
Leesburg is not. Leesburg has a AFSS on the field. Piedmont Hawthorne is
the FBO at Leesburg and they will arrange for an rental if you call them:
http://www.piedmonthawthorne.com/jyo/index.asp
GAI is a little closer but on the wrong side of the river -- can be a
factor in rush hour. National, Collage Park, Hyde and Potomac are out for
you because of the Flight Restricted Zone.
Coming into the area, read up on the ADIZ. This is not a big deal if you
follow the rules. It is a HUGE deal if you do not. Feel free to contact
me privately if you want tips from a local.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old February 18th 04, 01:40 AM
John Clonts
"Michelle P" wrote in message
ink.net...
Sami,
866-228-7410
Hi Michelle,
What do you mean, "...had to start over..."? Did they have their
certificates taken away, but they can some how earn them back? Wow, that IS
nuts!
Cheers,
John Clonts
Temple, Texas
N7NZ
Old February 19th 04, 03:09 PM
Michelle P
John,
Yes, is some instances you can start over.
I believe unless it is criminal, you can start over if you wish.
In one case a flight instructor did not enter the last digit in the
Garmin 327 Transponder since it was already the octet they wanted.
Apparently, the the 327 stops squawking your code while you are entering
it. Makes sense, you do not want to be sending several different codes
while you are changing it. Just make sure you enter all four octets when
changing codes.
Michelle
link.net...
Sami,
866-228-7410
Hi Michelle,
nuts!
Cheers,
John Clonts
Temple, Texas
N7NZ
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
Progress on Flying Car Steve Dufour General Aviation 5 December 19th 03 03:48 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
