I use it sparingly, about 2 oz. per 24 gallon fillup, and in the
fuel tanks only. Thanks . . . I put some in my fuel tanks when I started using auto gas, and started to see gray streaks along the right side of the engine cowling--apparently coming from the exhaust. It wiped right off, but I didn't know what it was. When I stopped using MMO, the streaking also stopped. Maybe I used too much . . . any ideas what the gray streaks were? www.Rosspilot.com |
I have a '65 172 and love the O-300. When I first got it I had
problems with plug fowling (despite leaning on the ground, etc.) and had a valve stick HARD. The previous owners had fed it a steady diet of 100LL. I started using mostly auto gas and the problems have gradually gone away. The engine was rebuilt with new Millennium cylinders and to new tolerances in 99 and had 1050 hours when I bought the plane a year ago. One cylinder had been replaced at about 600 hours due to valve problems. I flew a little over 100 hours in the first year and compressions were all in the 70s when I had the annual done last month. They key, like with any engine is to fly it frequently. 1. What kind of fuel burn do you consistently get with an O-300? Is the generally reported 105 KIAS @ 8 GPH true? I plan 9 GPH block to be on the safe side. 2. Does the autogas STC help reduce the problem with valve sticking? ABSOLUTELY -- so does flying frequently and using Marvel's Mystery Oil. 3.In general, has your experience led you to expect to have to do a top overhaul about halfway through the TBO period? What are the ballpark costs of such an operation. 1200 HRS SMOH -- Compressions in the 70s, engine runs great, uses very little oil -- (about 1 Qt per 15-18 hrs.) 4. In your opinion, would it be worth it to pay the premium to buy an new 172 equipped with the O-320E2D? No, but they're great planes too. I bought a 172 with the Continental specifically because they are such good bargains. But you have to be careful to get the right one. The Millennium cylinders and regular use since overhaul were factors I considered in purchasing this one. 5. Besides the valve guide and cylinder problems (often attributed to running on 100 LL), are there any other major problems that would make this an undesireable aircraft? The older 172s have narrower gear, lighter weight and slightly different handling due to cuffed wings on the later models, etc. All this makes them a little more challenging in winds, but still a wonderful airplane. Like others have said, carb ice is a definite issue, be proactive about checking for it and using carb ht when necessary. Remember to apply carb heat right before takeoff if you've been idling a long time; even if you already checked carb heat earlier during your run-up. - Brett |
Jim Weir wrote in message . ..
(Brett Justus) shared these priceless pearls of wisdom: -I have a '65 172 and love the O-300. When I first got it I had -problems with plug fowling How did the chickens get in to the engine in the first place? HEY spell check says that word is just fine! (WoooOOOPS) -ABSOLUTELY -- ... and using Marvel's Mystery -Oil. Somebody else must have used my computer when I was away -- I would never do that. Certainly not in a CERTIFICATED aircraft. Merciful heavens to Betsy {;-) Jim |
Is hyraulic drive posible? | PAW | Home Built | 38 | July 9th 04 08:03 AM |
Bush AWOL Story - New theory comes to light | Laura Bush murdered her boy friend | Military Aviation | 187 | March 30th 04 07:52 AM |
Stryker/C-130 Pics | robert arndt | Military Aviation | 186 | October 8th 03 09:18 AM |
Jabiru V Rotax reliability? | Joe | Home Built | 11 | September 5th 03 11:09 AM |
Space Junk & GPS Reliability | Doug Carter | Instrument Flight Rules | 9 | July 11th 03 01:38 PM |
