#5 cylinder not firing
Old February 25th 04, 01:41 PM
David R.
Default #5 cylinder not firing
We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago,
we began to notice the engine to be rough on the right magneto during
run-up. Over two weeks, it became increasingly difficult to burn it off by
leaning during the run-up, until one day when it became impossible. We
noticed on the engine monitor that the #5 cylinder head temp was cold during
the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug
which was replaced. Now, about 15 hours later (and an annual), we have the
same problem with the #5 cylinder. It's going back to the shop today. Any
ideas? Why the same cylinder? What should we be looking for?
Old February 25th 04, 02:06 PM
Newps
Bad plug, bad mag or bad spark plug wire.
Old February 25th 04, 02:07 PM
Rich
What was fouling it? Oil? Carbon? Lead?
Lots of different answers depending on what the cause was.
Rich
Old February 25th 04, 02:11 PM
David
I'm not sure, but i think he said it was carbon.
"Rich" wrote in message
Rich
ago,
by
during
plug
Any
Old February 25th 04, 02:21 PM
jls
"David R." wrote in message
by
during
plug
Any
Bad cylinder, bad valve guides, bad plugs, bad wires -- all possibilities.
Old February 25th 04, 06:09 PM
Kevin Chandler
We had a similar problem except the plug was getting fouled with oil. We
had a crack piston ring.
Old February 25th 04, 06:27 PM
G.R. Patterson III
Bad plug wire.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old February 26th 04, 12:09 AM
Michael
You likely have a cylinder running too rich. First off, are you
leaning for taxi? You should be - and I mean leaning to the point
where you can't advance the throttle to runup power without killing
the engine.
Second - do you have a carbureted engine or an injected one? If
carbureted, not much you can do besides leaning, but if it's injected,
the injectors come in several sizes and you can go to a narrower bore
injector.
Of course it could be lots of other reasons as well. Bad plug, bad
contact in the mag, bad wire - but all those things cost money to fix.
Leaning costs nothing, so you should try that first.
Michael
Old February 26th 04, 04:47 AM
David R.
Yes, we are aggressively leaning before taxi.
Thanks for the info.
"Michael" wrote in message
m...
the engine.
injector.
Michael
Old February 26th 04, 04:49 AM
David R.
How do you diagnose a cracked piston ring? Scope? Compressions?
"Kevin Chandler" wrote in message
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 08:11 PM
O-200 Cylinder Repair jls Home Built 3 February 29th 04 02:45 AM
Cylinder Wrenches for 0-320A Narrow Deck DAVE Home Built 1 December 31st 03 01:45 PM
Stick Shake When Firing Guns John Kunkel Military Aviation 17 October 2nd 03 12:39 AM
'Hot' cylinder after overhaul? Tony Cox Owning 8 August 10th 03 07:25 PM
