BTIZ wrote:
Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Allen |
Allen
Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? A little too simplified. Low wing airplanes get blown over in high winds as do high wing airplanes. Dihedral, direction and force of the wing, width of the landing gear all play a role. When taxiing, holding appropriate aileron and elevator deflection makes a big difference. Doing it wrong on an extremely windy or gusty day, combined with misue of the brakes which gets the airplane rocking, can ruin things for you in almost any light airplane. All the best, Rick |
Plus the wind is less the closerit is to the ground because of friction.
Roger @ MD43 C150E "Rick Durden" wrote in message m... Allen Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? A little too simplified. Low wing airplanes get blown over in high winds as do high wing airplanes. Dihedral, direction and force of the wing, width of the landing gear all play a role. When taxiing, holding appropriate aileron and elevator deflection makes a big difference. Doing it wrong on an extremely windy or gusty day, combined with misue of the brakes which gets the airplane rocking, can ruin things for you in almost any light airplane. All the best, Rick |
I agree. Low wings ought to be taxed out of existence.
{;-) Jim (manly high winger) that's MANLY, not mainly. - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Taxes aren't needed. Just send a high-wing out after them
The Ultimate High-Wing = B-52! - - - Al Gilson 1964 Skyhawk 3082U In article , wrote: I agree. Low wings ought to be taxed out of existence. {;-) Jim (manly high winger) that's MANLY, not mainly. -- Al Gilson Spokane, WA USA 1970 VW Convertible 1964 Cessna Skyhawk |
A Lieberman wrote in message ...
I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Lower CG is part of it. The weight of not only the fuel, but the wing spar and internal structure significantly contributes to the lower CG. The other part is that the gear stance is usually wider on a low wing, since it is often attached to the wing spar instead of the fuselage. The triangle formed by the nose, left and right wheel is wider and less prone to tip to one side or the other. John Galban=====N4BQ (PA28-180) |
![]() "John Galban" wrote in message om... A Lieberman wrote in message ... I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Lower CG is part of it. The weight of not only the fuel, but the wing spar and internal structure significantly contributes to the lower CG. The other part is that the gear stance is usually wider on a low wing, since it is often attached to the wing spar instead of the fuselage. The triangle formed by the nose, left and right wheel is wider and less prone to tip to one side or the other. For a low center of gravity, consider the Rockwell JetProp (now Twin Commander) when the bottom of the fusalage is only nine inches off the pavement. This can make the body act like an air dam for crosswind taxiing. |
Although all planes differ, the general answer is... yes.
Lot of factors here, but the wing being lower, helps..center of gravity is lower, and the main gear stance is wider , not being confined to mounting on the fuselage. I remember a landing a Comanche in a X-wind..(no cross rny- BTW, landings are mandatory) that would have sent our Cessna end over end. 3rd attempt, right foot in the firewall.. I would have been plain dumb to try this with a 182.. I have some time on a Warrior, - short, sturdy wide spaced gear.. Worked well in x-winds, but the rudder on the Comanche seemed to be more effective in the slip... Cheers! Dave on the On Sat, 21 Feb 2004 07:51:29 -0800, A Lieberman wrote: BTIZ wrote: Lets just say I've seen more than one Cessna flipped onto its back when tie downs failed in high winds.. But Pipers seem to stay upright. I wondered about this. I found that taxing a low wing is much easier to handle in high winds situation. Is it because the CG is lower to the ground? After all, the weight of the fuel is lower to the ground over the wheels, thus harder to tip over? Allen |
new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 10:20 PM |
Flight training recommendations for Dubai | Roland | General Aviation | 0 | August 9th 04 01:25 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 07:47 AM |
